Full Version: AC-3 audio stream not selectable
I have a problem where the audio stream cannot be changed from MP1 in Kodi. The menu option during playback to change the audio stream is not selectable. This occurs with live TV and recordings. If I play them through MediaPortal itself, I can select either the MP1 or AC-3 audio stream.
I am using the latest versions of MediaPortal, TVServerKodi and the PVR client along with Kodi 16.0 beta 1 Jarvis DSPlayer.
Any help will be appreciated. Smile
The stream selection is completely at the Kodi side. Nothing I can change from the pvr addon side. Try first if it works with the normal dvdplayer in Kodi. If it is specific for the DSPlayer, ask in the DSPlayer forum thread for help.
