Full Version: OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
New OpenELEC K* build #1211: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.3.1 #1 Fri Dec 11 21:33:16 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Dec  8 2015 14:44:44
Copyright (c) 2012 Broadcom
version e591b5eb05e2cdb1b5ae25512b27d33127d7bee9 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151211213227-#1211-gc5875ae [Build #1211]
# vcdbg log msg 2>&1 | grep DTOK
001695.277: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (c5875ae6, changelog) and tip of XBMC master (25ed1c2c, changelog) with the following modifications: Build Highlights:
  1. New 4.3.1 kernel
  2. FFmpeg based image loader
  3. [PVR] Feature: Separate windows for "Recording Rules" and "Timers"
Build Details:
  1. XBMC:
    • [guilib/pictures] Add an ffmpeg based image loader (PR:8370, 3 commits, 10 files changed)
    • add userrating support to mediafilter (PR:8553, 1 commit, 1 file changed)
    • FIX: [droid] mouse handling regression (PR:8550, 2 commits, 1 file changed)
    • [confluence] String fix 'Timer' => 'Timers' (PR:8558, 1 commit, 1 file changed)
    • [Confluence] fix sidemenu nowplaying buttons (PR:8554, 1 commit, 1 file changed)
    • add userrating support to smartplaylists (PR:8537, 1 commit, 2 files changed)
  2. newclock5:
    • New commits in this build:
      • [rendermananger] Ensure fps is valid before changing refresh rate (37002ed5)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: Bump kernel 4.3.1
    • Added: [pkg] PR:8196: jsonrpc: expose profile directory in Profiles.GetCurrentProfile/GetProfiles.
    • Added: [pkg] PR:8561: [PVR] Feature: Separate windows for "Recording Rules" and "Timers"
(2015-12-11, 18:54)popcornmix Wrote: [ -> ]
(2015-12-11, 18:21)parcel Wrote: [ -> ]Lastest test build working good, but there is a buffering issue that infinite showing video frames lagged and no audio.
Can't do anything with a report like this. Will need a debug log and/or a sample file with instructions to reproduce the issue.
I check again. Video source is wrong. It's not a OpenELEC problem. Sorry.
I noticed that only 2D bluray seems to be 'libaacs' compatible - 3D bluray refuse to play when they're AACS protected.
In the logfile it says:
Quote:01:26:36 6095.889648 T:1508754336 NOTICE: Creating Demuxer
01:26:37 6096.343750 T:1508754336 ERROR: Open - error probing input format, udf://%2fvar%2fmedia%2fBLURAYISO_02%2fBluray%2fB0036%20-%20BLURAY%203D%20-%20AACS.iso/BDMV/STREAM/SSIF/00013.ssif
01:26:37 6096.344238 T:1508754336 ERROR: OpenDemuxStream - Error creating demuxer
01:26:37 6096.344727 T:1508754336 NOTICE: CVideoPlayer::OnExit()
So I think the problem is in DVDDemuxFFmpeg.cpp - any chance this can be enhanced to also take advantage of libaacs?
1211 Boots only once for me. After a reboot it stucks on the bootscreen saying "OpenELEC (Milhouse) ... Version..."
Edit: unplugged the Pi for a minute, now it works
(2015-12-11, 17:02)doldi Wrote: [ -> ]Hi popcornmiy,
early in the morning i have kake this test with "zappa plays zappa" (pal) iso. [8,5 GB / with DD5.1 and DTS Sound]
chapter forward makes his job in one second.
chapter backwards needs ca 4 -6 seconds with buffering. [DTS5.1)
DVD folder (pal) strukture works perfect with chapter forward/backward.
Tested on RPi2 with hifiberryDAC+
Sound make no problem.
Hello doldi,
I noticed that you have a HifiberryDAC+. Is DD5.1 passthrough working for you?
Ollo
no Ollo - didn't work:
If i switch to passtrough in operation, my RPi2 reboots.
After this action AudioDevice PI:HDMI is avtivated.
I do not tested bevor, because my first RPi2 is on LCD TV over HDMI and conectetd with spdif to Yamaha 6.1 Audiodevice.
The second Rpi2 with hifiberry make his job with Monitor and AltecLansing Desktopspeakers.
sorry, no satisfactory reply for you - but helpfull for you?
hi milhouse and popcornmix,
over repository.lost-and-found.zip i have a new MTV.de addon Version (the old 3.3 is broken)
Build #1001 will play this, but in build #1211 i dont have any chance. Video is stuckering.
Edit:
If i switch in #1001 to passtrough (hifiberryDAC+) in operation (running on Video), my RPi2 do not reboot and analog sound goes on ;-)
@doldi: upload a debug log from #1211 when playing a stream from this addon
(2015-12-12, 17:14)doldi Wrote: [ -> ]Edit:
Is your RPi2 with #1211 actually rebooting, or do you mean Kodi is crashing (if so, upload the crashlog). If you need a debug-enabled build I can upload one later.
PS. If Hifiberry need Kodi developers to make their product work, they might want to consider donating hardware to the XBMC Foundation.
(2015-12-12, 17:30)Milhouse Wrote: [ -> ]PS. If Hifiberry need Kodi developers to make their product work, they might want to consider donating hardware to the XBMC Foundation.
I posted your request in the Hifiberry community. Maybe someone recognize you Christmas wish. Smile By the way are there some changes regarding passtrough. With #1210 I'm no longer able to switch the passtrough output. HDMI is greyed out. Independent of the "Sync playback to display" setting.
My hifiberry RPi2 with #1211 is actually rebooting. RPi2 is starting new =reboot
playing: Louane -Avenir on mtv.de addon [stuttering/pixeling video and hanging sound] - here is the log:
http://xbmclogs.com/paeymtkxc
@Ollo - i do not understand the world, tzzz
Now my system -Audiodevice stand on "PI:HDMI" is not greyed out and sound over hifiberry (go from '1001' to '1210' build for craslog).
doldi is disoriented Undecided
i am missing my hifiberrydac in settings?
there are
HDMI
Analogue
hdmi and Analog
Alsa Pulse audio server
...is that ok?
(2015-12-12, 03:22)nalor Wrote: [ -> ]I noticed that only 2D bluray seems to be 'libaacs' compatible - 3D bluray refuse to play when they're AACS protected.
Here's the full debug log of the problem (I thought I post it before anyone asks about it Wink ) : debug log
I have 2 images of the same disc on the my drive - at first I tried to play the aacs-encrypted image >> it fails and afterwards I played the image without aacs encryption and it works.
Spdif appeared after disabling "sync to display" and rebooting. As we say: you will not understand without a glass of vodka Big Grin
#1211
(2015-12-12, 18:00)doldi Wrote: [ -> ]My hifiberry RPi2 with #1211 is actually rebooting. RPi2 is starting new =reboot
there are
HDMI
Analogue
hdmi and Analog
...is that ok?
I don't think so, I have the same. Just noticed the same after installing #1211. I would assume it should be ALSA (snd_rpi_hifiberry_digi) or similar. This might be the explanation that the passtrough output is disabled and fixed to HDMI.
