Full Version: Featherence [Leia]
Pages: 1 2 3 4 5 6 7
@finalmakerr Wow, u r not kidding around r u? Is someone seeing this? Y'all better take notes Smile)
Thank u so much. I didn't have time to test, but I will let you know brother. As for the button. I'll be sure to spread a little financial love as well haha.
Thanks again! You're doing a great job!
Featherence v0.7.1 (02-Feb-17)
- Added icons to power off sub buttons.
- Added view addons changelog button for Krypton.
- Bugs fix:
+ Always show volume level on mute.
+ Circles shapes + reshape/bigger icons features.
+ Clear fanart preview.
+ Colour focus keyboards buttons.
+ Fade time between different skin windows transition.
+ Issue with setting fanart to a single sub menu.
+ MyPVRGuide + DialogPVRInfo topvideoinformation.
+ Play random trailers (from widget).
+ Texture fanart background.
+ Sub Menu action feature (in different language then English).
+ Widgets actions information in skin design window.
+ Others..
- Major update of Cross Fade Time (Multi-Fanart feature).
- Minor update of addon settings window.
+ Description are smaller in height and can be auto scroll by demand.
- Minor update of skin design pop up.
+ 0.5 sec delay added in order to see the current fanart when editing.
+ Improved please wait screen and preview.
+ Remember last fanart for preview purpose.
- Minor update of Allow thumbnail fanart feature to support all skin views.
- Minor update of skin design settings information.
@SpekEnBonen,
Thanks for your support my friend <3
@finalmakerr Your update did the trick brother! I can't thank u enough!
Learn how to fully customise Featherence skin (Kodi).
Featherence first release was on Dec 2015.
About one year later it's finally here!
This video will guide you through all the options available in Featherence.
I really put a lots of efforts in order to release this video, i hope you will find it useful as i do <3
Im using 0.7.1 on Kodi 17.. the action button is not working when i try to set ACTION in skin setup.
I assume script.skinshortcuts is disable, please check.
Also make sure you have the dependency for it:
script.module.simplejson
script.module.unidecode
Is there any builds with featherence already with kodi 17 if so where can I get it .thank u.. I'm having hard time adding widgets
Papo you should watch Featherence Guide video, as it's will answer your questions and more.
I just watched it but it didn't show me how to add the widgets on the home screen
If you're talking about custom widgets then watch from 6:43.
If you refer to movies/tvshows widgets then you should configurate a scraper.
Edit: Added to FAQ
Featherence v0.7.2 (10-Apr-17)
- Added 3 different weather fanart packages (Skin Settings).
- Added 8 different weather icons packages (Skin Settings).
- Added DialogGameControllers window.
- Added High Performance option (Skin Settings).
- Added new category Add-in in skin settings (Easily install and manage Featherence's dependencies).
- Buttons Layout is now selectable.
- Clicking on the left menu icon will pop it up.
- Clicking on the Top Bar while video is playing will open it up and the video OSD.
- Minor bugs fix.
Dialogues:
- Major design update.
- Minor update of some dialogues windows.
- Position has been slightly improved.
Home:
- Added support for additional 10 main buttons (total of 20+7).
- Added auto ID fix for bugged main buttons.
- Major update of Vertical layout.
Overall Design:
- Added light black frame to every poster image.
- 2D Buttons are now perfect squared with no radius (Across the skin).
- Main Color now effect thumbnails border and fill them up when needed.
- Major overall design updates (A lots of design prespective as been updated!).
- Major update of Dialogs windows.
- Major update of EPG timeline window.
- Major update trailers OSD buttons.
- Minor update of SettingsProfile window.
- Minor update of Weather window.
Performance:
- Major reduce of Textures.xbt size.
- Apply Power of Two Rule for all skin images.
- Major reduce of unnecessary animations and layers of images.
- Auto Trigger feature for ignoring extensive images processing during some instances.
Top Information Bar:
- Added MPAA, Ratings and Votes to DialogVideoInfo window.
- Added two more sizes for top information bar.
- Icons are now auto trigger on idle in the position of the time information.
- Video Information is now triggered only when there are enough info.
- Added Covers Distance and Full Fanart features to Line view.
- Added option to show video duration for Side List view.
- Added Sliding/Fade Animation for some views.
- Fade Animation is set to default for some views.
Widget:
- Added full genres support.
- Added Super Widget feature. You may now assign a path for a button which will generate a complete dynamic widget.
- Added Widget Position, Show Rating, Widget Shrink and Widget Fade features.
- Added widget preview for easier configuration.
- Major update of Widget animations and overall design.
- Minor update of widget script.
- Selected widget is more noticeable.
- Widgets are now available during video playback (Size reduced!)
Featherence v0.7.3 (17-Jun-17)
- Added option to control TopMenuDialogSlider transperancy (Subtitle Offset).
- Increase maximum customised buttons by 10.
- Minor bugs fix.
Featherence v0.7.4 (20-Jul-17)
- Added auto hide for ExtendedProgressBar during fullscreen video (for example Quasar progress bar).
- Minor bugs fix.
+ DVDcases not showing up.
- Minor performance improved.
- Minor update of Super Widget feature.
- Wall and Poster view are now always static (no shrink option).
Dears, I just installed featherence on an odroid C2 running the latest official libreelec (krypton based ).
Tried the Arcade section first, downloading the entire rom package by means of the context menu (right click)... But then, when all the games are available, i click on play and nothing appears (neither an error message). Any idea on how to troubleshoot the problem?
