It seems that each time I stop a video playback the stop button sound (click) is heard much louder than the actual volume level setting. After that the sound level is OK.
(2016-03-14, 14:24)popcornmix Wrote: [ -> ]Not known. Is it only photos, or do you get issues when browsing through movies/TV shows (which also does a lot of gpu jpeg decode).
Is the USB disk necessary for the probem? Can you reproduce with photos stored on sdcard or network?
Are you talking about HDMI, analogue, SPI or USB audio?
If this is a new problem then identifying the first build with the issue would provide the best chance of fixing it.
I only observe those issues while (quickly) browsing through photos. They also occur from photos on the sdcard, so no USB problem. Audio is over HDMI. I'll try older builds soon.
New OpenELEC.tv Krypton build #0314:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.5 #1 Mon Mar 14 22:06:10 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Mar 9 2016 18:15:17
Copyright (c) 2012 Broadcom
version 3a754304b032a5298ee7889b179c667bbc75dec5 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160314220202-#0314-g0026734 [Build #0314]
# vcdbg log msg 2>&1 | grep DTOK
002468.127: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC.tv master (0026734b,
changelog) and tip of
XBMC master (f8afd188,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest bcm2835-driver master (8b4e5482, ahead +3)
- Includes latest dcadec master (0e074384, ahead +139)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (eebe56ce, ahead +10)
- Includes latest p8-platform master (38343e0a)
- Includes latest addons: peripheral.joystick (af822765, +47), pvr.argustv (c05bf4ff, +23), pvr.demo (32ef5073, +19), pvr.filmon (188ef9ab, +25), pvr.hdhomerun (4f3a3949, +30), pvr.hts (1ec85548, +59), pvr.iptvsimple (d4fcb214, +25), pvr.mediaportal.tvserver (5815d770, +50), pvr.mythtv (b9dd8762, +29), pvr.nextpvr (d41be111, +25), pvr.njoy (af1d68ea, +17), pvr.pctv (f60f00a9, +23), pvr.stalker (91074ad3, +21), pvr.vbox (329fd13d, +25), pvr.vdr.vnsi (902a3cd1, +30), pvr.vuplus (135f1b03, +21), pvr.wmc (f0c62cfc, +30)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 3a6268c9: VAAPI: Enable EGL
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] compare: ffmpeg: Additional Jarvis 2.8.x patches
- Include [env] patch: Enable game controllers in manifest, add repository.kodi.game
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Add support for dynamic device tree overlays
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: Enable other binary addons
- Include [env] patch: Reinstate version check service add-on - avoid black screens on x86?
- Include [env] patch: Add experimental splash video
- Include [env] patch: kodi: peripheral.joystick binary addon
- Include [env] PR:4500: kodi: update to 17.0
- Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] PR:4661: stripping changes
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8723: Implement filecache retry logic
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9334: [chg] decrease volume steps to 20
- Include [pkg] PR:9343: [xbmc] [gui] fix media source workarounds
- Include [pkg] PR:9348: [xbmc] [PVR] Misc performance improvements for PVR windows
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- Switch to dynamic device tree overlays (link)
- New VideoDB schema v104
Build Details:
- OpenELEC.tv:
- Package updates (PR:4840, 14 commits, 20 files changed)
- tools/mkpkg: add script to get and repack RTL8812AU
- RTL8812AU: update to RTL8812AU-9fc227c
- openssh: update to openssh-7.2p2
- libdvbcsa: update to libdvbcsa-f988715, add script to get and repack sources
- projects/RPi*/linux: enable CONFIG_POWER_RESET, CONFIG_POWER_RESET_GPIO, CONFIG_POWER_RESET_GPIO_RESTART and CONFIG_POWER_RESET_RESTART, this should fix #4812
- xf86-video-intel: update to xf86-video-intel-0204e55, add mkpkg script to get and repack sources
- ncurses: update to ncurses-6.0
- libdvbcsa: dont build with LTO support
- dbus: update to dbus-1.10.8
- xorg-server: update to xorg-server-1.18.2
- videoproto: update to videoproto-2.3.3
- llvm: update to llvm-3.8.0
- cmake: update to cmake-3.5.0
- expat: update to expat-2.1.1 (dc4107cb)
- RTL8188EU: update to RTL8188EU-ced2b64, add script to get and pack sources (0026734b)
- XBMC:
- [videoplayer] InputStreamMultiSource: Fix Control flow issues (DEADCODE). (PR:9349, 1 commit, 1 file changed)
- Fix missing space in GetFilter SQL string (PR:9338, 1 commit, 1 file changed)
- add library.inputstream to CMakeLists.txt (PR:9331, 2 commits, 2 files changed)
- Set the duration on the tvshow object (PR:9212, 2 commits, 5 files changed)
- [VideoPlayer] Avoid to re-create renderer if it supports current form… (PR:9354, 1 commit, 4 files changed)
- inputstream: pass lib folder to addon (PR:9353, 3 commits, 5 files changed)
- [gui] refactor string and integer comparison boolean conditions (PR:9345, 1 commit, 2 files changed)
- make URIUtils::GetDirectory persistent while calling Inputstream::Op… (PR:9355, 1 commit, 1 file changed)
- [PVR] Separate TV and radio recordings: Fallback: If addon does not s… (PR:9356, 1 commit, 1 file changed)
- [cosmetic] Fix c/p errors for peripheral add-on callbacks (d803cb26)
- pvr.mythtv:
- PVR API 5.1.0 (PR:59, 4 commits, 5 files changed)
- newclock5:
- New commits in this build:
- fixup! logging: Add microsecond timer to log messages (ecd82fa8)
- cmake: Fix addon-bindings paths (b13ad878)
- overlayrenderer: Avoid null access (01cdd579)
- Commits no longer in build:
- VideoPlayer: fix DemuxClient after work on stream ids (0590679a)
- cmake: Add patches for ffmpeg (188ff0ee)
- kernel 4.4.y:
- dts, kbuild: dtbs_install installs .dtbo files too (06f658e1)
- Added: [env] patch: Add support for dynamic device tree overlays
hi there, anyone managed to get this running in 4k resolution?
(2016-03-15, 01:19)elroy1 Wrote: [ -> ]hi there, anyone managed to get this running in 4k resolution?
Nope. Pi doesn't support 4K.
(well it can just about drive the resolution, but it's too much to decode video at that resolution).
Hey!
Since a few 8.0 builds (I think around #0311), when I try to play a recorded TV programs using the TVHeadEnd PVR client, the "please wait" circle appears and Kodi becomes unresponsive. Watching live channels works fine, this only applies to recordings. I already tried resetting OpenELEC to system defaults.
I can restart Kodi via SSH, but if I don't do that, the PI freezes completely after about 20 seconds of "circle rotation".
The latest 7.0 does not exhibit this issue, neither do the first few 8.0 builds.
Even though I back up once a week to a separate drive on my network it seems that I cannot even restore at this point. After going to build 313 this has happened. I am wondering if it is the SD card that has become corrupt. Looks like I will have to start from scratch. I am able to boot up but after about 30 seconds mouse goes dead. I also notice my resolution is not set the same either. Any ideas on how to maybe backup or prevent this again? Thanks.
Similar to Loc2262, 0314 is still broken for playing back recorded TV and live TV continues to work fine. I'm using mythtv.
A follow up to the sound problems with the audio extractor....
I have found that non DTS or DD files will play fine as there is no "switch" to the DTS or DD needed.
In all the other log files posted I used two films as examples "300" as it has a DTS soundtrack and "A beautiful Mind" as it has a DD soundtrack.
If I play these files with build 314 (like all the others of these builds) there will be no DTS or DD sound heard. The Amp is showing no digital source.
BUT.....
If, whilst the film is playing I bring up the info for the film and select the settings and then"Audio and Subtitle Settings" and then flip the "Enable Passthrough" to off and then after a second back to on I then get a digital signal and sound is fine BUT it is not noted as DTS but simply "Digital".
When playing with OSMC (Kodi 16) or OE 6.0.3 (Kodi 15.2) all is perfect with DTS Digital being shown.
Next film.... A beautiful Mind with DD
Because this also has another sound track as well as DD I initially get sound but not DD. The amp shows "No Digital Data" however if I repeat the steps above by flipping off and then on the passthrough I will then get a Digital signal and all is well.
Log files when I do this.....
https://www.dropbox.com/s/jp330teck3v3wd...4.zip?dl=0
as noted OSMC and OE are both perfect and identify and play DTS and DD with no issues.
The issues are only with Kodi 17 builds.
If I play any material with DTS or DD sound I need to do the above if I use Kodi 17 but not any other.
Hope the above helps
(2016-03-15, 10:48)Vimes Wrote: [ -> ]A follow up to the sound problems with the audio extractor....
Identifying the first Milhouse build with this issue would be useful.
Might be worth trying the hdmi_audio_config options from
here.
With the change to dynamic device tree overlays does anything need to be changed with the dtoverlay=sdtweak,overclock50=100 command in config.txt?
(2016-03-15, 15:07)Trixster Wrote: [ -> ]With the change to dynamic device tree overlays does anything need to be changed with the dtoverlay=sdtweak,overclock50=100 command in config.txt?
In general no changes need. There are a few special cases (use of white space, or unnecessary use of "-overlay") but generally no changes needed.
See
here for more info.
Just noticed something odd. Got a RPi3 and noticed that when in suspend mode the temperature of the cpu ramps up. With a copper heatsink it sits at about 82 degrees Celsius (monitored through terminal). Once unit leaves suspend the temperature drops back down to about 65 degrees celsius. I've only tested on the latest build 0314.
