Had a few other things to do in life, but now I had some time... so back to playing with FIRE.
Had some semi-positive results, but generally not yet where I want to be.
For the record, this is the Amazon Fire 7" tablet with Fire OS 5.1.2. I have also loaded the Android APK version of KODI 16
I appreciate the tips on ES File Explorer and shifting the data to the mSD, as my library data (artwork & .nfo's) would easily overwhelm the remaining available memory in the tablet. ES File Explorer gave me better access to the directory structure once I changed its settings to show hidden files.
I believe that the original path to KODI on the FIRE 7" tablet Internal Storage is:
/mnt/sdcard/Android/data/org.xbmc.kodi/files/.kodi
Using the link that was provided as a guide to change the location of the userdata subdirectory, I created a plain text file on my laptop called
xbmc_env.properties.txt, with the contents being:
xbmc.data=/storage/sdcard1/Android/data/org.xbmc.kodi/files
And using the PC and USB cable, I copied that text file to
This PC/Fire/Internal Storage (... which is the same as
/mnt/sdcard ).
Now here is where I begin to run into a challenge...
First, moving .kodi using PC and cable won't work. (Insufficient permissions to write to the mSD card?)
However... ES File Explorer can associate itself with the mSD and allow it to write... and after messing around with it for a while, I was finally able to get it to request permissions to write. and it did.
After copying the .kodi subdirectory to the mSD, I deleted the original .kodi subdirectory and restarted KODI. It worked...
BUT !
What happened is that KODI recreated the .kodi subdirectory on the main storage... and it did not use the mSD located information. (I tried a few times to delete and restart, and found that .kodi would be recreated each time.)
SO:
Did I redirect incorrectly, or is KODI unable to address the mSD on the Fire Tablet?
The log seems to go to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log , so that's definitely not being written to the mSD.
When I look at the output of the log at:
http://xbmclogs.com/pcfpj9duo it does not appear to see (or act on) the xbmc_env.properties.txt file.
Ideas?
Quick footnote: if I just put my advancedsettings.xml into userdata, and tweak the usual settings to allow KODI to recognize my MySQL implementation... the Fire Tablet plays great. Great resolution and sound for such a small device. I'm sure that it could replace my Gen1 iPad. However, in the long run, to use my profiles and start using the full library... I really need to move userdata to the mSD card)
