Full Version: OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
New OpenELEC Krypton build #0310: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.5 #1 Thu Mar 10 21:26:31 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Mar  9 2016 18:15:17
Copyright (c) 2012 Broadcom
version 3a754304b032a5298ee7889b179c667bbc75dec5 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160310212539-#0310-g0de0a2a [Build #0310]
# vcdbg log msg 2>&1 | grep DTOK
002464.439: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (0de0a2a8, changelog) and tip of XBMC master (f3c7163a, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Includes latest bcm2835-driver master (8b4e5482, ahead +3)
  • Includes latest dcadec master (0e074384, ahead +139)
  • Includes latest kodi-platform master (92583ef9, ahead +2)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (eebe56ce, ahead +10)
  • Includes latest p8-platform master (38343e0a)
  • Includes latest addons: pvr.argustv (c05bf4ff, +23), pvr.demo (807cb2e2, +18), pvr.filmon (188ef9ab, +25), pvr.hdhomerun (4f3a3949, +30), pvr.hts (0814da42, +55), pvr.iptvsimple (d4fcb214, +25), pvr.mediaportal.tvserver (5815d770, +50), pvr.mythtv (44df4430, +25), pvr.nextpvr (d41be111, +25), pvr.njoy (af1d68ea, +17), pvr.pctv (f60f00a9, +23), pvr.stalker (91074ad3, +21), pvr.vbox (329fd13d, +25), pvr.vdr.vnsi (33390a99, +24), pvr.vuplus (135f1b03, +21), pvr.wmc (f0c62cfc, +30)
  • Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
  • Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 2f83a1cf: xf86-video-intel: bump to 8b8c9a36 (fixes segfault when refreshrate changing)
  • Include [env] 3a6268c9: VAAPI: Enable EGL
  • Include [env] 6f87cdbb: xf86-video-intel: bump to d167280
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] 858f6461: xf86-video-intel: bump to 371219c
  • Include [env] compare: ffmpeg: Additional Jarvis 2.8.x patches
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Clean Kodi view cache on startup
  • Include [env] patch: Enable other binary addons
  • Include [env] patch: Reinstate version check service add-on - avoid black screens on x86?
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: Add experimental splash video
  • Include [env] PR:4500: kodi: update to 17.0
  • Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
  • Include [env] PR:4661: stripping changes
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] PR:59: PVR API 5.1.0 (pvr.mythtv)
  • Include [pkg] PR:206: PVR API 5.1.0 (pvr.hts)
  • Include [pkg] PR:7030: CNetwork - implement IPv6
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8723: Implement filecache retry logic
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9317: Skin.SelectBool() - allow skins to set header label
  • Include [pkg] PR:9318: Fix MySQL issues with drop index syntax and case sensitivity on table name
  • Include [pkg] PR:9319: [PVR] Separate TV and Radio recordings
Build Highlights:
  1. NOTE: DVD playback remains temporarily disabled
  2. New 4.4.5 kernel
  3. New MusicDB schema v60
  4. Ensure all songs and albums have an artist - should improve query performance
  5. Estuary skin updates
  6. PR:9319: [PVR] Separate TV and Radio recordings
Build Details:
  1. OpenELEC:
    • linux: update to linux-4.4.5 (PR:4837, 1 commit, 31 files changed)
    • Python fixes (PR:4833, 10 commits, 10 files changed)
  2. XBMC:
    • [videoplayer] Fix Blu-ray playback in menu mode after changes to stre… (PR:9311, 1 commit, 1 file changed)
    • Fix XBMC.vcxproj.filters after #9252 (PR:9310, 1 commit, 2 files changed)
    • Ensure all songs and albums have an artist (PR:9205, 3 commits, 11 files changed)
    • Application: Remove unused variable (PR:9315, 1 commit, 1 file changed)
    • "Fix" compiler warning about unused variable and remove null statements. (PR:9314, 1 commit, 1 file changed)
    • [Estuary] - skin sync (PR:9313, 1 commit, 51 files changed)
    • VideoPlayer: fix ffmpeg demuxer ParsePacket after changes to stre… (PR:9316, 1 commit, 1 file changed)
  3. newclock5:
    • New commits in this build:
      • debug: Add mouse pointer logging (56666f1c)
      • ssif: comeback program management for BluRays (71ad56f0)
      • fixup! Revert supporting crappy tab/sbs subtitles. this fixes regular subtitles. (f4f530c2)
      • Revert "ssif: comeback program management for BluRays" (782d3c29)
    • Updated commits in this build:
    • Commits no longer in build:
      • CAdvancedSettings: add <glmipmapping> (bool) (ca3e2b99)
      • CGLTexture: perform trilinear filtering if enabled (484cff87)
      • squash: Fix mipmap generation for GL ES (d91716c5)
      • UI for toggling high quality picture downscaling (fece0537)
      • Minor correction (45dc5911)
      • Removing global mipmapping option (6056402e)
      • CBaseTexture: added mipmapping option (bd9dfc37)
      • CGLTexture: check object flag for mipmapping instead of advanced settings (32563ed9)
      • CGUIWindowSlideShow: set mipmapping if enabled in picture settings (c03f3842)
      • squash: Fix mipmap generation for GL ES pt2 (a6d493ce)
      • CBaseTexture: Removed parameter for SetMipmapping (091db604)
      • High quality downscaling moved to the slideshow category (rendering category axed) (08ccb99e)
      • CSlideShowPic: moved mipmapping activation from UI code to proper location (4d841322)
      • Fix Blu-ray playback in menu mode after changes to streamid. (4104f7e3)
  4. kernel 4.4.y:
      • BCM270X_DT: rpi-display overlay - add swapxy param (418177e2)
      • Add blk_pos parameter to mmc multi_io_quirk callback (462591cf)
      • FIXUP BCM270X_DT: "random" (HWRNG) dtparam default is on (232754cb)
      • BCM270X_DT: Disable DMA for bcm2835-sdhost on Pi2 (6dcfc3da)
      • FIXUP: Overlay README - Restore spaces deleted in error (d32795d2)
      • Revert "BCM270X_DT: Disable DMA for bcm2835-sdhost on Pi2" (14e35b8c)
      • Revert "Add blk_pos parameter to mmc multi_io_quirk callback" (d2943c4e)
      • FIXUP: BCM270X_DT: Update to latest Pi3 DTS (52015bd5)
      • Merge pull request #1329 from pelwell/sdhost4.4 (4f7b097a)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: Clean Kodi view cache on startup
    • Added: [pkg] PR:9317: Skin.SelectBool() - allow skins to set header label
    • Added: [pkg] PR:9318: Fix MySQL issues with drop index syntax and case sensitivity on table name
    • Added: [pkg] PR:9319: [PVR] Separate TV and Radio recordings
(2016-03-10, 19:50)arnoldjan Wrote: [ -> ]using Krypton build #0309 and Estouchy skin on RPI3,
I notice the button to turn the system off is not working, not that I need it though :-)
Did the button to turn the system off work in the previous skin (I think it was called "Retouched")?
As Estuary and Estouchy are both new, under heavy development and looking for feedback in their respective forums it might be worth posting in the Estouchy release thread if you find problems with either skin (Estuary has it's own bug thread).
(2016-03-10, 19:50)arnoldjan Wrote: [ -> ]The Stereo upmix does not work on my system.
I also have a Windows KODI and on that system de Stereo upmix works fine.
Is it somewhere in my system or settings? Or is it a shortcomming in the RPI Openelec version?
It would be great to get it working.
I'll ask the obvious question - have you enabled "Stereo upmix" in Settings > System > Audio output? The default is disabled, and it requires your settings level to be Advanced or Expert before you can change it.
(2016-03-10, 22:16)Milhouse Wrote: [ -> ]
(2016-03-10, 20:08)max30 Wrote: [ -> ]Im still having trouble with transmission service...from repositories I can install version 6.0.0..but im not able to connect to WEB interface. Is the version correct with this build?
Thanks for the help
6.0.0? No, probably not. Try installing the updated Transmssion addon I provide from the add-ons download area. Try that version, if it doesn't work I'll upload a new version later this evening.
Thanks Milhouse, the new version is better Smile, I can acess the web page..setup download dir to external USB, but for some reason it still downloads to SD card instead. I can provide some logs, if you point me to correct ones.
(2016-03-11, 00:57)Milhouse Wrote: [ -> ]
Yes in Retouched in worked.. I think... I load an old image tonight to ensure
Yes :-) i have
Continuation from post number 1500....
Updated to #310 and started to navigate, slowly, through photos. This time the sound distortion occurred when browsing the photo folder of jpgs "car accident 2011".
The log files are uploaded here....
https://www.dropbox.com/s/leyzbvn1qv14d1...7.zip?dl=0
.....the white noise sound distortion continues until the Pi is rebooted. All the defaults as previously noted apply.
EDIT: I tried again with HDMI audio and the USB sound stick removed. This time after several seconds of browsing the Pi paused and after a little while the screen went black, it was unresponsive. Then the Pi rebooted.
I had debugging enabled and hopefully it might be of use....?
https://www.dropbox.com/s/anzpc9tc97tk7e...d.zip?dl=0
(2016-03-11, 11:39)Vimes Wrote: [ -> ]Updated to #310 and started to navigate, slowly, through photos. This time the sound distortion occurred when browsing the photo folder of jpgs "car accident 2011".
Can you disable "Use GPU for jpeg acceleration" in video/acceleration settings and check if the failure still occurs?
When I get back home I will remove the video acceleration for jpg files and test it out. I'll report back.
I tried without the video acceleration for jpg's but sadly the sound distortion is still present.
A problem is because I updated to Kodi 17 almost right away I do not know if the issue is present within build 6.0.3 of OE.
Dropbox files of debugging....
https://www.dropbox.com/s/xp2lllgqjw6m5t...3.zip?dl=0
Ok I quiclkly formatted another card and loaded build 6.0.3 of OE onto it and then browsed the same jpg files.
As yet they have been perfect with no sound distortion.
Dropbox debugging info.....
https://www.dropbox.com/s/kff28ubds9x6kt...6.zip?dl=0
not sure if this means anything but when skipping from jpg to jpg the CPU usage (Kodi-CPU) was much lower than with these test builds of Kodi 17.
For example see this photo.....
http://s25.postimg.org/7fo8b8osf/2016031...00_HDR.jpg
where it shows the CPU-Kodi that was often near to and over 100 rather than being low.
I will keep testing later with 6.0.3
(2016-03-11, 09:09)max30 Wrote: [ -> ]Thanks Milhouse, the new version is better Smile, I can acess the web page..setup download dir to external USB, but for some reason it still downloads to SD card instead. I can provide some logs, if you point me to correct ones.
Sorry no idea, not a Transmission on OpenELEC user. Sounds like it might be a mounting issue, permissions issue, or a Transmission issue (post in their support subforum).
I've run into an issue which might have been there for a while, but currently I'm running the latest build. When the music library is being scanned, I can't play any video files. They only play audio, no video.
(2016-03-11, 17:40)jvandenbroek Wrote: [ -> ]I've run into an issue which might have been there for a while, but currently I'm running the latest build. When the music library is being scanned, I can't play any video files. They only play audio, no video.
A debug log (wiki) and identifying the first build that has this issue would be useful.
Gentlemen, I got my first Pi 2 about a month ago and I have to say I'm rally impressed and I appreciate the work everybody is doing here.
Couple of things on my side. I like the old skin Confluence better then new Estuary. It's like looking at Windows 8 tiles on the start screen rather then organised start menu in Windows 7 or 10. It's probably OK for smaller phone and tablet when using fingers but with larger screen or projector Estuary looks bulky.
Going back to Confluence skin I see couple of issues. One was already pointed out by "parcel" in post: #1488. Audio video buttons don't work in movie player screen. There is no way to select different audio track unless you change the skin to Estuary.
Second is the codecs display option. Since March updates we have this stripped down version of Codecs info with bulky fonts. I hope you have plans to reinstall original codecs info with all the details about the audio and video.
(2016-03-11, 20:18)3DBuff Wrote: [ -> ]Gentlemen, I got my first Pi 2 about a month ago and I have to say I'm rally impressed and I appreciate the work everybody is doing here.
As far as these builds are concerned Confluence is now a "third-party" skin, just like Aeon Nox. You'll need to post in the Confluence support forum if you have Confluence problems. There are no plans to include any further Confluence changes in these builds.
New OpenELEC Krypton build #0311: RPi / RPi2
# uname -a
Linux rpi512 4.4.5 #1 Fri Mar 11 21:37:01 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Mar  9 2016 18:15:17
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160311213608-#0311-g0de0a2a [Build #0311]
002481.325: Kernel trailer DTOK property says yes
Based on tip of OpenELEC master (0de0a2a8, changelog) and tip of XBMC master (f8eefddf, changelog) with the following modifications:
  • Includes latest addons: peripheral.joystick (af822765, +47), pvr.argustv (c05bf4ff, +23), pvr.demo (807cb2e2, +18), pvr.filmon (188ef9ab, +25), pvr.hdhomerun (4f3a3949, +30), pvr.hts (1ec85548, +59), pvr.iptvsimple (d4fcb214, +25), pvr.mediaportal.tvserver (5815d770, +50), pvr.mythtv (44df4430, +25), pvr.nextpvr (d41be111, +25), pvr.njoy (af1d68ea, +17), pvr.pctv (f60f00a9, +23), pvr.stalker (91074ad3, +21), pvr.vbox (329fd13d, +25), pvr.vdr.vnsi (2431fa48, +25), pvr.vuplus (135f1b03, +21), pvr.wmc (f0c62cfc, +30)
  • Include [env] patch: kodi: peripheral.joystick binary addon
  • Include [pkg] patch: Enable game controllers in manifest
  • Include [pkg] PR:9327: [guilib] introduce reusable expression definitions
Build Highlights:
  2. Controller input (PR8807) merged (although disabled for some reason)
Build Details:
  1. XBMC:
    • Fix MySQL issues with drop index syntax and case sensitivity on table name (PR:9318, 1 commit, 1 file changed)
    • [gui] add contextmenu to rule list in playlisteditor (PR:9304, 1 commit, 2 files changed)
    • [gui] add container.viewcount (PR:9309, 1 commit, 6 files changed)
    • [videoplayer][demuxer] Add multi source input stream/demuxer (PR:9286, 6 commits, 26 files changed)
    • Tls fix (PR:50, 22 commits, 31 files changed)
    • Controller input (PR:8807, 44 commits, 238 files changed)
    • Update win32 installer with inputstream and Peripheral addons (PR:9321, 2 commits, 2 files changed)
    • [adsp] fix kodi frezze if no add-on present (PR:9326, 1 commit, 1 file changed)
  2. pvr.hts:
    • Implement PVR API 5.1.0 (PR:206, 4 commits, 6 files changed)
  3. pvr.vdr.vnsi:
    • add Admin.xml for skin estuary (PR:62, 1 commit, 1 file changed)
  4. newclock5:
      • fixup! [omxplayer] Add ability to dump out audio/video data for later debugging (09ab0ecd)
      • VideoPlayer: update selectionstreams when stream parameters changes (24b27a30)
      • VideoPlayer: fix ffmpeg demuxer ParsePacket after changes to streamid (048bdb41)
  5. kernel 4.4.y:
      • Remove I2S config from bt_pins. (83f89bc8)
      • Merge pull request #1340 from DigitalDreamtimeLtd/rpi-4.4.y (4cd54bac)
  6. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: kodi: peripheral.joystick binary addon
    • Updated: [pkg] patch: Enable game controllers in manifest
    • Added: [pkg] PR:9327: [guilib] introduce reusable expression definitions
