I'm experiencing huge lags playing
this video (mp4, FullHD, 60fps, 35mbit/s). Last time I played it successfully I used test build Kodi 16 therefore no idea about the last working build.
Ok - have the last build working for me in DTS/DD on DVD identified - #0126.
But here it seemed to be a problem with the "skip key" for the chapters...everlasting.
Thanks for your answer/solution
Harald
(2016-02-14, 14:59)doldi Wrote: [ -> ]Ok - have the last build working for me in DTS/DD on DVD identified - #0126.
The only change I see in #0127 is "Pulseaudio update to 8.0 and switch back to AEPulseSink"
(I believe the other changes were just commits moving from newclock5 to upstream)
Starting with #0207b the touch interface on RPi2 with the official RPi 7" display doesn't work anymore. (Display works fine, but no touch handling anymore...)
And, as this is my first post here: A huge thank you for this great work! I love it!
mity!
(2016-02-14, 17:08)mity! Wrote: [ -> ]Starting with #0207b the touch interface on RPi2 with the official RPi 7" display doesn't work anymore. (Display works fine, but no touch handling anymore...)
Most likely
PR:8807
I suspected the same. But there isn't any solution in the quite long thread, or did I miss it...
This is the first time this issue has been reported. We made a small tweak to RPi's input handling to fix controllers, so maybe in fixing controllers we broke RPi touch. Can you post a debug log? I'll see if it tells us anything.
Can't lock changes on the main screen. Like adding progamm icons or weather info. It reset after rebooting. Thanks.
What skin? This looks unrelated to RetroPlayer. We don't tweak the main screen, other than adding the "My Games" window. If this is still a problem after RetroPlayer is rebased on master, I'll look into it. Thanks for reporting
(2016-02-14, 20:55)MONSTA Wrote: [ -> ]Can't lock changes on the main screen. Like adding progamm icons or weather info. It reset after rebooting. Thanks.
Failure to save these skin settings is a frequent issue - it sometimes works... sometimes doesn't. There's nothing in the log to indicate an issue - on shutdown Kodi claims to be saving settings but the most recent skin setting change is often lost. I suggest opening an issue on
http://trac.kodi.tv if there isn't one already.
(2016-02-14, 21:47)nb2a Wrote: [ -> ]Can someone please advise why I cannot get the HD home run pvr to work in this latest build?
Here is my log
http://xbmclogs.com/pkktvkdyo
18:38:45 89.346893 T:1754264480 ERROR: Unable to load /usr/lib/kodi/addons/pvr.hdhomerun/pvr.hdhomerun.so, reason: /usr/lib/kodi/addons/pvr.hdhomerun/pvr.hdhomerun.so: undefined symbol: IsRealTimeStream
This add-on doesn't support API 4.2.0. Open an issue on
https://github.com/kodi-pvr/pvr.hdhomerun - if there's no sign of an update soon I'll be forced to drop it from the build (as I recently did with pvr.vuplus). No point building broken and unsupported add-ons.
New OpenELEC Krypton build #0214:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.1 #1 Sun Feb 14 22:19:20 GMT 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160214221827-#0214-ga9bb95e [Build #0214]
# vcdbg log msg 2>&1 | grep DTOK
# Kernel device tree status: DISABLED
Based on tip of
OpenELEC master (a9bb95e0,
changelog) and tip of
XBMC master (221b1a82,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (0e074384, ahead +139)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (2927ce04, ahead +9)
- Includes latest p8-platform master (38343e0a)
- Includes latest addons: peripheral.joystick (fc605f4b, +46), pvr.argustv (9459a485, +9), pvr.demo (32952941, +8), pvr.dvblink (ff02fe16, +10), pvr.dvbviewer (d10f17c6, +7), pvr.filmon (76625cc8, +9), pvr.hdhomerun (f66cbe99, +8), pvr.hts (95b98abb, +45), pvr.iptvsimple (baaae159, +11), pvr.mediaportal.tvserver (39e89190, +33), pvr.mythtv (da0a6f50, +12), pvr.nextpvr (8c6e7ea7, +11), pvr.njoy (13bd96fd, +7), pvr.pctv (b321e302, +9), pvr.stalker (4da8913c, +10), pvr.vbox (83f95b9c, +15), pvr.vdr.vnsi (894555c6, +12), pvr.wmc (8327f887, +10)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 2f83a1cf: xf86-video-intel: bump to 8b8c9a36 (fixes segfault when refreshrate changing)
- Include [env] 3a6268c9: VAAPI: Enable EGL
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] 858f6461: xf86-video-intel: bump to 371219c
- Include [env] compare: ffmpeg: Additional Jarvis 2.8.x patches
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: Enable other binary addons
- Include [env] patch: Fix RSS patch
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: kodi: peripheral.joystick binary addon
- Include [env] PR:4500: kodi: update to 17.0
- Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] PR:4661: stripping changes
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8822: Implement ignore url options in CFileItemList
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:8985: [gui] new infobool Window.Is()
- Include [pkg] PR:9081: Fix limited songs query (for MySQL) and improve efficiency of GetSongs
- Include [pkg] PR:9112: [confluence] [PVR] small adjustments
- Include [pkg] PR:9134: RenderManager: Maintain counters correctly
- Include [pkg] PR:9136: [addons] fixes/cleanup
Build Highlights:
- Drop libsquish - no more support for DXT compressed textures and DDS artwork. May break third-party skins using DXT compressed textures (contact skin maintainer for updates)
- Improved performance when navigating Setting > Add-ons
- Fix add-on dependency issues after PR9051
- Solves the issue when pressing stop with boblight / ambilight / hue that we run into a hang (PR9134)
- Drop PR8807 (build issues) - may resolve touchscreen problem?
Build Details:
- XBMC:
- [win32][fix][VS] some missing end tags after #9105 (PR:9127, 1 commit, 1 file changed)
- [cmake] Guard inclusion of config.h (PR:9122, 1 commit, 4 files changed)
- [travis] Build with CMake (PR:9121, 5 commits, 16 files changed)
- [addons] improve database performance (PR:9113, 2 commits, 7 files changed)
- allow sorting of install date/last updated/used in directory providers (PR:9115, 2 commits, 2 files changed)
- AESinkAUDIOTrack: Adjustments for AML (PR:9084, 2 commits, 5 files changed)
- AE: flush engine when sink gets reconfigured (PR:9129, 1 commit, 1 file changed)
- VideoPlayer: fixes for DemuxClient (PR:9128, 1 commit, 1 file changed)
- remove libsquish (PR:9092, 11 commits, 76 files changed)
- AESinkAUDIOTrack: Shield v5 also wants HD Audio (PR:9133, 1 commit, 1 file changed)
- libnfs:
- fix spelling errors. (PR:139, 1 commit, 2 files changed)
- peripheral.joystick:
- Android support with two controller buttonmaps (PR:33, 3 commits, 3 files changed)
- newclock5:
- New commits in this build:
- VideoPlayer: update selectionstreams when stream parameters changes (8703bef6)
- rbp: Support zero copy interface with hevc acceleration (bb32bfe1)
- Updated commits in this build:
- MMALFFMPEG: Add pool to reduce number of gpu allocs/frees (edbef4a8 => 6dbf0291)
- Commits no longer in build:
- AE: flush engine when sink gets reconfigured (7b68d139)
- rbp: Add zero copy interface to ffmpeg for software decode (76e3a36f)
- Added: [pkg] PR:9134: RenderManager: Maintain counters correctly
- Added: [pkg] PR:9136: [addons] fixes/cleanup
So far I cannot get any PVR clients to work in the last two builds. I can only get the demo pvr to work. I have in use windows media center on another computer running windows 8 and Kodi with no issue. Can someone advise what pvr they are currently using please?
