Full Version: ADBFire File Directory
Hi
I installed Kodi on an Amazon Fire stick and pushed some mp4 video files using ADB Fire. Under 'preset directories' ADB Fire was configured to 'sdcard'
Where can I find these files and how do I play them?
Many thanks
Blankston
Had same problem, here the solution for kodi v15.2 Isengard:
- start Kodi
- go to System -> Settings
-- Appearance -> File lists -> check "Show hidden files and directories" is switched ON
Now you can find preset directories under: ..\sdcard\Android\data\org.xbmc.kodi\files\.kodi\
Note: files or directories with prefixed period e.g. .kodi are considered by kodi as hidden
Original description of this solution was found here
