2015-12-13, 00:07
Hi all,
So I finally decided after my main htpc died and I had to rebuild it was time to get a shared database working, we've got 1 PC downstairs, 1 in the study and 1 android fire tv stick in the bedroom and the wife is nagging me to get them all in sync. So far so easy...
I'll try to list everything and make this as easy for you all to tell me where I've gone wrong, I've tried and failed at this on my own a few years back but since I'm planning to run owncloud off my unraid box at some point soon I thought I best get the database sorted.
So first item was I decided to start the database from scratch. Half the played/unwatched markers are a mess anyway.
So...
1 - Unraid, installed 6.1.3 and made the move to dockers instead of plugins!
2 - Installed MariaDB on the server
3 - Installed mysql workbench aimed it at 192.168.0.9 (Unraid) and ran
CREATE USER 'kodi' IDENTIFIED BY 'kodi';
GRANT ALL ON *.* TO 'kodi'
4 - uninstalled and re-installed Kodi (Isenguard last stable) in the study.
Let it run, closed it and then moved in advancesettings.xml
Added the TV source, used NFS so nfs://192.168.0.9/mnt/user/Television
Let it load, marked a bunch as watched and then updated the source again to refresh it to the server...took an age so I went to bed.
5 - This morning I copied the advancesettings.xml onto a new Kodi install downstairs and it doesn't load TV at all.
6 - Gone back to the upstairs machine and TV is gone too. It only shows up under video and doesn't open up when you hit enter, click on it etc. Pressing C doesn't even bring up a menu!
So any idea what I've done?
Lifted from the log but also shows advancesettings.xml
And from the bottom of the log all these errors....
[b]
Which is making me think I've screwed the pooch on the database but I have no idea how!?
Also I've tried to remove and readd the database on the first machine, it's doing it, but it never shows up to watch....
Thanks to everyone who helps, this is driving me mad. My database skills are weak!
So...
[b]22:02:26 T:996 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.0.9</host>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
</advancedsettings>
22:02:26 T:996 WARNING: VIDEO database configuration is experimental.
22:02:26 T:996 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
22:02:26 T:996 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</musicdatabase>
<videolibrary>
</videolibrary>
</advancedsettings>
[/b]
[b]
22:02:27 T:11736 NOTICE: -->Python Interpreter Initialized<--
22:02:28 T:10364 NOTICE: Previous line repeats 1 times.
22:02:28 T:10364 ERROR: SQL: The table does not exist
Query: select * from movie_view WHERE ((movie_view.playCount IS NULL OR movie_view.playCount < 1))
22:02:28 T:10364 ERROR: CVideoDatabase::GetMoviesByWhere failed
Query: select * from episode_view WHERE ((episode_view.playCount IS NULL OR episode_view.playCount < 1))
22:02:28 T:10364 ERROR: CVideoDatabase::GetEpisodesByWhere failed
Query: select * from musicvideo_view
22:02:28 T:10364 ERROR: CVideoDatabase::GetMusicVideosByWhere failed
Query: SELECT albumview.* FROM albumview WHERE albumview.strReleaseType = 'album'
22:02:28 T:10364 ERROR: CMusicDatabase::GetAlbumsByWhere () failed
Query: SELECT artistview.* FROM artistview WHERE (artistview.idArtist IN (SELECT song_artist.idArtist FROM song_artist) OR artistview.idArtist IN (SELECT album_artist.idArtist FROM album_artist)) and artistview.strArtist != '' and artistview.strArtist <> 'Various artists'
22:02:28 T:10364 ERROR: CMusicDatabase::GetArtistsByWhere failed
Query: SELECT songview.* FROM songview WHERE ((CAST(songview.iTimesPlayed as DECIMAL(5,1)) < 1))
22:02:28 T:10364 ERROR: CMusicDatabase::GetSongsByWhere() failed
22:02:28 T:11508 NOTICE: Thread FileCache start, auto delete: false
Query: select * from movie_view WHERE (movie_view.idFile IN (SELECT DISTINCT idFile FROM bookmark WHERE type = 1))
Query: SELECT * FROM tvshow_view WHERE ( ((tvshow_view.watchedcount > 0 AND tvshow_view.watchedcount < tvshow_view.totalCount) OR (tvshow_view.watchedcount = 0 AND EXISTS (SELECT 1 FROM episode_view WHERE episode_view.idShow = tvshow_view.idShow AND episode_view.resumeTimeInSeconds > 0))))
22:02:28 T:10364 ERROR: CVideoDatabase::GetTvShowsByWhere failed
Query: select * from movie_view WHERE ((movie_view.playCount IS NULL OR movie_view.playCount = 0))
22:02:28 T:9028 NOTICE: Thread FileCache start, auto delete: false
22:02:28 T:4408 NOTICE: Previous line repeats 2 times.
22:02:28 T:4408 NOTICE: Thread JobWorker start, auto delete: true
22:02:28 T:4240 NOTICE: Thread LanguageInvoker start, auto delete: false
22:02:28 T:8632 NOTICE: Thread JobWorker start, auto delete: true
22:02:28 T:8612 NOTICE: Thread RSSReader start, auto delete: false
22:02:28 T:4408 ERROR: SQL: The table does not exist
Query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
22:02:28 T:4408 ERROR: CMusicDatabase::GetRecentlyAddedAlbumSongs failed
Query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
22:02:28 T:4408 ERROR: CMusicDatabase::GetRecentlyAddedAlbums failed
22:02:29 T:10364 ERROR: SQL: The table does not exist
22:02:29 T:10364 ERROR: CVideoDatabase::GetMusicVideosByWhere failed
22:02:29 T:10364 ERROR: CMusicDatabase::GetAlbumsByWhere () failed
22:02:29 T:4408 ERROR: SQL: The table does not exist
Query: select * from movie_view ORDER BY dateAdded desc, idMovie desc LIMIT 10
22:02:29 T:4408 ERROR: CVideoDatabase::GetMoviesByWhere failed
Query: select * from episode_view ORDER BY dateAdded desc, idEpisode desc LIMIT 10
22:02:29 T:4408 ERROR: CVideoDatabase::GetEpisodesByWhere failed
Query: select * from musicvideo_view ORDER BY dateAdded desc, idMVideo desc LIMIT 10
22:02:29 T:4408 ERROR: CVideoDatabase::GetMusicVideosByWhere failed
22:02:29 T:10364 ERROR: CMusicDatabase::GetArtistsByWhere failed
Query: SELECT count(1) FROM songview LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM songview LIMIT 1'
Query: SELECT count(distinct strAlbum) FROM songview LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strAlbum) FROM songview LIMIT 1'
Query: SELECT count(distinct strArtists) FROM songview LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strArtists) FROM songview LIMIT 1'
Query: SELECT count(1) FROM tvshow_view LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM tvshow_view LIMIT 1'
Query: SELECT count(1) FROM movie_view LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM movie_view LIMIT 1'
Query: SELECT count(playCount) FROM movie_view LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM movie_view LIMIT 1'
Query: SELECT count(1) FROM musicvideo_view LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM musicvideo_view LIMIT 1'
Query: SELECT count(playCount) FROM musicvideo_view LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM musicvideo_view LIMIT 1'
Query: SELECT sum(watchedcount) FROM tvshow_view LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount) FROM tvshow_view LIMIT 1'
Query: SELECT sum(totalcount) FROM tvshow_view LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(totalcount) FROM tvshow_view LIMIT 1'
Query: SELECT sum(watchedcount = totalcount) FROM tvshow_view LIMIT 1
22:02:29 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount = totalcount) FROM tvshow_view LIMIT 1'
22:02:29 T:10364 ERROR: CMusicDatabase::GetSongsByWhere() failed
22:02:29 T:4240 NOTICE: -->Python Interpreter Initialized<--
22:02:29 T:9192 NOTICE: Thread FileCache start, auto delete: false
22:02:33 T:9168 NOTICE: Previous line repeats 1 times.
22:02:33 T:9168 NOTICE: Thread BackgroundLoader start, auto delete: false
22:02:35 T:3444 NOTICE: Thread LanguageInvoker start, auto delete: false
22:02:35 T:3460 ERROR: SQL: The table does not exist
22:02:35 T:3460 ERROR: CMusicDatabase::GetRecentlyAddedAlbumSongs failed
22:02:35 T:3460 ERROR: CMusicDatabase::GetRecentlyAddedAlbums failed
22:02:35 T:3460 ERROR: CVideoDatabase::GetMoviesByWhere failed
22:02:35 T:3460 ERROR: CVideoDatabase::GetEpisodesByWhere failed
22:02:35 T:3460 ERROR: CVideoDatabase::GetMusicVideosByWhere failed
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM songview LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strAlbum) FROM songview LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strArtists) FROM songview LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM tvshow_view LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM movie_view LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM movie_view LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM musicvideo_view LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM musicvideo_view LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount) FROM tvshow_view LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(totalcount) FROM tvshow_view LIMIT 1'
22:02:35 T:3460 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount = totalcount) FROM tvshow_view LIMIT 1'
22:02:35 T:3444 NOTICE: -->Python Interpreter Initialized<--
22:02:35 T:10364 ERROR: SQL: The table does not exist
22:02:35 T:10364 ERROR: CVideoDatabase::GetMoviesByWhere failed
22:02:35 T:10364 ERROR: CVideoDatabase::GetEpisodesByWhere failed
22:02:35 T:10364 ERROR: CVideoDatabase::GetMusicVideosByWhere failed
22:02:35 T:10364 ERROR: CMusicDatabase::GetAlbumsByWhere () failed
22:02:35 T:10364 ERROR: CMusicDatabase::GetArtistsByWhere failed
22:02:35 T:10364 ERROR: CMusicDatabase::GetSongsByWhere() failed
22:02:35 T:996 ERROR: SQL: The table does not exist
Query: select count(idSong) as NumSongs from songview
22:02:35 T:996 ERROR: CMusicDatabase::GetSongsCount() failed
22:02:40 T:996 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Program Files (x86)\Kodi\sounds\
22:02:40 T:996 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://xbmc/sounds/
22:02:41 T:996 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Program Files (x86)\Kodi\sounds\
22:02:41 T:996 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://xbmc/sounds/
22:02:43 T:996 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Program Files (x86)\Kodi\sounds\
22:02:43 T:996 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://xbmc/sounds/
22:02:45 T:996 ERROR: SQL: The table does not exist
Query: SELECT movie_view.idSet,COUNT(1) AS c FROM movie_view JOIN sets ON sets.idSet = movie_view.idSet GROUP BY movie_view.idSet HAVING c>1
22:02:45 T:996 ERROR: CVideoDatabase::HasSets failed
22:02:45 T:4408 ERROR: SQL: The table does not exist
22:02:45 T:4408 ERROR: CMusicDatabase::GetRecentlyAddedAlbumSongs failed
22:02:45 T:4408 ERROR: CMusicDatabase::GetRecentlyAddedAlbums failed
22:02:45 T:4408 ERROR: CVideoDatabase::GetMoviesByWhere failed
22:02:45 T:4408 ERROR: CVideoDatabase::GetEpisodesByWhere failed
22:02:45 T:4408 ERROR: CVideoDatabase::GetMusicVideosByWhere failed
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM songview LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strAlbum) FROM songview LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strArtists) FROM songview LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM tvshow_view LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM movie_view LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM movie_view LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM musicvideo_view LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM musicvideo_view LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount) FROM tvshow_view LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(totalcount) FROM tvshow_view LIMIT 1'
22:02:45 T:4408 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount = totalcount) FROM tvshow_view LIMIT 1'
22:02:48 T:4172 NOTICE: Thread BackgroundLoader start, auto delete: false
22:02:55 T:996 NOTICE: Previous line repeats 1 times.
22:02:55 T:996 ERROR: SQL: The table does not exist
Query: SELECT COUNT(*) FROM episode_view WHERE strPath = 'nfs://192.168.0.9/mnt/user/Television/'
22:02:55 T:996 ERROR: exception in CApplication::FrameMove()
22:02:57 T:996 ERROR: SQL: The table does not exist
Query: SELECT COUNT(*) FROM episode_view WHERE strPath LIKE 'nfs://192.168.0.9/mnt/user/Television/Breathless (2013)/'
22:02:57 T:996 ERROR: exception in CApplication::FrameMove()
22:03:41 T:7436 NOTICE: Thread JobWorker start, auto delete: true
22:03:41 T:4500 NOTICE: Thread BackgroundLoader start, auto delete: false
22:03:42 T:996 NOTICE: Previous line repeats 1 times.
22:03:42 T:996 ERROR: Unable to activate the previous window
22:03:42 T:7436 ERROR: SQL: The table does not exist
22:03:42 T:7436 ERROR: CMusicDatabase::GetRecentlyAddedAlbumSongs failed
22:03:42 T:7436 ERROR: CMusicDatabase::GetRecentlyAddedAlbums failed
22:03:42 T:7436 ERROR: CVideoDatabase::GetMoviesByWhere failed
22:03:42 T:7436 ERROR: CVideoDatabase::GetEpisodesByWhere failed
22:03:42 T:7436 ERROR: CVideoDatabase::GetMusicVideosByWhere failed
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM songview LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strAlbum) FROM songview LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strArtists) FROM songview LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM tvshow_view LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM movie_view LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM movie_view LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM musicvideo_view LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM musicvideo_view LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount) FROM tvshow_view LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(totalcount) FROM tvshow_view LIMIT 1'
22:03:42 T:7436 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount = totalcount) FROM tvshow_view LIMIT 1'
22:03:42 T:988 NOTICE: Thread JobWorker start, auto delete: true
22:03:51 T:996 NOTICE: WakeOnAccess - Enabled:TRUE
22:03:51 T:988 ERROR: SQL: The table does not exist
22:03:51 T:988 ERROR: CMusicDatabase::GetRecentlyAddedAlbumSongs failed
22:03:51 T:988 ERROR: CMusicDatabase::GetRecentlyAddedAlbums failed
22:03:51 T:988 ERROR: CVideoDatabase::GetMoviesByWhere failed
22:03:51 T:988 ERROR: CVideoDatabase::GetEpisodesByWhere failed
22:03:51 T:988 ERROR: CVideoDatabase::GetMusicVideosByWhere failed
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM songview LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strAlbum) FROM songview LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(distinct strArtists) FROM songview LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM tvshow_view LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM movie_view LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM movie_view LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(1) FROM musicvideo_view LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT count(playCount) FROM musicvideo_view LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount) FROM tvshow_view LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(totalcount) FROM tvshow_view LIMIT 1'
22:03:51 T:988 ERROR: CDatabase::GetSingleValue - failed on query 'SELECT sum(watchedcount = totalcount) FROM tvshow_view LIMIT 1'
22:03:54 T:7436 ERROR: CNetworkInterfaceWin32::GetHostMacAddress - SendArp failed with error (67)
22:03:54 T:7436 NOTICE: CWakeOnAccess::SaveMACDiscoveryResult - Mac discovered for host '192.168.0.9' -> '00:11:3B:15:3D:02'
22:03:58 T:7008 NOTICE: Thread BackgroundLoader start, auto delete: false
22:03:59 T:996 ERROR: SQL: The table does not exist
22:03:59 T:996 ERROR: exception in CApplication::FrameMove()
[/b]
