(2016-02-02, 16:34)polo_joe Wrote: [ -> ]with latest build I get no audio when watching livetv channels
debug log http://sprunge.us/NiKe
build 0131 was ok.
Switching for build #0129 to #0201 I also have no audio with SD or HD channels when playing Live TV
(TVHeadend frontend & backend running on Pi)
Standard log
http://sprunge.us/FQaL
My usual Video Add-ons and local stored video playback audio is working as normal
Good morning
I tested build #201, and I've had the following issues:
- With a 3D ISO BD file: movie starts in 3D after boot, but subsequent playback of a 3D ISO file results into the movie being played in 2D only
- 3D MKV of the same content seem fine, it always playback in 3D
- Seek is broken in both cases for me: if I try to seek back and forth, it hangs the playback. I can stop the playback then start again though, however in
Need to do more tests with audio playback as well, when using 3D ISO I had a very muffled sound, with the center channel and rear channels completely absent (I'm using 5.1 LPCM output, not passthrough)
(2016-01-31, 14:53)Quinn2015 Wrote: [ -> ]I have pinned down the last working build. It´s #105b.
I could watch the dvd without the MPEG-2 license key.
From #106, software decode is messed up.
Thanks for this. I can reproduce and it is caused by
PR:8773
Previously we request YADIF 1x for deinterlace which keeps up.
After the PR the requested deinterlace is not respected and we get YADIF 2x which doesn't keep up (with software decode).
FernetMenta is thinking about the best fix for this.
Why my kodi on pi dont see files thah have long dash in filename windows version see this files no not normal dash like - but someting like —
(2016-02-02, 23:25)popcornmix Wrote: [ -> ] (2016-02-02, 23:03)nalor Wrote: [ -> ]One last question for the moment: 'Enable Full HD HDMI modes for stereoscopic 3D' is activated in my settings - but my screenshots all look like top/bottom and the final picture size is only 1920x1080 although I expected them to be 2 times this size. (I've created the screenshots with the ssh command 'texturecache.py screenshot')
Is this correct as it is?
On the screen everything looks perfect
What does "tvservice -s" report when playing 3D video?
Directly after the start of a video it says:
Quote:state 0x12000a [HDMI CEA (16) 3D SbS RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
and ~3 seconds later it switches the tv to another mode:
Quote:state 0x12000a [HDMI CEA (32) 3D FP RGB lim 16:9], 1920x1080 @ 23.98Hz, progressive
But although the 'FP' sounds like 'Full...' the screenshot is still only half-res top/bottom
Is it possible that this is simply the way it is? Or is something wrong with my setup?
Here's a log of a few seconds of playback:
http://sprunge.us/SQWf
If it says FP, you will be getting a full resolution 1920x2205 mode.
I think the screenshot may resize to kodi's gui size.
If you play a full resolution MVC video (i.e. one with 16:9 aspect ratio and so 1920x1080 for each eye)
I think you should find the screenshot has a small black border between the top and bottom images
(45 pixels before the scaling, but will be about 22 pixels after scaling).
In the image you've posted it is hard to tell as there are black bars due to the aspect ratio.
This latest release seems to be better for me as I don't have anymore the duration time bug.
Nonetheless, some of my BD 3D ISO that play perfectly normally, are only seen as 2D movie.
No 3D button on OSD.
Here is a sample 3D movie that's played in 2D only :
https://onedrive.live.com/redir?resid=C1...file%2ciso
(2016-02-04, 00:05)vandamme Wrote: [ -> ]This latest release seems to be better for me as I don't have anymore the duration time bug.
Thanks for sample - I'll take a look. Did this work in previous builds?
(2016-02-04, 00:05)vandamme Wrote: [ -> ]Here is a sample 3D movie that's played in 2D only :
Hmmm, that worked for me. Playing in framepacked mode. 3D button is on video OSD.
How are you playing? I have "Blu-ray playback mode" set to "Play main movie".
Ah - if I use the simplified menu and then "play main title" it is 2D. I'll have a look.
Hi Popcornmix,
I played with simplified menu.
But, you're right, if I use "Play main movie" option, everything is fine !
(2016-02-04, 00:47)vandamme Wrote: [ -> ]I played with simplified menu.
I've reverted the change that broke it. Works both ways now.
New OpenELEC Krypton build #0203:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.1 #1 Wed Feb 3 21:05:32 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Feb 1 2016 17:54:49
Copyright (c) 2012 Broadcom
version b3dc56931507f355d503ea69397778643f7a3dc3 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160203210441-#0203-g5704075 [Build #0203]
# vcdbg log msg 2>&1 | grep DTOK
001745.977: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (57040756,
changelog) and tip of
XBMC master (e39724cb,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (0e074384, ahead +139)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (4476f11b, ahead +4)
- Includes latest p8-platform master (38343e0a)
- Includes latest addons: adsp.basic (598900a9), adsp.biquad.filters (71087c48), adsp.freesurround (990fee29), asplib (d8a34587, +8), pvr.argustv (c8f64fd4, +8), pvr.demo (32952941, +8), pvr.dvblink (ff02fe16, +10), pvr.dvbviewer (d10f17c6, +7), pvr.filmon (618594a7, +8), pvr.hdhomerun (41184673, +7), pvr.hts (5eceedaa, +43), pvr.iptvsimple (baaae159, +11), pvr.mediaportal.tvserver (39e89190, +33), pvr.mythtv (da0a6f50, +9), pvr.nextpvr (0c5d81d3, +10), pvr.njoy (13bd96fd, +7), pvr.pctv (ddef4bc9, +8), pvr.stalker (1a3cf911, +9), pvr.vbox (49f16911, +10), pvr.vdr.vnsi (894555c6, +12), pvr.vuplus (b27f0819, +8), pvr.wmc (9b43f0be, +8)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Exclude [env] kodi-995.20-black-screen-when-switching-channels-during-live-tv.patch: Merged upstream
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] f26415ab: libass: bump to 0.13.1
- Include [env] 3a6268c9: VAAPI: Enable EGL
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] 858f6461: xf86-video-intel: bump to 371219c
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: Enable other binary addons
- Include [env] patch: [update] pvr.vuplus (thanks @seo)
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] PR:4500: kodi: update to 17.0
- Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] PR:4659: connman-wait-online and connman.service changes
- Include [env] PR:4661: stripping changes
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8822: Implement ignore url options in CFileItemList
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:8923: [GUI] Replace thumb size with images res
- Include [pkg] PR:8937: [guilib] Add animated png support
- Include [pkg] PR:9034: [mysql]: Fix limited songs query after #8993
Build Highlights:
- New 4.4.1 kernel
- ffmpeg: update to 2.8.6
- curl: update to 7.47.0
- libressl: update to 2.2.6
- Fix for systemd reboot issue when using remote filesystems - please test and confirm if issue now fixed!
- Disable DMA on RPi2 sdhost driver to see if this improves stability with some SD cards, but at the cost of increased CPU.
Re-enable DMA by add "pio-limit=1" to sdtweak or sdhost dtoverlay options in config.txt, eg:
dtoverlay=sdtweak,pio-limit=1
or
dtoverlay=sdhost,overclock_50=100,pio-limit=1
Build Details:
- OpenELEC:
- Various package updates (PR:4669, 2 commits, 2 files changed)
- pixman: update to 0.34.0
- More package updates (PR:4673, 5 commits, 36 files changed)
- linux: update to 4.4.1
- libnfs: update to 1.10
- cmake: update to 3.4.3
- platform: update to 081032f (49593e8e)
- kodi-binary-addons: update to use their Jarvis branches (fbdbf12f)
- XBMC:
- AESinkAudiotrack: Reimplement critical parts (PR:9023, 6 commits, 7 files changed)
- CGUIListContainer: reset scroller position too on GUI_MSG_LABEL_RESET. (PR:9018, 1 commit, 1 file changed)
- VideoPlayer: refactor DemuxerClient (ex PVR) (PR:9019, 3 commits, 14 files changed)
- [videoplayer] Update selectionstream's properties that can change over time in UpdateStreamInfos(). (PR:8913, 2 commits, 1 file changed)
- Bump libnfs to version 1.10.0 (PR:9016, 1 commit, 4 files changed)
- fix French AZERTY keyboard layout (2ed49f8e)
- newclock5:
- New commits in this build:
- AE: detect messy timestamps (mkvmerge) and increase interval for average error calculation if pts jumps (19cd5692)
- RenderSystem - cleanup (63443a85)
- fixup! RenderSystem - cleanup (85e850e0)
- Commits no longer in build:
- Revert "ActiveAE: Enable display lost callbacks for EGL" (4bb6710a)
- Revert "VideoPlayer: Handle lost display with pause/resume" (91c514eb)
- kernel 4.4.y:
- BCM270X_DT: Disable DMA for bcm2835-sdhost on Pi2 (9c1adcc0)
- Added: [env] PR:4659: connman-wait-online and connman.service changes
Just noticed there's a long-ish delay (4-5 seconds) without audio after seeking to a timestamp, eg. enter 5-0-0-OK to jump to 5 minutes. This affects only MMAL, not OMX.
Going back through the builds, this started happening with build
#0102 - prior to build #0102, audio resumes immediately after seeking to a timestamp.
Debug log from #0203, using MMAL:
http://sprunge.us/dXOH
At 60.655430 I clicked "OK" (KEY_ENTER) to jump to the 5m timestamp - video resumed immediately at the new timestamp.
However audio didn't resume until 64.815727:
04:09:23 64.815727 T:1875895200 DEBUG: ActiveAE::SyncStream - average error 22.072887, last average error: 3513.680532
04:09:23 64.915710 T:1875895200 DEBUG: ActiveAE::SyncStream - average error of -15.568037, start adjusting
04:09:23 64.915878 T:1875895200 DEBUG: ActiveAE::SyncStream - average error -0.568037 below threshold of 30.000000
