Full Version: Changes to the skinning engine for Kodi Krypton
Pages: 1 2 3 4 5 6 7
Below you'll find an up-to-date list of all changes made to the skinning engine since the release of Kodi Jarvis.
addon.xml
xbmc.gui
new feature
new actions
new built-in functions
removed built-in functions
new infolabels
changed infolabels
  • ListItem.Rating - for songs it's now the scraped rating (details)
  • ListItem.UserRating - now available for albums/songs (details)
  • ListItem.RatingAndVotes - now available for albums/songs (details)
  • ListItem.DBType - now available in the music library (details)
  • ListItem.Property(Addon.Name) -> ListItem.AddonName (details)
  • ListItem.Property(Addon.Version) -> ListItem.AddonVersion (details)
  • ListItem.Property(Addon.Creator) -> ListItem.AddonCreator (details)
  • ListItem.Property(Addon.Summary) -> ListItem.AddonSummary (details)
  • ListItem.Property(Addon.Description) -> ListItem.AddonDescription (details)
  • ListItem.Property(Addon.Disclaimer) -> ListItem.AddonDisclaimer (details)
  • ListItem.Property(Addon.Broken) -> ListItem.AddonBroken (details)
  • ListItem.Property(Addon.Type) -> ListItem.AddonType (details)
removed infolabels
new infobools
changed infobools
  • ListItem.Property(Addon.Installed) > ListItem.Property(Addon.IsInstalled) (details)
  • ListItem.Property(Addon.Enabled) > ListItem.Property(Addon.IsEnabled) (details)
  • ListItem.Property(Addon.UpdateAvail) > ListItem.Property(Addon.HasUpdate) (details)
removed infobools
deprecated infobools
includes
new defaulticons
changed defaulticons
  • unknown-user.png -> DefaultUser.png (details)
new database path
new content type
new control type
removed control types
epggrid control
grouplist control
slider control
new dialogs
new window names
removed window names
DialogAddonInfo.xml
DialogNotification.xml
DialogAudioDSPManager.xml
  • remove listitems (details)
  • ListItem.Property(Name) --> ListItem.Label (details)
  • ListItem.Property(AddonName) --> ListItem.Label2 (details)
  • ListItem.Property(Icon) --> ListItem.Icon (details)
DialogConfirm.xml
DialogGameControllers.xml
DialogMusicInfo.xml
DialogPVRInfo.xml
DialogSelect.xml
DialogSettings.xml
DialogVolumeBar.xml
MyPlaylist.xml
MyPVRTimers.xml
  • remove radiobutton id="8" (details)
  • change radiobutton id="9" to id="8" (details)
  • add ActivateWindow(TVTimerRules) / ActivateWindow(RadioTimerRules) (details)
  • update visible conditions (details)
SettingsCategory.xml
SettingsSystemInfo.xml
SlideShow.xml
SmartPlaylistEditor.xml / SmartPlaylistRule.xml
  • converted several controls to regular "button" controls" (details)
VideoFullScreen.xml
Please keep this thread clean. It should be an easy overview for skinners who are updating their skin for Kodi Krypton.
For discussions / feature requests / bugreports, please find (or create) the appropriate thread in the skin development forum.
2015-12-05 new built-in function - InstallAddon()
instead of adding a long list of addon dependencies to your addon.xml,
please consider whether you can remove some of them and instead use the
InstallAddon() function in your skin to install addons on demand.
forum discussion: 231104 (thread)
git commit: https://github.com/xbmc/xbmc/commit/c8f7...a4b8c368fe
pull request: 8419 (PR)
2015-12-06 music ratings changes
this applies to albums and songs:
ratings have been split into
  • ListItem.Rating (scraped rating)
  • ListItem.UserRating (user set rating)
this info label has been added:
  • ListItem.RatingAndVotes (for albums/songs)
  • MusicPlayer.UserRating (for songs)
this info label has been removed:
  • ListItem.StarRating
also, these ratings now use a 1-10 rating system (used to be 1-5).
git commit: https://github.com/xbmc/xbmc/commit/3cd0...5cb867cfe9
pull request: 8405 (PR)
Will be superseded by https://github.com/xbmc/xbmc/pull/8856
(2015-12-06, 16:23)ronie Wrote: [ -> ]2015-12-06 DialogContentSettings.xml changes
needed changes:
  • replace spincontrol (id="20") with a button control (id="20")
  • remove the list control (id="21") and replace it with a button (id="21")
some cleanup / navigation fixes might be needed in your skin as well.
git commit: https://github.com/xbmc/xbmc/commit/c1d4...adacb9c9ba
pull request: 8320 (PR)
2015-12-06 xbmc.gui - version bump
xbmc.gui has been bumped to 5.11.0.
git commit: https://github.com/xbmc/xbmc/commit/a358...da6654d488
pull request: 8495 (PR)
2015-12-15 DialogSelect.xml - cancel button
add a cancel button (id="7") in DialogSelect.xml
or
in case you already had a custom cancel button, change it's id to 7 and remove the onclick and label tags.
git commit: https://github.com/xbmc/xbmc/commit/17fb...94420f3634
pull request: 8417 (PR)
2015-12-18 MyPVRTimers.xml - changes
pvr timers have been split in 'repeating timers' and 'one off timers'.
the repeating timers have been moved to two new windows:
  • TVTimerRules
  • RadioTimerRules
both will keep using the MyPVRTimers.xml file.
required changes:
  • remove radiobutton id="8" (group timers)
  • change the id of radiobutton id="9" to id="8" (Hide disabled timers)
  • add ActivateWindow(TVTimerRules) / ActivateWindow(RadioTimerRules) somewhere so the new windows can be accessed
  • update your visible conditions to include Window.IsVisible(TVTimerRules) / Window.IsVisible(RadioTimerRules) where needed
git commit: https://github.com/xbmc/xbmc/commit/5cd8...3f0b433360
pull request: 8561 (PR)
2015-12-29 AddonBrowser.xml - changes
a few settings that were on the sidemenu of the addon browser have been moved to the system settings window.
needed changes:
  • remove radiobutton id="6" (notifications)
  • change the label of button id="5" to 10004 (settings)
this change also introduces a new boolean condition:
  • ListItem.Property(Addon.Orphaned)
git commit: https://github.com/xbmc/xbmc/commit/af48...7bba379b09
pull request: 8607 (PR)
2015-12-31 Changed infolabel
ListItem.DBType now also works in the music library.
it will return 'artist', 'album' or 'song', depending on the listitem.
git commit: https://github.com/xbmc/xbmc/commit/5ece...6b2a4dd372
pull request: 8711 (PR)
2016-01-04 New infolabels
  • ListItem.Tag
  • ListItem.Set
will return the name of the 'tag' or 'set' the item is part of.
git commit: https://github.com/xbmc/xbmc/commit/4a65...984d697592
pull request: 8721 (PR)
2016-01-04 Changed infobools
old names:
new names:
  • ListItem.Property(Addon.IsInstalled)
  • ListItem.Property(Addon.IsEnabled)
  • ListItem.Property(Addon.HasUpdate)
for use in the addon window/dialogs
git commit: https://github.com/xbmc/xbmc/commit/7e84...a0a8179a86
pull request: 8682 (PR)
2016-01-05 New built-in function
  • Skin.SelectBool()
up 'till now skins couldn't use spincontrols (or any other button) to make a selection between multiple options.
this new function allows skins to use a select dialog to select between multiple skin setting options.
you need to pass the header label and the labels and the names of the skin settings:
Skin.SelectBool(424, 31411|RecentWidget, 31412|RandomWidget, 31413|InProgressWidget)
git commit: https://github.com/xbmc/xbmc/commit/34eb...378734c9e8
pull request: 8303 (PR)
2016-01-05 New infolabels
in order to support multiple ratings in the future (needs scraper support),
the following new infolabels have been added:
  • ListItem.Rating(<name>)
  • ListItem.Votes(<name>)
  • ListItem.RatingAndVotes(<name>)
this will allow skins to display a rating from a specific metadata provider, eg:
ListItem.Rating(imdb)
ListItem.Votes(tmdb)
git commit: https://github.com/xbmc/xbmc/commit/9204...0b92c4b97d
git commit: https://github.com/xbmc/xbmc/commit/03c8...7c821f1374
pull request: 8080 (PR)
pull request: 8788 (PR)
2016-01-09 New infolabel
  • ListItem.SetID
usecases:
show a list of movies belonging to the same set as the focused movie: <content target="video">videodb://movies/sets/$INFO[ListItem.SetID]</content>
provide a shortcut to open the movie set directly: ActivateWindow(Videos,videodb://movies/sets/$INFO[ListItem.SetID],return)
git commit: https://github.com/xbmc/xbmc/commit/ea3f...b27a850814
pull request: 8759 (PR)
