bagofcrap24, @
username145 and anyone else that reported/experienced reboot hangs when mounting remote filesystems using systemd: can you test this issue is now fixed in build #0203 as you should now be able to reboot reliably while using systemd mount services.
I tried watching Finding Nemo and the movie looks pretty awful. Its completely pixelated and the colors are washed out. It looks fine when I play the same movie in vlc.
Just an FYI that I played that movie for the first time tonight, so I can't vouch for the fact that it worked before.
I tried other movies and they don't suffer from this issue.
Here is
Kodi Log
Platform/Build: Raspberry Pi 2 with New OpenELEC Krypton build #0203
(2016-02-04, 04:22)Milhouse Wrote: [ -> ]
popcornmix with this commit I'm able to boot after removing the "debug_flags=1" hack, but I see a couple "mmc0: timeout waiting for hardware interrupt" entries:
dmesg output
Apart from that, everything seems to be working correctly. Would you pass this info to pelwell.
No one else has the problem with Delete the EPG Guide Data ?
System->Live-TV->EPG->Delete Data and nothing happened (Log:
http://pastebin.com/uk9jSnAr)
Raspberry Pi 2 , PVR IPTV Simple Client and build #0203
Last build seems a bit confused about "network online". I do have a OS-level mount (but I wasn't experiencing any lockup on reboot).
Before the systemd bump months ago my network would be up in ~7 seconds and Kodi started a second after that (~8s). After bump, network would be online in ~15 seconds and Kodi started a second or two after that (~16-17s).
Today's build takes a while to bring up the interface, pinging the Pi while rebooting confirmed that network comes up after ~35 seconds.
"Network Online" service seems to timeout (after 30 seconds), mount service is started but fails and then Kodi is started (33 seconds):
10:50:43 33.529049 T:1963450368 NOTICE: Starting Kodi (17.0-ALPHA1 Git:e39724c). Platform: Linux ARM 32-bit
SSHing and starting the mount service manually works and Kodi is happy.
journalctl:
http://sprunge.us/YcXZ
(2016-02-04, 12:13)Kougami Wrote: [ -> ]No one else has the problem with Delete the EPG Guide Data ?
System->Live-TV->EPG->Delete Data and nothing happened (Log: http://pastebin.com/uk9jSnAr)
Log shows it's trying to get confirmation, but the confirmation dialog fails to load with Aeon Nox 5 skin as there were changes in Krypton.
Switch to Confluence or manually update (and continue updating manually) to Aeon Nox from GitHub.
(2016-02-04, 12:20)menakite Wrote: [ -> ] (2016-02-04, 12:13)Kougami Wrote: [ -> ]No one else has the problem with Delete the EPG Guide Data ?
Thanks, update to Aeon Nox from GitHub solve the Problem
with 202 and 203 I get a very strong green tinge with iso, siff and 3D.MVC.m2ts 3d files. 3D.MVC.mkv files are fine. In previous versions I only had the problems with 3D.MVC.m2ts files. After this happens all screens have this green tinge. I can fix this by switching to another hdmi input on my television and back to the Kodi input. I see there were some changes made in this area on 202.
(2016-02-04, 12:16)menakite Wrote: [ -> ]SSHing and starting the mount service manually works and Kodi is happy.
journalctl: http://sprunge.us/YcXZ
Could you paste your mount service? Surprised you're not getting problems on reboot - with an NFS mount service I would hang on reboot almost all of the time (prior to #0203).
(2016-02-04, 08:56)lixer Wrote: [ -> ]I tried watching Finding Nemo and the movie looks pretty awful. Its completely pixelated and the colors are washed out. It looks fine when I play the same movie in vlc.
Here is Kodi Log
Debug wasn't enabled for this log. A sample of this file would be more useful. Cut a one or two minute section. e.g. with mmg from
mkvtoolnix and upload to a sharing site (e.g. google drive or dropbox).
(2016-02-04, 13:35)trevorjharris Wrote: [ -> ]with 202 and 203 I get a very strong green tinge with iso, siff and 3D.MVC.m2ts 3d files. 3D.MVC.mkv files are fine. In previous versions I only had the problems with 3D.MVC.m2ts files. After this happens all screens have this green tinge. I can fix this by switching to another hdmi input on my television and back to the Kodi input. I see there were some changes made in this area on 202.
Nothing changes in software when you switch inputs. I suspect this is a hardware/voltage issue.
Make sure power supply is good and try adding to config.txt
http://config_hdmi_boost=7
You could also try a different hdmi cable.
(2016-02-04, 16:41)Kougami Wrote: [ -> ]OpenELEC sometimes freeze while playing music ? Log: http://pastebin.com/GjVV7Jdc
Don't cut down logs. Post them complete.
15:33:18 754.080505 T:1497662368 ERROR: Open - error probing input format, /storage/music/Warface - The 9 Circles/04. Warface Ft. Eric Dumont - Voice Of Addiction.mp3
Suggests ffmpeg doesn't like that file. Can you play it with another media player?
(2016-02-03, 08:46)MikeKL Wrote: [ -> ] (2016-02-02, 16:34)polo_joe Wrote: [ -> ]with latest build I get no audio when watching livetv channels
debug log http://sprunge.us/NiKe
build 0131 was ok.
Switching for build #0129 to #0201 I also have no audio with SD or HD channels when playing Live TV
(TVHeadend frontend & backend running on Pi)
Standard log http://sprunge.us/FQaL
My usual Video Add-ons and local stored video playback audio is working as normal
same behavior with latest build 0203!
(2016-02-04, 14:54)Milhouse Wrote: [ -> ]Could you paste your mount service? Surprised you're not getting problems on reboot - with an NFS mount service I would hang on reboot almost all of the time (prior to #0203).
http://sprunge.us/YhdY
Looks like it's based on nfs.mount.sample.
