Full Version: Jarvis Repo Help
I updated my repo to include different skins for different Kodi versions.
Repo Download
I tested Isengard 15.2 and it works perfectly but in Jarvis no textures get loaded. It behaves as if the Textures.xbt file isn't there but it is. I tested the zip from GitHub and manually extracted the xbt and overwrote the one downloaded from my repo through Kodi's addon manager and it works so there is something happening with the Textures.xbt file Huh
I installed through the addon manager with debug logging on.
here is my log
Using latest Jarvis nightly 20151209-7f9ff45 on Windows 10.
I also would like to upload a different colored studio icons pack for the resource.addon section since the one currently in the Kodi repo has many images that are hard to make out on dark backgrounds. Any way that it is possible to have this and what should I fix or look for to make it as easy as possible so it is accepted?
Any assistance or insight is appreciated Smile
Known problem with jarvis for combined repo
