2016-01-05, 20:47
2016-01-10, 16:10
I'm seeing a small black box in the upper right corner, beneath the Date + Time.
It's probably one of the settings for the Skin, but I can't find which one. Anyone?
2016-01-10, 20:25
Also: Kodi crashes when I press the "OK" button on my remote. It's set to show the OSD.
2016-01-10, 20:26
(2016-01-05, 20:47)coolguy82 Wrote: [ -> ]When I try to install this via zip file, says failed to install addon on APPLE TV 4?
Hi, I'm not sure what is happening here, do you have a log file? Thanks.
2016-01-10, 20:27
(2016-01-10, 16:10)Smultie Wrote: [ -> ]I'm seeing a small black box in the upper right corner, beneath the Date + Time.
Hi, I think this is to do with having weather enabled but with no add-on configured. I just disabled all weather add-ons and it went away. Thanks.
2016-01-11, 03:35
Does this new version implement the option to cycle between subs directly from the video overlay?
If yes, how difficult would it be for me to manually implement this in my own 14.2 setup?
I looked at the differences in both the VideoOSD.xml of my setup and the new one on Github, and I see only 2 major differences.
edit: Nevermind, that wasn't hard at all. Thanks for implementing that feature.
edit2: For anyone that wants the new subtitle functions as hotkeys
\userdata\keymaps\keyboard.xml
Can be easily changed, here's how to find out which keycode you want
http://kodi.wiki/view/List_of_Kodi_keynames
<keymap>
<fullscreenvideo>
<keyboard>
<key id="61526">nextsubtitle</key> <!-- key = v -->
<key id="61506">showsubtitles</key> <!-- key = b -->
</keyboard>
</fullscreenvideo>
</keymap>
2016-01-21, 19:03
Thanks for all the work !
Jarvis compatible version of Amber including joethepartylion and my fixes is available on the official Kodi repo.
http://mirrors.xbmc.org/addons/jarvis/skin.amber/
All fixes/updates/changes have been updated on the official amber github:
https://github.com/jester-xbmc/skin.amber
2016-02-07, 05:24
I've installed Amber to Jarvis release candidate 3. The Settings menu for Amber is greyed out, no access to settings. Any tips or ideas? I could not find anything by googling.
It's a great looking skin but it would be nice to be able to limit the button amount, which I understand should be possible in the settings.
2016-02-11, 01:07
Anyone, any info?
2016-02-11, 02:41
(2016-02-11, 01:07)hartsa Wrote: [ -> ]Anyone, any info?Works great for me. Try doing another fresh install of both Jarvis RC3 and the Amber skin.
2016-02-12, 17:54
Strangely, yesterday evening the settings button was suddenly active. Didn't update Kodi in between
2016-02-12, 21:29
I have a problem that pressing Guide under TV causes Kodi to just hang - ticker tape freezes and becomes unresponsive.
The same Guide menu option works fine under Confluence.
Any ideas? I'm on Jarvis beta 3 I think.
2016-02-12, 23:43
Never mind.. It's working now, although it does take quite a while to appear.
2016-02-13, 02:16
Where can I change the resolution from 1080p60 to 1080p50?
2016-02-13, 23:25
I feel like I'm missing something, not sure if my install is screwed (though I also did a fresh install)...
The playback controls (especially the "Download Subtitle" button) look weird in Jarvis compared to Isengard. Also some dialogues look weird, too (ie: unskinned)
http://i.imgur.com/yQFlSGW.png
http://i.imgur.com/OZHNqpr.png
Is this how Amber is going to be on Jarvis or it's simply a "bug"?
