Full Version: Kodi craches while updating my movie library
Hey guys, I just bought a FireTV Stick two weeks ago, kodi works fine on it and I am super happy.
Since the FireTV Stick has no USB port, I bought a mini NAS Server and connect my external drive into my network.
The drive with all the movies is very well recognized from kodi, as long as I am using the filebrowser.
Everytime I try to set up my movie folder and update my movie library kodi crashes.
There is this little message in the right top corner that says "Getting information from the movie database... " and than it kicks me directly to the fire tv menu. Even if I tell Kodi to not use the Movie Database, but using just the local informations, Kodi tries to connect to the movie database and crashes.
I also cannot deactivate or delete this addon, its greyed out.
I am using a FireTV Stick and Kodi 15.2 - Eminence theme (if this is important)
Regards from Germany!
Here is my log File by the way:
12:31:31 T:1483078960  NOTICE: special://profile/ is mapped to: special://masterprofile/
12:31:31 T:1483078960  NOTICE: -----------------------------------------------------------------------
12:31:31 T:1483078960  NOTICE: Starting Kodi (15.2 Git:2015-10-19-02e7013). Platform: Android ARM 32-bit
12:31:31 T:1483078960  NOTICE: Using Release Kodi x32 build
12:31:31 T:1483078960  NOTICE: Kodi compiled Oct 19 2015 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
12:31:31 T:1483078960  NOTICE: Running on Amazon AFTM with Android 4.2.2 API level 17, kernel: Linux ARM 32-bit version 3.0.31+
12:31:31 T:1483078960  NOTICE: FFmpeg version: 2.6.4-kodi-2.6.4-Isengard
12:31:31 T:1483078960  NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 2 cores available
12:31:31 T:1483078960  NOTICE: Product: montoya, Device: montoya, Board: capri - Manufacturer: Amazon, Brand: BRCM, Model: AFTM, Hardware: montoya
12:31:31 T:1483078960  NOTICE: External storage path = /storage/emulated/0; status = ok
12:31:31 T:1483078960  NOTICE: ARM Features: Neon enabled
12:31:31 T:1483078960  NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
12:31:31 T:1483078960  NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
12:31:31 T:1483078960  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
12:31:31 T:1483078960  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
12:31:31 T:1483078960  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
12:31:31 T:1483078960  NOTICE: The executable running is:
12:31:31 T:1483078960  NOTICE: Local hostname: localhost
12:31:31 T:1483078960  NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
12:31:31 T:1483078960  NOTICE: load settings...
12:31:31 T:1483078960   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
12:31:31 T:1483078960 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
12:31:31 T:1483078960   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
12:31:31 T:1483078960   DEBUG: AESinkAUDIOTRACK - 44100 supported
12:31:31 T:1483078960   DEBUG: AESinkAUDIOTRACK - 48000 supported
12:31:31 T:1483078960  NOTICE: Found 1 Lists of Devices
12:31:31 T:1483078960  NOTICE: Enumerated AUDIOTRACK devices:
12:31:31 T:1483078960  NOTICE:     Device 1
12:31:31 T:1483078960  NOTICE:         m_deviceName      : AudioTrack
12:31:31 T:1483078960  NOTICE:         m_displayName     : android
12:31:31 T:1483078960  NOTICE:         m_displayNameExtra: audiotrack
12:31:31 T:1483078960  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
12:31:31 T:1483078960  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR
12:31:31 T:1483078960  NOTICE:         m_sampleRates     : 44100,48000
12:31:31 T:1483078960  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
12:31:31 T:1483078960  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
12:31:31 T:1483078960  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
12:31:31 T:1483078960  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <network>
                                                <buffermode>1</buffermode>
                                                <cachemembuffersize>20971520</cachemembuffersize>
                                                <readbufferfactor>1</readbufferfactor>
                                              </network>
                                            </advancedsettings>
12:31:31 T:1483078960  NOTICE: Default DVD Player: dvdplayer
12:31:31 T:1483078960  NOTICE: Default Video Player: dvdplayer
12:31:31 T:1483078960  NOTICE: Default Audio Player: paplayer
12:31:31 T:1483078960  NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:31:31 T:1483078960  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
12:31:31 T:1483078960  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
12:31:31 T:1483078960  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:31:31 T:1483078960  NOTICE: Loaded playercorefactory configuration
12:31:31 T:1483078960  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:31:31 T:1483078960  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:31:31 T:1483078960  NOTICE: WakeOnAccess - Load settings :
12:31:31 T:1483078960  NOTICE: WakeOnAccess - Enabled:TRUE
12:31:31 T:1483078960  NOTICE:   -Network init timeout : [20] sec
12:31:31 T:1483078960  NOTICE:   -Network settle time  : [500] ms
12:31:31 T:1483078960  NOTICE:   Registering wakeup entry:
12:31:31 T:1483078960  NOTICE:     HostName        : 10.10.10.254
12:31:31 T:1483078960  NOTICE:     MacAddress      : 00:1C:C2:20:78:E6
12:31:31 T:1483078960  NOTICE:     PingPort        : 0
12:31:31 T:1483078960  NOTICE:     PingMode        : 0
12:31:31 T:1483078960  NOTICE:     Timeout         : 300 (sec)
12:31:31 T:1483078960  NOTICE:     WaitForOnline   : 40 (sec)
12:31:31 T:1483078960  NOTICE:     WaitForOnlineEx : 40 (sec)
12:31:31 T:1483078960  NOTICE:     WaitForServices : 5 (sec)
12:31:31 T:1483078960  NOTICE:     HostName        : 192.168.0.13
12:31:31 T:1483078960  NOTICE:     MacAddress      : 60:03:08:A5:8C:5C
12:31:31 T:1495009312  NOTICE: Thread ActiveAE start, auto delete: false
12:31:31 T:1495114288  NOTICE: Thread AESink start, auto delete: false
12:31:31 T:1483078960  NOTICE: Running database version Addons19
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.addonscriptorde-beta
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.podgod
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.TheYidXXX
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.kodinerds
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.xunitytalk
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.bromix
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.xstream
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository MENTALITY.repo
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.xbmchub
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.entertainmentrepo
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository superrepo.kodi.isengard.all
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.dss
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.superrepo.org.frodo.others.adult
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.kodinerds.helix
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.lost-and-found
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.the-one
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.i4a-repo
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.xbmc.org
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.lambda
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository superrepo.kodi.gotham.all
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.laryloose.xbmc-addons
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.steverob
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repo.streamnetwork
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.BlazeRepo
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.seppius
12:31:32 T:1483078960  NOTICE: ADDONS: Using repository repository.superrepo.org.gotham.all
12:31:32 T:1483078960  NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
12:31:32 T:1483078960  NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
12:31:32 T:1483078960  NOTICE: Previous line repeats 1 times.
12:31:32 T:1483078960  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.999996 Hz
12:31:32 T:1483078960  NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
12:31:32 T:1483078960  NOTICE: Checking resolution 16
12:31:32 T:1483078960  NOTICE: GL_VENDOR = Broadcom
12:31:32 T:1483078960  NOTICE: GL_RENDERER = VideoCore IV HW
12:31:32 T:1483078960  NOTICE: GL_VERSION = OpenGL ES 2.0
12:31:32 T:1483078960  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
12:31:32 T:1483078960  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_debug_marker
12:31:34 T:1483078960 WARNING: Unable to resolve: /libcec.so CECInitialise, reason: Symbol not found:
12:31:34 T:1483078960   ERROR: Unable to resolve exports from dll libcec.so
12:31:34 T:1483078960   ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
12:31:34 T:1499672552  NOTICE: Thread PeripBusUSB start, auto delete: false
12:31:34 T:1483078960  NOTICE: Running database version Addons19
12:31:34 T:1483078960  NOTICE: Running database version ViewModes6
12:31:34 T:1483078960  NOTICE: Running database version Textures13
12:31:34 T:1483078960  NOTICE: Running database version MyMusic52
12:31:34 T:1483078960  NOTICE: Running database version MyVideos93
12:31:34 T:1483078960  NOTICE: Running database version TV29
12:31:34 T:1483078960  NOTICE: Running database version Epg10
12:31:36 T:1483078960 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
12:31:36 T:1483078960 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
12:31:36 T:1483078960 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
12:31:36 T:1483078960 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
12:31:36 T:1525977360  NOTICE: Thread LanguageInvoker start, auto delete: false
12:31:36 T:1525972464  NOTICE: Previous line repeats 4 times.
12:31:36 T:1525972464  NOTICE: Thread JobWorker start, auto delete: true
12:31:36 T:1526271136  NOTICE: Thread LanguageInvoker start, auto delete: false
12:31:36 T:1525972464  NOTICE: PVRManager - starting up
12:31:36 T:1526338512  NOTICE: Thread PVRManager start, auto delete: false
12:31:36 T:1527075360  NOTICE: Thread PVRClient start, auto delete: false
12:31:36 T:1483078960  NOTICE: void CApplication::UpdateLibraries(): Starting music library startup scan
12:31:36 T:1527055312  NOTICE: Thread MusicInfoScanner start, auto delete: false
12:31:36 T:1528441160  NOTICE: Thread LanguageInvoker start, auto delete: false
12:31:36 T:1483078960  NOTICE: Previous line repeats 1 times.
12:31:36 T:1483078960  NOTICE: initialize done
12:31:36 T:1483078960  NOTICE: Running the application...
12:31:36 T:1483078960   ERROR: int CScriptInvocationManager::ExecuteAsync(const string&, const AddonPtr&, const std::vector<std::basic_string<char> >&) - Not executing non-existing script script.skin.info.service
12:31:36 T:1528456736  NOTICE: Thread LanguageInvoker start, auto delete: false
12:31:37 T:1528868088  NOTICE: Thread JobWorker start, auto delete: true
12:31:37 T:1528868088 WARNING: static XFILE::IDirectory* XFILE::CDirectoryFactory::Create(const CURL&) - unsupported protocol(playmedia("pvr) in playmedia("pvr://channels/tv/Alle Kanäle/pvr.iptvsimple_1437684968.pvr"
12:31:37 T:1483078960  NOTICE: starting zeroconf publishing
12:31:37 T:1483078960  NOTICE: Webserver: Starting...
12:31:37 T:1529909928  NOTICE: Thread ZerocconfEmbedded start, auto delete: false
12:31:37 T:1483078960  NOTICE: WebServer: Started the webserver
12:31:37 T:1483078960  NOTICE: starting upnp client
12:31:37 T:1529429648  NOTICE: Thread JobWorker start, auto delete: true
12:31:37 T:1483078960  NOTICE: starting upnp server
12:31:37 T:1483078960  NOTICE: starting upnp controller
12:31:37 T:1483078960  NOTICE: starting upnp renderer
12:31:37 T:1483078960  NOTICE: ES: Starting event server
12:31:37 T:1528808384  NOTICE: Thread TCPServer start, auto delete: false
12:31:37 T:1529549400  NOTICE: Thread EventServer start, auto delete: false
12:31:37 T:1529549400  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
12:31:37 T:1529549400  NOTICE: UDP: Listening on port 9777
12:31:37 T:1483078960  NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
12:31:37 T:1483078960  NOTICE: GL_VENDOR = Broadcom
12:31:37 T:1483078960  NOTICE: GL_RENDERER = VideoCore IV HW
12:31:37 T:1483078960  NOTICE: GL_VERSION = OpenGL ES 2.0
12:31:37 T:1483078960  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
12:31:37 T:1483078960  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_debug_marker
12:31:37 T:1665235560  NOTICE: Thread AirPlayServer start, auto delete: false
12:31:37 T:1529429448  NOTICE: Thread MusicFileCounter start, auto delete: false
12:31:37 T:1527055312  NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
12:31:37 T:1525977360  NOTICE: -->Python Interpreter Initialized<--
12:31:37 T:1683432104  NOTICE: Previous line repeats 1 times.
12:31:37 T:1683432104  NOTICE: Thread FileCache start, auto delete: false
12:31:38 T:1528532760  NOTICE: Previous line repeats 1 times.
12:31:38 T:1528532760  NOTICE: 15
12:31:38 T:1526268416  NOTICE: -->Python Interpreter Initialized<--
12:31:38 T:1525972464  NOTICE: Previous line repeats 4 times.
12:31:38 T:1525972464   ERROR: CCurlFile::Open failed with code 404 for https://bitbucket.org/tcz009/theyidxxx/raw/master/addons.xml.md5
12:31:38 T:1525972464   ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://bitbucket.org/tcz009/theyidxxx/raw/master/addons.xml.md5>
12:31:38 T:1525972464   ERROR: Failed to fetch checksum for directory listing https://bitbucket.org/tcz009/theyidxxx/raw/master/addons.xml for repository repository.TheYidXXX.
12:31:38 T:1658126072  NOTICE: Thread FileCache start, auto delete: false
12:31:39 T:1526271136  NOTICE: Previous line repeats 1 times.
12:31:39 T:1526271136  NOTICE: -->Python Interpreter Initialized<--
12:31:39 T:1527075360  NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 197 channels.
12:31:39 T:1526269288  NOTICE: -->Python Interpreter Initialized<--
12:31:40 T:1525715872  NOTICE: script.grab.fanart: Grab Fanart Service Started
12:31:40 T:1528532760  NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.8.6
12:31:40 T:1528532760  NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup Start
12:31:41 T:1528532760  NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < '2015-11-15'
12:31:41 T:1528532760  NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup End
12:31:41 T:1653377392  NOTICE: Thread PVRGUIInfo start, auto delete: false
12:31:42 T:1702159936  NOTICE: Thread EPGUpdater start, auto delete: false
12:31:42 T:1526338512  NOTICE: virtual void EPG::CEpgContainer::Start() - EPG thread started
12:31:42 T:1702159936  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG file path is not configured. EPG not loaded.
12:31:45 T:1526269288  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
12:31:45 T:1526269288  NOTICE: script.tv.show.next.aired: ### no prior data found
12:31:46 T:1528441160  NOTICE:  StorageServer Module loaded RUN
12:31:46 T:1528441160  NOTICE: StorageClient-2.5.4 Starting server
12:31:48 T:1528868088  NOTICE: VideoInfoScanner: Starting scan ..
12:31:48 T:1528868088  NOTICE: WakeOnAccess [10.10.10.254] trigged by accessing : smb://10.10.10.254/USBDisk1_Volume1/
12:31:48 T:1528868088  NOTICE: WakeOnAccess success exit, server already running
12:31:48 T:1526269288  NOTICE: script.tv.show.next.aired: ### starting data update
12:31:49 T:1525972464   ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
12:31:49 T:1525972464   ERROR: CCurlFile::Open failed with code 0 for http://xty.me/xunitytalk/addons/addons.xml.md5
12:31:49 T:1525972464   ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://xty.me/xunitytalk/addons/addons.xml.md5>
12:31:49 T:1525972464   ERROR: Failed to fetch checksum for directory listing http://xty.me/xunitytalk/addons/addons.xml for repository repository.xunitytalk.
I tried it one more time with a little time gap to see clearly what he is doing since I pressed "
12:49:29 T:1483402448  NOTICE: Thread JobWorker start, auto delete: true
12:49:29 T:1483402448  NOTICE: VideoInfoScanner: Starting scan ..
12:49:29 T:1483402448  NOTICE: WakeOnAccess [10.10.10.254] trigged by accessing : smb://10.10.10.254/USBDisk1_Volume1/
12:49:29 T:1483402448  NOTICE: WakeOnAccess success exit, server already running
Same here. You find a solution, yet?
Greetings from germany, too. Wink
Sorry for doublepost. But I think I've got it.
Kodi has really big problems with SMB sharing. Configured my NAS as an ftp server and so: voilá works.
