Full Version: Featherence [Leia]
Pages: 1 2 3 4 5 6 7
Current skinning engine: 5.14.0 - Kodi Leia.
Krypton, Jarvis and Helix Version are also available in Featherence Repo.
watch gallery
Features:
- 4 2D buttons effects: Bevel, Shadow, Overlay and Stroke effects are available across the entire skin.
- 8 Layouts: Panel/2/3, Horizontal/2/3, Vertical RTL/LTR.
- 6 Buttons shapes: Rectangles, Rectangles R10, Pillows, Hexagons, Circles, Triangles.
- 6 Views: Center List, Line, Poster, Small List, Side List, and Wall.
Most views have about 10 different settings to fit your preference.
- 11 AutoView setup: Movies, TV shows, Seasons, Episodes, Movies Sets, Actors, Genres, Years, Countries, Studios and Directors.
- 1:1 realtime home design capability. Customized is at the top level, superb easy and fun!
- Build creator: Allow to create your own build in a very unique way.
Also used to save and load previously backups.
- Coloring: Everything can be colored exactly as you want, preview is included.
- DVD Cases: Support display of DVD cases and discs across the skin.
- ExtendedInfo support (Movies/TV/Seasons/Episodes/Actors/Directors/AutoComplete..)
- Fanart: Over 10 properties for fanarts! Including 2 layers of colors and textures.
- Integrated video screen and OSD: Keep watching your video while navigating on any window/view, Video player OSD included!
- Genres: 74 hard coded Genres images are insuring to always be seen in your prefered language.
- Mouse: Full mouse support across the skin.
- Multi Languages: Default buttons's labels may change to your current system language if you require.
That's feature will work too when loading a shared build.
- Overlay: Up to 10 different values of overlay for any buttons/menus, preview is included.
- Reposition: Movement of objects maybe done automatic, aka RTL and LTR - simply depend on system language.
Movment of home buttons in the skin design window are matching the current layout 1:1.
- Subtitles: The subtitles window display current and previously choosen subtitles, include a Smart Search button and even auto switch between hosts if required.
Subtitle OSD show country language flag and can be used to offset subtitle.
- User customized media: Choose your favourite startup music, video and pictures slideshow music.
- Password Lock: Lock your prefered buttons with a password.
- Web browser: Launch your default OS internet browser from within Kodi.
- Widget: unwatched/recently added movies and inprogress/recently added TV shows (10/15/20 etc).
Additionaly support: Play trailer or up to 20 random trailers, manual/auto refresh, random fanart from widgets..
- Customized Widget: Create up to 10 widgets for each button.
Download Featherence
Cheers will test
It's probably a good idea to add which version of Kodi the skin is targeted at, I assume Jarvis and have links to the required addons that are not in the Kodi repo.
@im85288
- Added current skinning engine information.
- Added link to the required service addon.
Thanks Smile
Edit:
featherence v0.1.3 (16-Dec-15)
- Option to reposition dialog Yes/No, OK, Busy, Progress...
- Option to force static transperancy for unfocused buttons.
- Option to show rolling disc art.
- Option coloring buttons label & icons.
- Top information auto align by language.
- Show Tips on wait (optional).
- Widget display genre & duration.
- Major Update Horizontal & Vertical views.
- Major design updates across the skin.
- Major bugs fix.
Great job ! very nice skin -light and good looking.
Looks nice. Does it use Clearart/Character art at all?
Featherence v0.2.0 (22-Dec-15)
- Added few more colors options.
- Added default startup music.
- Option to enlarge selected thumbnail.
- Option to hide selector frame.
- Option to color selector frame.
- Option to fade out unfocused thumbnails for some views.
- Minor update default design.
- Update views.
- Update inprogress and watched markers.
- Update scrollbar.
- Update edit manual color module.
- *Major update save/load script.
*Previous backups will not work.
@bearhand,
i will appreciate more feedbacks if you may have.
@mattyspurs76,
I am not sure what is Clearart.. Care to explain?
Very nice Job.
btw, clearart is one kind of many arts you can find in fanart.tv website.
https://fanart.tv/movie/98/gladiator/
go to the end you'll see.
you can use it if your skin support artwork downloader.
@tomer953,
Thanks m8 i am glad you like it!
About clearart i start to understand now.
@mattyspurs76,
Added clear fanart support to the skin WIP.
Hello From The Holy Land...
Featherence v0.2.2 (01-Jan-16)
- Added PVR support.
- Option to enlarge Side List view for extra information.
- Option to toggle fanart size for Side List view.
- Update default settings.
- Update autoview script.
- Update ExtendedInfo buttons.
- Update views.
- Backup script now support all languages.
- Minor bugs fix.
hi mate, sorry to ask this, would it be possible to add enigma2 like channel list?
@hfmls
Don't be sorry as I am too can't help you out Wink
Feel free to ask any question regarding Featherence.
