2016-02-23, 16:40
2016-02-23, 16:40
2016-02-23, 16:55
(2016-02-23, 16:40)calexicoca Wrote: [ -> ]Is there a way to fix this? When I click icon to chose subtitles Stereoscopic 3D mode opens up and and blocks submenu for downloading subtitles. Really annoying.
Ah yes, my fault, I've pushed a fix to Jester, if you are confident you can change the two occurrences of ID 656 to 655 on line 406 in VideoOSD.xml until a new release.
2016-02-23, 17:29
Easy-peasy! Done. Thanks a million!
2016-02-26, 22:37
I have Amber loaded on latest kodi 16.0 and after setting up the menu shelf it crashes after a few uses and resets everything. It's loaded on an Amazon firetv box. What am I doing wrong? Is this a know issue?
2016-02-26, 22:39
Can we expect Krypton support any time soon?
2016-02-29, 09:49
New to this skin.
Can someone tell me how to make file manager available?
New to this skin.
2016-02-29, 09:56
(2016-02-29, 09:49)glubbish Wrote: [ -> ]Hi,
New to this skin.
It's in the settings menu. To the right of Appearance, Videos, Music etc.
2016-02-29, 10:09
Thanks. Rep+1
2016-03-06, 05:52
I use favourites for menus and feeds within plugins/addons (ie: local news, trakt collections) and would like to know if there is a way to have them refresh content everytime I open them. I have to either go through the the original addon and navigate to where I need to get, or exit and re enter kodi....at the moment.
Let me know if I'm missing something or if this is just the way she goes.
2016-03-07, 12:25
(2016-02-26, 22:39)Smultie Wrote: [ -> ]Can we expect Krypton support any time soon?
I'm working on it, still a few bits to tweak and I was waiting for the settings dialogs consolidation to be committed (which it now has). hopefully I'll have something in the next couple of weeks.
2016-03-08, 22:13
Hi guys,
I'm a new in this. I have been using the Amber skin on my kodi in my Rasp PI2.
(Thank you all for that)
But, how can I update my kodi to the new version 16? The Jarvis one?
I don't find any selection on the Settings menu to Update the kodi...
Thanks in advance,
MifPT
Thanks in advance,
MifPT
2016-03-08, 22:25
(2016-03-08, 22:13)MifPT Wrote: [ -> ]Hi guys,Hi
Thanks in advance,
MifPT
which system are you running on your Pi2 ? OpenELEC, OSMC or something else ?
2016-03-08, 23:46
Hi Fredouye,
I'm using OSMC on the RaspPI2.
Thanks,
MifPT
Thanks,
MifPT
2016-03-10, 17:07
This skin works amazing now with Jarvis 16.0... Thank you so much for updating!! Great work...
2016-03-12, 03:02
Where can I get the latest AMBER skin for Jarvis ?
Thanks in advance !!
JB
JB
