(2016-03-01, 18:47)doldi Wrote: [ -> ]by your leave, Milhouse
why is that disabled? :-)
Because some PR (merged) which improved windoze build stuff completely broke linux cross-compiling of needed libdvd* libs.
Milhouse I was able to figure this libdvd crap out, but the fixes are for my own buildsystem, not sure if similar tricks can be made for OpenELEC,
if you want details via PM let me know.
(2016-03-02, 00:37)asavah Wrote: [ -> ] (2016-03-01, 18:47)doldi Wrote: [ -> ]by your leave, Milhouse
@Milhouse I was able to figure this libdvd crap out, but the fixes are for my own buildsystem, not sure if similar tricks can be made for OpenELEC,
Sure, I'd be interested in your patches - thanks.
(2016-03-01, 20:20)galopogos Wrote: [ -> ]Hei
I installed the Pi2 build 29Feb on the new raspberry Pi3. I do not see the openelec menu (the one to set the network connections) under system.
Do you please know how to solve this one?
It's all in preparation for
Estuary, which will (starting with tonight's build) be the new default Kodi skin.
As a result, Confluence is now in installed from the Kodi repository and the version number has been bumped so that your Kodi will update itself with Confluence from the repository.
The repository version of Confluence is not patched with the OpenELEC button.
Nor will Estuary have an OpenELEC button - you can access the Settings add-on from the Add-on page.
New OpenELEC Krypton build #0301:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.3 #1 Tue Mar 1 22:36:50 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Feb 29 2016 14:28:51
Copyright (c) 2012 Broadcom
version dea971b793dd6cf89133ede5a8362eb77e4f4ade (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160301223527-#0301-g553a77a [Build #0301]
# vcdbg log msg 2>&1 | grep DTOK
001786.626: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (553a77a5,
changelog) and tip of
XBMC master (f327e149,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest bcm2835-driver master (9cd1c6c0, ahead +22)
- Includes latest dcadec master (0e074384, ahead +139)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (eebe56ce, ahead +10)
- Includes latest p8-platform master (38343e0a)
- Includes latest addons: peripheral.joystick (fc605f4b, +46), pvr.argustv (501f56b3, +21), pvr.demo (116a172a, +16), pvr.filmon (4beb05da, +23), pvr.hdhomerun (3f0dd8e6, +29), pvr.hts (0814da42, +55), pvr.iptvsimple (1dfc3547, +24), pvr.mediaportal.tvserver (4860e622, +48), pvr.mythtv (44df4430, +25), pvr.nextpvr (1871323c, +23), pvr.njoy (4f30f4af, +16), pvr.pctv (522f9603, +21), pvr.stalker (0402f465, +20), pvr.vbox (b0916449, +23), pvr.vdr.vnsi (2089549a, +21), pvr.vuplus (4cf6ad02, +19), pvr.wmc (9a83292f, +22)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Exclude [env] libcec-03-amlogic-support.patch: Incompatible with libcec 3.1.0, not required
- Include [env] ae77537c: new package: add package 'brcmfmac_sdio-firmware-rpi'
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] f815ed9d: linux: bluez needs /etc/firmware
- Include [env] 2f83a1cf: xf86-video-intel: bump to 8b8c9a36 (fixes segfault when refreshrate changing)
- Include [env] 3a6268c9: VAAPI: Enable EGL
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] 858f6461: xf86-video-intel: bump to 371219c
- Include [env] compare: ffmpeg: Additional Jarvis 2.8.x patches
- Include [env] patch: Add Pi3 GPIO LED support
- Include [env] patch: Enable AUX SPI module
- Include [env] patch: Enable other binary addons
- Include [env] patch: Enable OpenELEC add-ons and repositories in manifest
- Include [env] patch: linux: update to 4.4.3
- Include [env] patch: Switch to Estuary as default skin, drop Confluence
- Include [env] patch: config: Enable HCI over UARTs
- Include [env] patch: Add experimental splash video
- Include [env] patch: kodi: update to 17.0
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: kodi: peripheral.joystick binary addon
- Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] PR:4661: stripping changes
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: Fix OE settings setProperty() method (OpenELEC-settings)
- Include [pkg] patch: # Quick fix for libdvd build issues
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8723: Implement filecache retry logic
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9112: [confluence] [PVR] small adjustments
- Include [pkg] PR:9204: fixed: Screensaver would lockup Kodi when stopping on slow systems
- Include [pkg] PR:9225: Fix out of memory crash in CArchive
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- New default skin Estuary (Confluence now available from repository)
- Fix crash with 10-bit video
Build Details:
- OpenELEC:
- partly rollback for LG compatibility (PR:4796, 1 commit, 2 files changed)
- buildsys: define TARGET_KERNEL_ARCH early (PR:4797, 1 commit, 11 files changed)
- kodi-language-addons: add languages (PR:4758, 2 commits, 3 files changed)
- add generic aarch64 support (PR:4787, 3 commits, 4 files changed)
- linux: aarch64 fixup (PR:4802, 1 commit, 1 file changed)
- XBMC:
- [PVR] small tweaks (PR:9116, 2 commits, 2 files changed)
- [VideoPlayer] WinRenderer: fix UO/SBS playback if stereo mode was ena… (PR:9242, 1 commit, 1 file changed)
- New clothes for Kodi (PR:9235, 6 commits, 1531 files changed)
- [PVR] Channels window: Add support for sorting channels by 'last played' (PR:9248, 1 commit, 2 files changed)
- [skin] Estouchy (PR:9222, 3 commits, 683 files changed)
- newclock5:
- New commits in this build:
- fixup! rbp: Support zero copy interface with hevc acceleration (1c7b53c3)
- MMALFFPEG: Avoid crash with 10-bit video (6dcbf2af)
- Commits no longer in build:
- confluence: Remove media-overlay.jpg for when video is backgrounded (b8f7aadf)
- fixup! temp: Add lock around mmal and omx calls to avoid stalled audio issue (35c626ce)
- Added: [env] f815ed9d: linux: bluez needs /etc/firmware
- Added: [env] patch: Switch to Estuary as default skin, drop Confluence
- Updated: [env] patch: kodi: update to 17.0
(2016-03-02, 01:08)Milhouse Wrote: [ -> ] (2016-03-02, 00:37)asavah Wrote: [ -> ] (2016-03-01, 18:47)doldi Wrote: [ -> ]by your leave, Milhouse
Will PM you with the details tomorrow (today?).
Milhouse I am currently running OpenELEC 6.0.3 on my RPi2, and I noticed on the first page on this thread that 0301, 01-Mar-2016 now has new default skin Estuary. That's great, thanks so much for this update, I will try this out this week.
Maybe this is a silly question, but I was wondering if for any reason I want to revert back to OpenELEC 6.0.3, can I just put the 'OpenELEC-Generic.x86_64-6.0.3.tar' file in the updates folder like you do for an upgrade or do I need to do a fresh install?
I also was wondering is there any way to get OpenELEC 7.0 Kodi 17.0 for generic builds, i.e. x86 (Intel/AMD) CPU systems. I have OpenELEC running on a Media PC and also on a USB stick and would like to upagrade these to Kodi 17.0 as well. I appologise, I realise this is not the correct thread for this question.
(2016-03-02, 16:16)parker.hugh Wrote: [ -> ]Maybe this is a silly question, but I was wondering if for any reason I want to revert back to OpenELEC 6.0.3, can I just put the 'OpenELEC-Generic.x86_64-6.0.3.tar' file in the updates folder like you do for an upgrade or do I need to do a fresh install?
You can downgrade using just the tar file, but since #0301 you'll also need to delete /storage/.kodi/addons/skin.confluence when downgrading back to OE6.
(2016-03-02, 16:16)parker.hugh Wrote: [ -> ]I also was wondering is there any way to get OpenELEC 7.0 Kodi 17.0 for generic builds, i.e. x86 (Intel/AMD) CPU systems. I have OpenELEC running on a Media PC and also on a USB stick and would like to upagrade these to Kodi 17.0 as well. I appologise, I realise this is not the correct thread for this question.
http://forum.kodi.tv/showthread.php?tid=238393
just loaded the #301 build - noticed a few challenges with the skin when using an MCE remote exclusively (some widgets cannot be reached..) but the killer for me is that rendering the EPG (coming from a WMC backend) is extremely slow and browsing the EPG causes the Pi2 to hang altogether. Went back to latest Jarvis test build and all is good again...
keep up the good works!!
Thnx
(2016-03-02, 16:54)Milhouse Wrote: [ -> ]You can downgrade using just the tar file, but since #0301 you'll also need to delete /storage/.kodi/addons/skin.confluence when downgrading back to OE6.
Thanks for your advice, I'm glad I asked now that I realise I need to delete this file when downgrading. Hopefully I won't need to but it's good to have a plan B
(2016-03-02, 16:54)Milhouse Wrote: [ -> ]http://forum.kodi.tv/showthread.php?tid=238393
Again, thanks for above link to OpenELEC Testbuilds for x86 (Kodi 17), I didn't know that existed. You certainly have a lot of builds going on. Your help is much appreciated.
since some weeks the tvheadend epg data is lost after reboot
tvheadend settings, kodi settings wrong?
(2016-03-02, 19:26)polo_joe Wrote: [ -> ]since some weeks the tvheadend epg data is lost after reboot
You don't say what version of tvheadend you're using, but I provide the latest version
here
You could also go back through the OpenELEC builds to try and determine the build when the problem started.
It might also be a tvheadend issue - have you tried asking in their
support section?
Latest upgrade seems to have become an issue even opening quite a few addons. I suspect it is skin related although the new skin looks nice. I will more than likely go back to build 229 until I see more reports on the new build. Thanks for the work.
(2016-03-02, 19:57)nb2a Wrote: [ -> ]Latest upgrade seems to have become an issue even opening quite a few addons. I suspect it is skin related although the new skin looks nice. I will more than likely go back to build 229 until I see more reports on the new build. Thanks for the work.
Just switch back to Confluence, you should have it installed already in /storage/.kodi/addons (v3.0.0, from the official Kodi repository). The only noticeable difference is likely to be the missing OpenELEC button.
(2016-03-02, 01:41)Milhouse Wrote: [ -> ][*]Fix crash with 10-bit video
Thanks for the fix. I tried the build today:
Kodi does not crash anymore, but there is neither video nor sound.
(2016-02-29, 21:38)daCook8 Wrote: [ -> ]With OpenELEC 6.0.2 playback works, but is stuttering.
Is there a Kodi v17 compatible Keymap_Editor - Add-on ?
http://kodi.wiki/view/Add-on:Keymap_Editor
I installed the addon from repo via your latest build #0301.
But when i try to change a key, the addon crashes.
Do you need debug logs?
