Full Version: Custom menus
Hi all
I have made a few changes in the menu to suit myself and renames some of the headings.
I did a backup on my PC and then installed it to my Android box.
I noticed some of the headings that I turned off were back on and some of the headings I renames had different sub menus.
It looked fine on the PC. ?
Any help with this thanks
Hi. Welcome to the forum. You may need to give a bit more info here...
What Skin are you using? Nox 5, Confluence, etc?
Are you making sure you select OK instead of just exiting?
If you just PUT the backup on the Android, it doesn't work that way. You need to make sure your files are all the same. You may have some issues with the GUISETTINGS (which holds your skin settings) transferring over properly. If you don't have a lot of changes, just set them up again on Android. In the new updated Kodi version coming soon, this will be a much easier transition. At the moment, you may have to do a little work though.
