(2016-04-03, 19:02)fredlox Wrote: [ -> ]Hello,
I use an old version of your Testbuild (15.0 from september 2015)
I wanted to use a newer version but this one no longer include ALSA ? (I use squeezelite player too on this RPI)
Which is the lastet build with ALSA ?
ALSA is still included in the latest builds
# aplay --version
aplay: version 1.1.0 by Jaroslav Kysela <
[email protected]>
(2016-04-03, 18:55)popcornmix Wrote: [ -> ] (2016-04-03, 17:31)Kiralina Wrote: [ -> ]For ex., opening a blu ray file from my smb took 0 04 31, another mkv file 0 04 38, also from smb.
Need to measure with both OE and LE to determine if it is actually faster.
RPI3 LE:
startup sound at 15s, Live-TV VDR ready at 18s
RPI3 OE:
startup sound at 17s, Live-TV VDR ready at 20s
For test I only replace "kernel.img" and "SYSTEM" between LE and OE
Start time for video playback from SMB, same file, 2 identical microsd cards. (RP3)
LE #0403 4,31-4,40 sec.
OE #0402 4,55-4,63 sec.
(2016-04-02, 13:26)popcornmix Wrote: [ -> ]It's rather more complicated than just bitrate. We can play some 10Mbit/s HEVC which is very high for HEVC (with it's higher compression rates).
But it is possible to produce a 1Mbit/s stream we can't play.
I attempted to do some google research between ffmpeg 2.8.x and 3.0.x and came up empty.
Currently I am on the latest nightly with the ffmpeg 2.8.6 branch, is that anything 3.0.1 in the newer nightly builds might help?
I was planning to wait a few days for the newer bugs to be worked out before updating.
(2016-04-03, 20:30)herrmeier01 Wrote: [ -> ]For test I only replace "kernel.img" and "SYSTEM" between LE and OE
That should probably suffice - since for now kodi is build with same parameters....
So very interesting - would also like to see tests of utilization of the CPU (and the effect on clock throttling - mine (RPI2) is running in the high "too much"....
But for me - the only times it really feels slow, is opening the movies library (also when returning from movie playback to the library). Would be nice to see that benchmarked..
(I am running from a very fast USB stick)
(2016-04-03, 22:07)J_E_F_F Wrote: [ -> ] (2016-04-02, 13:26)popcornmix Wrote: [ -> ]It's rather more complicated than just bitrate. We can play some 10Mbit/s HEVC which is very high for HEVC (with it's higher compression rates).
In "a few days" some of the old bugs would be gone... But others could appear. These are not "stable" builds, and it will take some time before they are there......
With that in mind. They are actually quite stable! You could find some builds being more problematic - but most are quite good. Currently I use v403 as "my daily driver" - and it is actually not that bad
(for me TV is buggy with the Estuary skin, but perfect with Rapier, which anyway is my preferred... So all good
(2016-04-02, 06:07)parcel Wrote: [ -> ] (2016-04-01, 22:30)niwa2 Wrote: [ -> ]I just updated from 0224 to 0331 because the confluence skin got messed up today (no transparencys are shown anymore, just black squares). The same ist still happenening with 0331.
I got same problem on confluence skin. No special error messages on log.
The problem with TexturePacker on the server is fixed and Confluence has been updated to 3.0.7 so you should be able to update to a working Confluence.
New OpenELEC.tv Krypton build #0403:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.6 #1 Sun Apr 3 21:52:20 BST 2016 armv6l GNU/Linux
# vcgencmd version
Mar 24 2016 12:49:34
Copyright (c) 2012 Broadcom
version e16cd015026a8bda22bb50dc30b30ce07f52a202 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160403215124-#0403-g0026734 [Build #0403]
# vcdbg log msg 2>&1 | grep DTOK
002484.726: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC.tv master (0026734b,
changelog) and tip of
XBMC master (02e2e021,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest bcm2835-driver master (046effa1, ahead +10)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (3c26ce1e, ahead +13)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (5cf12e83, +7), adsp.biquad.filters (af575f3d, +7), adsp.freesurround (6dc533be, +8), asplib (da66f517, +13), inputstream.mpd (6bd24f3f), peripheral.joystick (76b7c40a, +48), pvr.argustv (974820ab, +25), pvr.demo (e74822f2, +21), pvr.dvblink (82c7b4d5, +20), pvr.dvbviewer (6ab861fa, +33), pvr.filmon (0d8dd5bd, +27), pvr.hdhomerun (fd9daf4a, +32), pvr.hts (0f88a357, +67), pvr.iptvsimple (b741cac7, +27), pvr.mediaportal.tvserver (96f415e3, +52), pvr.mythtv (f8d25fda, +36), pvr.nextpvr (d445c5ad, +27), pvr.njoy (b9b0ae43, +19), pvr.pctv (f1880484, +25), pvr.stalker (14a7c70d, +28), pvr.vbox (e70146d8, +27), pvr.vdr.vnsi (b64e7b4c, +43), pvr.vuplus (d8c6f9ba, +23), pvr.wmc (898e2dad, +33)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Exclude [env] kodi-999.42-KEY_EPG.patch: Added upstream
- Exclude [env] package.mk: dcadec: Drop (not needed anymore)
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 3a6268c9: VAAPI: Enable EGL
- Include [env] 6be9ebe7: libva / libva-driver-intel: bump to 1.7.0
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] 20965d0a: mesa: update to 11.2.0-rc4
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: Fix OE settings button after Estuary update
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Add support for dynamic device tree overlays
- Include [env] patch: Set default volume steps to 20
- Include [env] patch: Enable game controllers in manifest, add repository.kodi.game
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: Enable other binary addons
- Include [env] patch: Reinstate version check service add-on - avoid black screens on x86?
- Include [env] patch: Update inputstream.mpd settings
- Include [env] patch: Install dtoverlay userland
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Binary-Addons: Package inputstream.mpd
- Include [env] patch: kodi: peripheral.joystick binary addon
- Include [env] PR:4500: kodi: update to 17.0
- Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] PR:4661: stripping changes
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8723: Implement filecache retry logic
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9334: [chg] decrease volume steps to 20
- Include [pkg] PR:9535: [Builtins/Cec] add missing registrations
- Include [pkg] PR:9538: [Peripherals] m_bNeedsPolling broken for busses where it is set outsi?
- Revert [pkg] e9a6d59f: VideoPlayer: inputstream, fix cp error (Reason: inputstream.mpd needs update) (kodi)
- Revert [pkg] PR:9531: VideoPlayer: add method for requesting desired video resolution to demuxer (Reason: inputstream.mpd needs update)
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- A few small Kodi updates
Build Details:
- XBMC:
- [DVDVideoCodecOpenMax] update after d5f63a8 (PR:9539, 1 commit, 2 files changed)
- VideoPlayer: add method for requesting desired video resolution to de… (PR:9531, 1 commit, 12 files changed)
- [json] - add support for tvshow status (PR:9537, 1 commit, 2 files changed)
- [cmake] Add cmake parameter to BuildSetup.bat (PR:9529, 5 commits, 5 files changed)
- [python] add mediatype to setinfo for music (PR:9396, 1 commit, 4 files changed)
- [cmake] Fix android build (PR:9540, 2 commits, 1 file changed)
- [gui] - remove go-to-root context menu buttons (PR:9536, 1 commit, 6 files changed)
- [buildsystem][win32] Updated some more build files to vs2015 that was forgotten about (PR:9541, 1 commit, 4 files changed)
- VideoPlayer: inputstream, fix cp error (e9a6d59f)
- [lang][skin.estuary] updated language files from Transifex (da74385e)
- [lang][skin.estouchy] updated language files from Transifex (02e2e021)
- pvr.vdr.vnsi:
- [skin] adapt to recent include attribute renaming (PR:71, 2 commits, 1 file changed)
- Added: [pkg] PR:9538: [Peripherals] m_bNeedsPolling broken for busses where it is set outsi?
- Reverted: [pkg] e9a6d59f: VideoPlayer: inputstream, fix cp error (Reason: inputstream.mpd needs update) (kodi)
- Reverted: [pkg] PR:9531: VideoPlayer: add method for requesting desired video resolution to demuxer (Reason: inputstream.mpd needs update)
On 403 after suspend could not wakeup device.
Any ideas as to why films which are correctly tagged as being 3D, and were previous list in the list view with that label, are now showing as HD....?
Using the Estuary skin in the latest build and extra media information to be shown would normally list a 3D film as being 3D.
Example Avatar 2009 .3d.hsbs.mkv will now show as HD and not 3D.
I'm not sure which build this started to change sadly but I do know they were there as 3D in the list view on the right on the Window pane which shows media information.
(2016-04-04, 16:13)Vimes Wrote: [ -> ]I'm not sure which build this started to change sadly but I do know they were there as 3D in the list view on the right on the Window pane which shows media information.
Nothing immediately springs to mind, so identifying the first build with the issue would be useful.
(2016-04-04, 17:15)popcornmix Wrote: [ -> ] (2016-04-04, 16:13)Vimes Wrote: [ -> ]I'm not sure which build this started to change sadly but I do know they were there as 3D in the list view on the right on the Window pane which shows media information.
Now I'm back home I'll work my way through older builds until I find where it started.
