Full Version: How to create an addon for a radio station
HI Everyone,
I have scrolled through the forums and I was wondering is it possible to create an add on for just one radio station 'Sonic Stream', with the stream addy http://cloudrad.io/sonicstream/listen.pls
Could someone point me in the right direction to ask a developer to create this addon.
thanks
Just create a text file with the extension .strm with the URL in it, then put the file somewhere that you can browse to it in Kodi.
http://kodi.wiki/view/Internet_video_and_audio_streams
Or (gratuitous plug alert)
Using my Super Favourites addon (under programs in official repo)
Start up Super Favourites.
Open context menu
Select Create New Manual Entry
Give it a name
Select PlayMedia type
Type in the URL
Job done
(you can then add the item back to Kodi favourites if you want)
HI Spoyser,
Thanks that works Smile
I would really like if an addon could be developed so that other users can use it too.
(2015-12-13, 15:48)pathfinder808 Wrote: [ -> ]HI Spoyser,
Give me 5 minutes
Here you go, it is extremely basic but it does the job. It doesn't really justify being an addon, but since you asked...
https://dl.dropboxusercontent.com/u/1155...-1.0.0.zip
If anyone fancies making some artwork I'll happily add it.
Do you know of any other station hosted there, it might be worth making a more generic cloudrad.io addon
Thanks Spoyser Smile
What dimensions for the artwork?
(2015-12-13, 16:38)pathfinder808 Wrote: [ -> ]Thanks Spoyser Smile
256x256 for Icon
1280x720 for Fanart
How can I get this to you?
(2015-12-13, 17:13)pathfinder808 Wrote: [ -> ]How can I get this to you?
I got your email thanks. Will get it sorted for you.
Thank you Smile
Much appreciated
Added artwork, also changed it to be a script rather than an addon (doesn't open an empty list when you select it), and updated the description in addon.xml
https://dl.dropboxusercontent.com/u/1155...-1.0.1.zip
Might be worth submitting it to the official kodi repo
thanks much appreciated will do Smile
