(2016-01-28, 12:13)Milhouse Wrote: [ -> ]I have Yatse (v5.9.7) on my Nexus 7 2013 tablet although I don't use Yatse often so maybe I'm looking in the wrong place, however I can't see any problem as the progress bar (on the second panel, if you swipe from the right) appears to be displayed correctly and tapping on the progress bar seeks to the correct timestamp.
Can you describe the issue in detail - screenshots from the app (how it currently looks in latest build, and how it look with build #0122) would also help immensely.
OK,
When I start the movie, the progress bar on the mobile app shows for instance [0-10s] and then,
the upper limit of the progress bar is increasing as the movie is playing, so the progress bar shows after a few seconds : [0-15s] for instance.
If I want to go to timestamp 1H for instance, I can't ....
I will make screenshots of Yatse tonight with the same 3D BD ISO movie with builds #0122 and #0127 of Kodi to show you the behavior.
I notice that I don't have the problem with 2D BD ISO or mkv (even MVC 3D mkv).
Regards.
I'm sorry, but i have no chance on a BR-Rip to play the correct Audiochannels with the RPi2 in H264 -Videos [MPEG-4 AVC]
...possiple to play Audio-Codec MPEG AAC Audio (48khz) and chanels 3F2R/LFE ?
With vlc-mediaplayer this file plays correct in 5.1 from the PC over s/pdif to the Yamaha-Receiver.
With RPi2 this feature is unavailable.
Thanks for Your friendly answers.
Harald
Here is a screenshot (photo ..) of Kodi, which shows the same progress bar bug as the App.
As you see the start time is 00:01:55 and endtime is 00:01:59.
same bug with build #0123 and newer.
How should it look (what does it show in #0122)? Your screenshot doesn't appear to demonstrate a bug, unless the duration is not 00:01:59 but something else. The current position (00:01:55) looks about right, assuming the total duration is 00:01:59. Without knowing what the total duration should be, it's hard to see a problem.
By the way you can grab screenshots by pressing PrintScr on a keyboard, or "texturecache.py screenshot" in ssh - you'll then find the screenshots in the "Screenshots" folder.
Edit: I missed post #856, but still a screenshot from #0122 might be useful. Do you have any unusual advancedsettings.xml - can you upload a debug log from #0123 while playing this file? Is it only with this file/disk, or all 3D MVC ISO disks? I've tried reproducing here with two different 3D MVC ISOs, but failed.
New OpenELEC Krypton build #0128:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.0 #1 Thu Jan 28 21:55:11 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Jan 15 2016 17:31:09
Copyright (c) 2012 Broadcom
version 50b1ff57f80db9c96b78757d2d2cfc226ed71f93 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160128215418-#0128-g2500064 [Build #0128]
# vcdbg log msg 2>&1 | grep DTOK
001719.432: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (25000647,
changelog) and tip of
XBMC master (ff8b0087,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (0e074384, ahead +139)
- Includes latest kodi-platform master (cef3f526, ahead +1)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (d8274472, ahead +43)
- Includes latest p8-platform master (38343e0a)
- Includes latest addons: adsp.basic (598900a9, +2), adsp.biquad.filters (71087c48, +1), adsp.freesurround (990fee29, +2), asplib (2fac1bf3), pvr.argustv (74918d5a, +4), pvr.demo (a6f58c4e, +5), pvr.dvblink (6616a0bb, +4), pvr.dvbviewer (8a005dd8, +4), pvr.filmon (b80ced90, +4), pvr.hdhomerun (888f19e0, +4), pvr.hts (0b7c65cf, +17), pvr.iptvsimple (bd52b624, +7), pvr.mediaportal.tvserver (33d59732, +13), pvr.mythtv (bb00bf7b, +8), pvr.nextpvr (28490d18, +5), pvr.njoy (29881492, +3), pvr.pctv (a6974b23, +4), pvr.stalker (7fba39ff, +5), pvr.vbox (1326eca9, +4), pvr.vdr.vnsi (a67ae38b, +11), pvr.vuplus (aaada55a, +4), pvr.wmc (70001bd3, +4)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] f26415ab: libass: bump to 0.13.1
- Include [env] 3a6268c9: VAAPI: Enable EGL
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] 518f5e6f: FFmpeg: Bump to 2.8.5-Jarvis-rc1
- Include [env] 858f6461: xf86-video-intel: bump to 371219c
- Include [env] patch: xf86-video-nvidia: update to xf86-video-nvidia-352.79
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: ffmpeg: Drop unpack()
- Include [env] patch: Enable other binary addons
- Include [env] patch: Fixup 4653 on latest Kodi master
- Include [env] patch: [update] pvr.vuplus (thanks @seo)
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] PR:4500: kodi: update to 17.0
- Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] PR:4653: Pulseaudio update to 8.0 and switch back to AEPulseSink
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8822: Implement ignore url options in CFileItemList
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8872: videolibrary: support manually setting dateadded through NFO and JSON-RPC
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:8923: [GUI] Replace thumb size with images res
- Include [pkg] PR:8973: drop TimeSmoother
Build Highlights:
- Drop TimeSmoother
- Use updated Kodi17 pull request [wip]
Build Details:
- XBMC:
- Allow to parse only the details needed in videodb (PR:8906, 2 commits, 8 files changed)
- [PVR] Timer window: proper fix for trac1659 (actually fix for first fix attempt) (PR:8967, 1 commit, 1 file changed)
- [osx] - Fix crash when unplugging usb devices (PR:8956, 1 commit, 1 file changed)
- pvr.demo:
- Update to API 4.2.0 - Implement IsRealTimeStream() (PR:28, 2 commits, 2 files changed)
- pvr.hts:
- Extend automatic build tests to run on clang and OS X too (PR:178, 2 commits, 1 file changed)
- Updated to PVR API v4.2.0 (implemented IsRealTimeStream) (PR:179, 1 commit, 6 files changed)
- Add missing files to CMakeLists.txt (PR:181, 2 commits, 1 file changed)
- Timeshift: Seeking fixes (PR:155, 6 commits, 2 files changed)
- newclock5:
- New commits in this build:
- VideoPlayer: fix incorrectly determined audio sync error (9428191d)
- Updated: [env] PR:4500: kodi: update to 17.0
- Added: [pkg] PR:8973: drop TimeSmoother
This movie lasts more than 2 hours.
Here is the correct behavior, in build #0122 :
And here are the logs for #0123 whre the progress bar (on kodi and the mobile app) give wrong indications :
http://xbmclogs.com/paubzqpk9
I didn't modify advancedsettings.xml
Excuse me for being a total newbie. I have only had a pi2 for 48 hours and got it working perfectly except for not being able to play 3D isos. I understand I need latest test build for this. I understand how to do an install, but how exactly would I rollback to the stable build if I get any issues? Thanks in advance
you roll back in the same way as you upgrade - copy the tar file to the update folder. This at least works just fine as long as there haven't been any database changes. When there are DB changes, Kodi creates a new copy of the DB and bumps it's version. If you then install a Kodi version that requires a lower DB version, it will still work, but it will use the old DB file matching the required DB version. So depending on what you did in the meantime, these changes might be gone as they are only done in the new DB version. Same the other way around.
Thank you for such a quick response :-)
note that you can always just delete a certain db version and Kodi will automatically migrate the newest it can find to the DB version it currently needs. So if you tested a new version once but rolled back and plan to upgrade again some time later, Kodi would detect and use the already upgraded DB file from your test, but you can always delete that obsolete test version and have Kodi do the migration again
Thanks. I'll give it a go this evening.
I hope this makes my 3D isos play ok. The 3D Mkvs are perfect!
New OpenELEC Krypton build #0129:
RPi /
RPi2
# uname -a
Linux rpi512 4.4.0 #1 Fri Jan 29 21:18:46 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Jan 29 2016 13:52:31
version 75a32fd37768d64654506c3eaba453ecc3d587a6 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160129211754-#0129-g39c6a99 [Build #0129]
001746.676: Kernel trailer DTOK property says yes
Based on tip of
OpenELEC master (39c6a995,
XBMC master (e949c32a,
- Includes latest addons: adsp.basic (598900a9, +2), adsp.biquad.filters (71087c48, +1), adsp.freesurround (990fee29, +2), asplib (d8a34587, +8), pvr.argustv (74918d5a, +4), pvr.demo (32952941, +8), pvr.dvblink (6616a0bb, +4), pvr.dvbviewer (8a005dd8, +4), pvr.filmon (b80ced90, +4), pvr.hdhomerun (888f19e0, +4), pvr.hts (28d36137, +25), pvr.iptvsimple (baaae159, +11), pvr.mediaportal.tvserver (c620fcfa, +17), pvr.mythtv (da0a6f50, +11), pvr.nextpvr (28490d18, +5), pvr.njoy (29881492, +3), pvr.pctv (a6974b23, +4), pvr.stalker (7fba39ff, +5), pvr.vbox (1326eca9, +4), pvr.vdr.vnsi (894555c6, +14), pvr.vuplus (aaada55a, +4), pvr.wmc (70001bd3, +4)
- Include [pkg] PR:8937: [guilib] Add animated png support
Build Highlights:
- New firmware - improved RPi2 sdram overclocking (see forum post)
- AudioEngine updates
- Add animated PNG support (see PR:8937)
Build Details:
- Firmware (Jan 29):
- firmware: hdmi: Pass sequenced event through queue to avoid it being overwritten by hotplug change See: link
- firmware: H264_PWR: Increase max number of users. See: link
- firmware: platform: If gpu_freq is set don't set core_freq on pi0 as it might reduce frequency
- firmware: sdram: Avoid PVT calibration when overclocking sdram on pi2. See: link
- OpenELEC:
- Pulseaudio update to 8.0 and switch back to AEPulseSink (PR:4653, 5 commits, 8 files changed)
- XBMC:
- [gui] use history to save/restore selected item for media windows (PR:8969, 1 commit, 3 files changed)
- drop TimeSmoother (PR:8973, 1 commit, 11 files changed)
- [TexturePacker][gif] The Graphic Control Extension is optional. (PR:8971, 1 commit, 2 files changed)
- [depends] removed unused libssh2 (PR:8951, 1 commit, 3 files changed)
- [cleanup] wayland (PR:8980, 1 commit, 91 files changed)
- [PVR] Guide window: EPG grid: now even works if none of the available channels has EPG data (fixes trac#16548). (PR:8981, 1 commit, 1 file changed)
- [dx11] Fix: Properly handle DXGI_STATUS_OCCLUDED status, previous met… (PR:8984, 1 commit, 1 file changed)
- asplib:
- Travis ci linux support (PR:21, 2 commits, 3 files changed)
- Build Fixes (PR:22, 6 commits, 17 files changed)
- pvr.demo:
- Add travis.yml and gitignore (PR:29, 3 commits, 3 files changed)
- pvr.hts:
- Fix some potential threading issues in the demuxer (PR:180, 6 commits, 2 files changed)
- Update gitignore (PR:182, 2 commits, 2 files changed)
- pvr.iptvsimple:
- Add gitignore (PR:60, 2 commits, 2 files changed)
- add Travis-CI file (f0d9707f)
- Update README.md (7cdc3262)
- pvr.mediaportal.tvserver:
- Add travis.yml and update gitignore (PR:32, 4 commits, 4 files changed)
- pvr.mythtv:
- Add travis.yml and update gitignore (PR:55, 3 commits, 3 files changed)
- pvr.vdr.vnsi:
- Add travis.yml and gitignore (PR:55, 3 commits, 3 files changed)
- newclock5:
- AE: fix update of buffered time (after refactoring) (d33187e1)
- AE: fix number of provided buffers for PT (6e00bf97)
- AE fix endless loop after stream rework (906f29b2)
- AE: update resample ratio in GetStreamInfo (8207feea)
- AE: provide only limited buffers to input stream (e03574bb)
- Added: [pkg] PR:8937: [guilib] Add animated png support
Any chance of adding pvr.argustv I have not been able to use my pvr since #022
Unfortunately, "my" bug persists with this latest release.
If I am the only one to have this behavior, maybe I am using wrong parameters, but I kept exactly the same parameters as build #0122
which is perfect.
Nonetheless, I noticed a difference in audio label between post #858 screenshot made with build #0123 which is buggy : audio is marked as DTS 7.1
In post #861, screenshot made with build #0122 which is perfect, audio is marked as DTS Master Audio 7.1
Is my problem with the progress bar due to a bug in audio stream ?
