Full Version: OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-02-26, 22:30)nikekakkar Wrote: [ -> ]Whats the best way to port over addons from Openelec 6 to the latest build on this thread? I tried using the kodi default backup/restore program addon but it doesnt restore anything at all. It shows me un-archiving the zip file, copying the data, but then nothing happens. I got a popup message asking if I wanted to restore backups from a previous version of kodi which I selected yes. Is there anything else I need to do?
I am using a raspberry pi2
Just drop the tar file into the Update folder and reboot.
Not really sure about the backup/restore program - do you have a debug log (wiki)?
(2016-02-26, 22:26)doldi Wrote: [ -> ]@FernetMenta
Thank You for the fix detection of eof in passthrough mode.
..available in the next build? ;-)
I think it missed the cut for tonight's #0226 build, but should probably be in Saturdays build.
Edit: It will be in #0226 after all.
(2016-02-26, 23:03)Milhouse Wrote: [ -> ]
That would normally be my option - but I am using a new SD card and wanted to copy over the addons I had earlier - I figured since this is Kodi 17 if I have issues I can always go back to my vanilla openelec install. Thats why was looking at addons to use
I will try again and upload the debug log.
** edit ** - looking at the sd card via ssh, it seems all the addons/sources are copied in. Not sure why they dont show up though - my original data was **not** from a custom build or anything.. just a custom background wallpaper picture.
**edit 2** - addons are there it seems but they are all disabled. No shortcuts (the quick dropdown addons that you can select) show up however, and some other settings are off.. odd really.
New OpenELEC Krypton build #0226: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.2 #1 Fri Feb 26 21:38:21 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Feb 25 2016 18:56:38
Copyright (c) 2012 Broadcom
version dea971b793dd6cf89133ede5a8362eb77e4f4ade (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160226213725-#0226-g610e9bf [Build #0226]
# vcdbg log msg 2>&1 | grep DTOK
001785.630: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (610e9bfe, changelog) and tip of XBMC master (877b7d8f, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Includes latest bcm2835-driver master (35282eba, ahead +21)
  • Includes latest dcadec master (0e074384, ahead +139)
  • Includes latest kodi-platform master (92583ef9, ahead +2)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (eebe56ce, ahead +10)
  • Includes latest p8-platform master (38343e0a)
  • Includes latest addons: peripheral.joystick (fc605f4b, +46), pvr.argustv (501f56b3, +21), pvr.demo (116a172a, +16), pvr.filmon (4beb05da, +23), pvr.hdhomerun (3f0dd8e6, +29), pvr.hts (0814da42, +55), pvr.iptvsimple (1dfc3547, +24), pvr.mediaportal.tvserver (4860e622, +48), pvr.mythtv (44df4430, +25), pvr.nextpvr (1871323c, +23), pvr.njoy (4f30f4af, +16), pvr.pctv (522f9603, +21), pvr.stalker (0402f465, +20), pvr.vbox (b0916449, +23), pvr.vdr.vnsi (2089549a, +21), pvr.vuplus (4cf6ad02, +19), pvr.wmc (9a83292f, +22)
  • Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
  • Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 2f83a1cf: xf86-video-intel: bump to 8b8c9a36 (fixes segfault when refreshrate changing)
  • Include [env] 3a6268c9: VAAPI: Enable EGL
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] 858f6461: xf86-video-intel: bump to 371219c
  • Include [env] compare: ffmpeg: Additional Jarvis 2.8.x patches
  • Include [env] patch: Enable AUX SPI module
  • Include [env] patch: Clean Kodi view cache on startup
  • Include [env] patch: Enable other binary addons
  • Include [env] patch: Fix AML patch 3.0.0 -> 3.1.0
  • Include [env] patch: Enable OpenELEC add-ons and repositories in manifest
  • Include [env] patch: config: Enable HCI over UARTs
  • Include [env] patch: Add experimental splash video
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: kodi: peripheral.joystick binary addon
  • Include [env] PR:4500: kodi: update to 17.0
  • Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
  • Include [env] PR:4661: stripping changes
  • Include [env] PR:4780: bluez: Add patches to load new brcm firmware
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] patch: # Quick fix for libdvd build issues
  • Include [pkg] patch: Enable game controllers in manifest
  • Include [pkg] PR:7030: CNetwork - implement IPv6
  • Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8807: Controller input
  • Include [pkg] PR:8822: Implement ignore url options in CFileItemList
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9110: [addons] fix 'system addons'
  • Include [pkg] PR:9112: [confluence] [PVR] small adjustments
  • Include [pkg] PR:9191: [GUI] Hide OSD close button
  • Include [pkg] PR:9204: fixed: Screensaver would lockup Kodi when stopping on slow systems
  • Include [pkg] PR:9210: [gui] refactor visualisation preset dialog
Build Highlights:
  1. NOTE: DVD playback remains temporarily disabled
  2. paplayer: fix detection of eof in passthrough mode
Build Details:
  1. OpenELEC:
    • Add all mtools during host install step. (PR:4778, 2 commits, 1 file changed)
  2. XBMC:
    • VideoPlayer fix comskip (PR:9179, 5 commits, 10 files changed)
    • [PVR] PVRManager::Cleanup - do not destruct addons with pvr manager mutex locked (PR:9190, 1 commit, 1 file changed)
    • [python] - fix WindowXML().setProperty() (PR:9187, 1 commit, 2 files changed)
    • [cmake] Build kodi.bin for android (PR:9197, 2 commits, 35 files changed)
    • addon fixes and improvements (PR:9207, 5 commits, 13 files changed)
    • [database] dont attempt to drop automatically created indices when clearing analytics (PR:9166, 1 commit, 1 file changed)
    • [android] bump to NDK 10e (PR:9218, 1 commit, 2 files changed)
  3. pvr.nextpvr:
    • Fixed editing recordings, and recording only new episodes (PR:40, 1 commit, 3 files changed)
  4. newclock5:
    • New commits in this build:
      • paplayer: fix detection of eof in passthrough mode (5b3aaa2d)
      • VideoPlayer: some cleanup for dropping video frames (d4a4e845)
    • Commits no longer in build:
      • fixup: mmalrender: protect null access (acae10e8)
      • rbp: Fix up mouse coordinates in 3D modes (bba730f6)
  5. kernel 4.4.y:
      • Merge pull request #1300 from HiassofT/card-owner-fix (371f4f69)
(2016-02-26, 17:30)popcornmix Wrote: [ -> ]Can you test with latest build?
I tried it with build #0224 and #0226 and it's working fine with them Smile
Thanks for the quick fix!
(2016-02-02, 22:56)nalor Wrote: [ -> ]Just came across another small optical flaw in stereomode - a few checkboxes in the menu are displayed in the wrong aspect ratio, they aren't round any longer but eggs instead.
Here you can see the wrong ones
And here's an example of the right ones
Just noticed it's fixed in #0226! Thanks for that Smile
(just noticed screenshots created in 3d mode look destroyed now? Those created in 2d mode are ok)
fix detection of eof in passthrough mode works. DTSwaves in one folder plays all now.
(2016-02-26, 21:41)popcornmix Wrote: [ -> ]
(2016-02-26, 20:55)Lyns Wrote: [ -> ]Is there no option for "Pause during refresh rate change" anymore?
What about system/video output/Delay after change of refresh rate?
(make sure settings level is on advanced or expert).
I had tried that before, but gave it another experiment today. It does indeed work but only when omxplayer acceleration is disabled (before I had both omx&mmal acceleration on so didn't notice or think to try different combinations).
Is that an expected behaviour & will there be any disadvantages to not having omx acceleration enabled?
(2016-02-27, 19:09)Lyns Wrote: [ -> ]Is that an expected behaviour & will there be any disadvantages to not having omx acceleration enabled?
omxplayer disabled is the default on Pi2 so it's not a problem.
(2016-02-27, 01:22)nalor Wrote: [ -> ]Just noticed it's fixed in #0226! Thanks for that Smile
I've been wrong - it's not fixed Sad Don't know what I've seen yesterday... Sad
New OpenELEC Krypton build #0227: RPi / RPi2
# uname -a
Linux rpi512 4.4.2 #1 Sat Feb 27 22:57:32 GMT 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160227225640-#0227-g0fd4f7b [Build #0227]
001787.145: Kernel trailer DTOK property says yes
Based on tip of OpenELEC master (0fd4f7b7, changelog) and tip of XBMC master (789a7899, changelog) with the following modifications:
Build Highlights:
  2. MMAL: Remove support for YUV and make the MMAL format more general
Build Details:
  1. OpenELEC:
    • amlogic_cec: bug fixes and clean ups (PR:4785, 1 commit, 2 files changed)
    • bluez: Add patches to load new brcm firmware (PR:4780, 2 commits, 2 files changed)
    • misc-firmware: update to misc-firmware-0.0.17 (PR:4782, 1 commit, 1 file changed)
  2. XBMC:
    • [osx] - fix crash on osx 10.7 when trying to resolve hdd names (PR:9216, 2 commits, 3 files changed)
    • [builtins] add doxygen related documentation (PR:9184, 1 commit, 16 files changed)
    • [addon] add several for python related documentation parts (PR:9193, 1 commit, 5 files changed)
    • [win32] DownloadMingwBuildEnv: Quote paths (PR:9219, 1 commit, 1 file changed)
    • [VideoPlayer] WinRenderer: fix render capure when dxva render method … (PR:9214, 1 commit, 2 files changed)
    • [gitignore] - remove outdated paths (PR:9215, 1 commit, 1 file changed)
    • [android] Show all cpus in debug overlay (PR:9206, 2 commits, 2 files changed)
    • [gui] refactor visualisation preset dialog (PR:9210, 1 commit, 4 files changed)
    • [addons] fix 'system addons' (PR:9110, 1 commit, 8 files changed)
    • [network] Fix CZeroconfBrowserAvahi dtor avahi thread termination. (PR:9211, 1 commit, 2 files changed)
    • [GUI] Hide OSD close button (PR:9191, 1 commit, 4 files changed)
    • [GUI] Update default icons (PR:9192, 1 commit, 20 files changed)
  3. newclock5:
      • squash dropping (c928cc53)
      • MMAL: Remove support for YUV and make the MMAL format more general (a24e2bf2)
      • MMAL: Add zero copy accelerated interface to ffmpeg (1065f701)
      • [network] Fix CZeroconfBrowserAvahi::doRemoveServiceType map iterator usage (8be2af26)
      • [cmake] fix libdvd after move to depends (824ca7e0)
      • [cmake] openssl is an optional dep (089fdd37)
      • [cmake] fix mmal (b7331487)
      • [gui] change CGUIEditControl to use CVariant (2ab4fad6)
      • [addons] remove 'visualization-library'. unused (0a1fc480)
      • [addons] remove 'userdirs' feature. unused (181d1ce5)
      • [addons] remove repository plugin hooks. unused and broken (7fd6454b)
      • VideoPlayer: drop incorrect error message (e5c9194a)
      • VideoPlayer: make video abort faster on flush (b37c6e41)
      • VideoPlayer: some cleanup in audio player (91499d8b)
      • VideoPlayer: fix comskip (7a1636d2)
      • OMXVideoPlayer: make video abort faster on flush (479b92ad)
      • [PVR] PVRManager::Cleanup - do not destruct addons with pvr manager mutex locked (ac0640b2)
      • [python] - fix WindowXML().setProperty() (4bbc6550)
      • [cmake] Drop unused FindMpeg2 module (5d9fa5c5)
      • [cmake] Build kodi.bin for android (b3e3a643)
      • move jsonrpc code out of AddonProps (abc71dfe)
      • [addons] don't return empty repository on failure. regression from 78096f42db (73cf7ed9)
      • cleanup CScraper constructors (26f42f66)
      • [addons] remove unnecessary database access on opening info dialog (0756e1a8)
      • [addons] cleanup and cosmetics (e50cdd8b)
      • [database] dont attempt to drop automatically created indices when clearing analytics (2578bab1)
      • rbp: Add zero copy interface to ffmpeg for software decode (1a57190d)
      • MMALFFMPEG: Add pool to reduce number of gpu allocs/frees (548bf240)
      • mmal: Handle software and hardware decode with common renderer code (d0f75d07)
      • fixup: uninitialised dimensions in mmal (2ba82473)
      • fixup: Allocate mmal buffer header later and use small pool (34ce96cf)
      • fixup: More mmal buffers (d93edab5)
  4. kernel 4.4.y:
      • smsx95xx: Add option to disable the crimes against truesize fix (b14062ee)
New OpenELEC Krypton build #0228: RPi / RPi2
# uname -a
Linux rpi512 4.4.2 #1 Sun Feb 28 21:30:02 GMT 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160228212910-#0228-g436e3e6 [Build #0228]
001784.993: Kernel trailer DTOK property says yes
Based on tip of OpenELEC master (436e3e69, changelog) and tip of XBMC master (27feddfd, changelog) with the following modifications:
  • Exclude [env] libcec-03-amlogic-support.patch: Incompatible with libcec 3.1.0, not required
  • Include [pkg] PR:8723: Implement filecache retry logic
  • Include [pkg] PR:9225: Fix out of memory crash in CArchive
Build Highlights:
  2. Fix segfault on empty folders
  3. PR:8723: Implement filecache retry logic (may benefit poor WiFi reception)
  4. PR:9225: Fix out of memory crash in CArchive (no longer deleting cache files on startup)
Build Details:
  1. OpenELEC:
    • libcec: make Amlogic adapter thread safe (PR:4789, 1 commit, 1 file changed)
    • Include all default additional drivers into WeTek Play and WeTek Core projects (PR:4790, 2 commits, 3 files changed)
  2. XBMC:
    • [fix] binary-addons on linux/aarch64 (PR:9221, 1 commit, 1 file changed)
    • [cmake] Fix windows build after migration to msys2 (PR:9220, 2 commits, 3 files changed)
    • [EPG] Notify observers on epg updates (PR:9233, 1 commit, 2 files changed)
    • Fix segfault on empty folders (PR:9229, 1 commit, 1 file changed)
  3. newclock5:
  4. Additional commits/pull requests/changes not yet merged upstream:
From #0226 OpenELEC Settings/About no longer gives any information for Distribution, Version, Architecture.
Since build 211, the PVR guide window takes a large amount of time to open, up to 30 seconds or so. Build 210 is fine if I revert, with usual wait of 2-3 seconds. No build since has shown any improvement either. This occurs on 2 individual RPi2. 1 core is at 100% usage whilst this is happening, and it does occasionally happen whilst the guide is displayed also, with everything freezing for a long time. I'm connected to another RPi2 running latest TVHeadend. Logs show nothing obvious as it looks like nothing is logged at all whilst kodi is frozen; although I can obtain if required. Has anyone else seen this?
(2016-02-29, 01:42)Chudley Wrote: [ -> ]Since build 211, the PVR guide window takes a large amount of time to open, up to 30 seconds or so. Build 210 is fine if I revert, with usual wait of 2-3 seconds. No build since has shown any improvement either. This occurs on 2 individual RPi2. 1 core is at 100% usage whilst this is happening, and it does occasionally happen whilst the guide is displayed also, with everything freezing for a long time. I'm connected to another RPi2 running latest TVHeadend. Logs show nothing obvious as it looks like nothing is logged at all whilst kodi is frozen; although I can obtain if required. Has anyone else seen this?
I guess you might as well upload the debug log (wiki) from #0210 and #0211 - there might be something that gives a clue what the difference is.
