Full Version: OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
New OpenELEC.tv Krypton build #0408: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.6 #1 Fri Apr 8 21:06:05 BST 2016 armv6l GNU/Linux
# vcgencmd version
Apr  8 2016 20:16:32
Copyright (c) 2012 Broadcom
version e3bfc49ea56050dbe545ec3acfa5637b25464d5b (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160408210512-#0408-g0026734 [Build #0408]
# vcdbg log msg 2>&1 | grep DTOK
002469.247: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC.tv master (0026734b, changelog) and tip of XBMC master (a9cdf975, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Includes latest bcm2835-driver master (e968a4e7, ahead +14)
  • Includes latest kodi-platform master (92583ef9, ahead +2)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (3c26ce1e, ahead +13)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (5cf12e83, +7), adsp.biquad.filters (af575f3d, +7), adsp.freesurround (6dc533be, +8), asplib (da66f517, +13), inputstream.mpd (6bd24f3f), peripheral.joystick (76b7c40a, +48), pvr.argustv (974820ab, +25), pvr.demo (e74822f2, +21), pvr.dvblink (82c7b4d5, +20), pvr.dvbviewer (6ab861fa, +33), pvr.filmon (0d8dd5bd, +27), pvr.hdhomerun (fd9daf4a, +32), pvr.hts (0f88a357, +67), pvr.iptvsimple (b741cac7, +27), pvr.mediaportal.tvserver (96f415e3, +52), pvr.mythtv (f8d25fda, +36), pvr.nextpvr (d445c5ad, +27), pvr.njoy (b9b0ae43, +19), pvr.pctv (f1880484, +25), pvr.stalker (14a7c70d, +28), pvr.vbox (e70146d8, +27), pvr.vdr.vnsi (b64e7b4c, +43), pvr.vuplus (d8c6f9ba, +23), pvr.wmc (898e2dad, +33)
  • Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
  • Exclude [env] kodi-999.42-KEY_EPG.patch: Added upstream
  • Exclude [env] package.mk: dcadec: Drop (not needed anymore)
  • Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 3a6268c9: VAAPI: Enable EGL
  • Include [env] 6be9ebe7: libva / libva-driver-intel: bump to 1.7.0
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] 20965d0a: mesa: update to 11.2.0-rc4
  • Include [env] patch: xf86-video-intel: bump to 3fafabe
  • Include [env] patch: Clean Kodi view cache on startup
  • Include [env] patch: Fix OE settings button after Estuary update
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Add support for dynamic device tree overlays
  • Include [env] patch: Set default volume steps to 20
  • Include [env] patch: Enable game controllers in manifest, add repository.kodi.game
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: Enable other binary addons
  • Include [env] patch: Reinstate version check service add-on - avoid black screens on x86?
  • Include [env] patch: Update inputstream.mpd settings
  • Include [env] patch: Install dtoverlay userland
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: Binary-Addons: Package inputstream.mpd
  • Include [env] patch: kodi: peripheral.joystick binary addon
  • Include [env] PR:4500: kodi: update to 17.0
  • Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
  • Include [env] PR:4661: stripping changes
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8723: Implement filecache retry logic
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9334: [chg] decrease volume steps to 20
  • Include [pkg] PR:9538: [Peripherals] m_bNeedsPolling broken for busses where it is set outsi?
  • Revert [pkg] e9a6d59f: VideoPlayer: inputstream, fix cp error (Reason: inputstream.mpd needs update) (kodi)
  • Revert [pkg] PR:9531: VideoPlayer: add method for requesting desired video resolution to demuxer (Reason: inputstream.mpd needs update)
Build Highlights:
  1. NOTE: DVD playback remains temporarily disabled
  2. New firmware
  3. VideoPlayer: fix mem leak in subtitle processing (note: doesn't fix ASS memory leak) - reverted due to OSD Codec issue
Build Details:
  1. Firmware (Apr 8):
    • pwm_sdm: fix ring buffer UINT_MAX wraparound bug. See: link
    • firmware: IL ISP: Correct RGB to YUV matrices, and ignore code side info
    • firmware: MJPEG encode: Handle stereoscopic images. See: link
    • firmware: IL Camera: Change unspecified colour space to being JFIF. See: link
    • firmware: OV5647: Option to configure auto lens shading to use potential fix
    • firmware: arm_loader: Factor out DT support into arm_dt. See: link
    • firmware: arm_ldconfig: Switch to using arm stubs generated from tools/mkimage.
    • firmware: arm_ldconfig: Support loading arm stubs from file. See: link
  2. XBMC:
    • VideoPlayer: fix mem leak in subtitle processing (PR:9578, 1 commit, 4 files changed)
    • [utils] CMime: make parseMimeType() private (PR:9573, 1 commit, 1 file changed)
  3. newclock5:
    • New commits in this build:
      • Revert "VideoPlayer: fix mem leak in subtitle processing" (8b24590e)
      • VideoPlayer: make videoRefClock an object of DVDClock' (3695e8a7)
      • OMXPlayer: use SystemClock instead of DVDClock for a simple timer (ccaaa4d4)
      • fixup! VideoPlayer: move setting videoDelay from player to renderer (bdb5c941)
    • Commits no longer in build:
  4. kernel 4.4.y:
      • RPi config: Add CONFIG_PWM_PCA9685 for NXP PCA9685 driver over I2C (7ed2e70e)
      • Merge pull request #1398 from 6by9/PR20160407 (71ddb1c0)
      • BCM270X_DT: Don't generate "linux,phandle" props (a4e16ff5)
      • V4L2 driver updates (#1393) (5fe9c7b5)
(2016-04-09, 01:27)Milhouse Wrote: [ -> ]
  • VideoPlayer: fix mem leak in subtitle processing (note: doesn't fix ASS memory leak) - reverted due to OSD Codec issue
How come this commit got reverted? I was hoping to test it, I'm suffering from this memory leak :/ What's "OSC Codec issue" mean?
(2016-04-09, 14:23)Caesium Wrote: [ -> ]How come this commit got reverted? I was hoping to test it, I'm suffering from this memory leak :/ What's "OSC Codec issue" mean?
Read the comments in the related PR.
Gotcha, missed that. Thanks.
Audio offset (delay) works OK with this current build #0408 for both players MMAL and OMX.
Thanks guys Smile
This is really important when using direct analog outputs or HDMI audio extractors to small analog devices like headphones.
My Epson projector has extensive image processing taking about 200ms to display from the signal. Without ability to manually adjust the delay I have to run high current surround receiver just for 1 or 2 sets of headphones.
This is the case with PS3. There is no audio delay adjustment of any kind. When playing Blu-Rays, games or anything else audio has to go through full blown surround receiver for the headphones to get proper lip sync.
Something unstable started on my rpi3. I have occasional freezes and recorded reboot. Usually during menu paging and video playback. I also started using yatse together with mouse pointer.
(2016-04-09, 22:17)SpokV Wrote: [ -> ]Something unstable started on my rpi3. I have occasional freezes and recorded reboot. Usually during menu paging and video playback. I also started using yatse together with mouse pointer.
No idea without a debug log (wiki) or crashlog. Maybe try and identify the build when this problem started, or determine what changed in your system that coincided with the crashes starting - if you stop using Yatse do the crashes stop?
Hello all Smile
I first want to thank milhouse for his work and all people for support.
I have a silly question : when you write "NOTE: DVD playback remains temporarily disabled", are you talking about physical disc itself (with some external USB drive for example), or are you taking about ISO files created from a DVD ?
I have problems with some ISO files that are ok with openElec 9.5.2, and don't know if I have to try to troubleshooting or just have to wait the playback to be enabled again Big Grin
Thank you very much
#408 RPi 3, iso BD files still very slow (>1 minute typically) to start playing from an NFS sever (Synology) - other media players access and start playing same files in ~1 second.
(2016-04-10, 11:24)Sinisan Wrote: [ -> ]I have a silly question : when you write "NOTE: DVD playback remains temporarily disabled", are you talking about physical disc itself (with some external USB drive for example), or are you taking about ISO files created from a DVD ?
Thank you very much
Both. No idea what "OpenELEC 9.5.2" is, but DVD should be working in OE7 Betas as these are based on Kodi 16.
(2016-04-10, 12:04)Milhouse Wrote: [ -> ]
Thank you very much
Thank you for your help. Sorry for the mistake, it was sure 6.95.2.
I thought we were using kodi17 here ?
(2016-04-10, 11:59)eenjec Wrote: [ -> ]#408 RPi 3, iso BD files still very slow (>1 minute typically) to start playing from an NFS sever (Synology) - other media players access and start playing same files in ~1 second.
ISO files will always be much slower than mkv. An mkv file has an index at the start with all the important data.
An ISO file doesn't and a lot more data needs to be parsed to work out what needs to be done.
Try setting "Blu-ray playback mode" to "Play main movie" in video/discs settings, and also enable "attempt to skip introduction before DVD menu" if you use DVD ISOs.
(2016-04-10, 12:45)Sinisan Wrote: [ -> ]Thank you for your help. Sorry for the mistake, it was sure 6.95.2.
Yes the builds here are using Kodi 17, but OE7 is Kodi 16.
New OpenELEC.tv Krypton build #0409: RPi / RPi2
# uname -a
Linux rpi512 4.4.6 #1 Sat Apr 9 21:05:02 BST 2016 armv6l GNU/Linux
# vcgencmd version
Apr  8 2016 20:16:32
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160409210409-#0409-g0026734 [Build #0409]
002466.509: Kernel trailer DTOK property says yes
Based on tip of OpenELEC.tv master (0026734b, changelog) and tip of XBMC master (3283a64d, changelog) with the following modifications:
  • Includes latest addons: adsp.basic (5cf12e83, +7), adsp.biquad.filters (af575f3d, +7), adsp.freesurround (6dc533be, +8), asplib (da66f517, +13), inputstream.mpd (6bd24f3f), peripheral.joystick (76b7c40a, +48), pvr.argustv (974820ab, +25), pvr.demo (e74822f2, +21), pvr.dvblink (82c7b4d5, +20), pvr.dvbviewer (6ab861fa, +33), pvr.filmon (0d8dd5bd, +27), pvr.hdhomerun (fd9daf4a, +32), pvr.hts (0f88a357, +67), pvr.iptvsimple (b741cac7, +27), pvr.mediaportal.tvserver (96f415e3, +52), pvr.mythtv (f8d25fda, +36), pvr.nextpvr (d445c5ad, +27), pvr.njoy (b9b0ae43, +19), pvr.pctv (f1880484, +25), pvr.stalker (14a7c70d, +28), pvr.vbox (e70146d8, +27), pvr.vdr.vnsi (12364058, +44), pvr.vuplus (d8c6f9ba, +23), pvr.wmc (898e2dad, +33)
Build Highlights:
  2. Render updates
Build Details:
  1. XBMC:
    • fix 'add source' button after ae4fcd0 (PR:9579, 1 commit, 10 files changed)
    • clean up leftovers (PR:9581, 5 commits, 9 files changed)
    • VideoPlayer: init memeber m_textureId of CDVDOverlay (PR:9587, 1 commit, 1 file changed)
    • Porting fixes (PR:9492, 3 commits, 1 file changed)
    • [win32] VS2015 fix for libdvd (PR:9583, 1 commit, 4 files changed)
    • [win32] fix unit test environment (PR:9575, 2 commits, 2 files changed)
    • VideoPlayer: drop WaitPresentTime + simplify render loop (PR:9542, 12 commits, 69 files changed)
  2. pvr.vdr.vnsi:
    • drop DX9, rendering OSD on Windows requires DX11 (PR:72, 1 commit, 2 files changed)
  3. newclock5:
      • MMALRenderer: Block in RenderUpdate to avoid high CPU with WaitPresentTime commits (5751bb73)
      • MMAL: Increase GetAllowedReferences to allow larger queue in RenderManager (fbab8942)
      • fixup: Handle case where fps=0.0 with sync playback to display disabled (ef491091)
      • temp: MMALRenderer: Block in RenderUpdate to avoid high CPU with WaitPresentTime commits (e5f43b53)
      • MMALRenderer: return earlier when frames are already submitted frame is skipped (ddb47c04)
      • MMALRenderer: Wait for vsync after presenting (21329b9c)
      • VideoPlayer: drop WaitPresentTime (dd6c952f)
      • VideoPlayer: simplify video rednering (6a7c8aa9)
      • simplify render loop (dfee729c)
      • VidoePlayer: do not block renderthread if no gui was rendered and video is separate layer (bf4d35f1)
      • move FinishPipeline from application to gfx context (b1b96811)
      • rendering: skipping gui rednering should be independent from dirty (095373df)
      • VideoPlayer: move setting videoDelay from player to renderer (f18d7e70)
      • VideoPlayer: only check skipping if we render a frame, saves CPU (7f3bdba4)
I'm using #0409 and as you'll see from earlier in the thread I was having issues with TVHeadend (I've now raised on their forums). Anyway, in the meantime I have compiled the latest TVHeadend from source on Raspbian. That is now acting as my server (I'm testing to see if later builds have addressed the issue I was seeing whilst waiting for a response) but clearly has no completed items in the recording section just yet and no items to display.
I inadvertently pressed on the Recordings option in Estuary and got taken to a screen that showed 15 items on the right-hand side and and nothing on the left - I would have expected this. However, this then caused a complete crash of Kodi.
Logs are here:
kodi.old.log: http://sprunge.us/UACh
Crashlog: http://sprunge.us/FgZY
I wouldn't be able to say which build this started with, as I only did this accidentally. I normally watch the recordings on a tablet or laptop and not from the Kodi interface (they get stored on a NAS which I can access from these devices).
