2015-12-14, 14:16
I'm trying to retain the episode play count when I update an episode or movie (by update I mean replace an existing copy with a better quality source). The new media files are moved into the directories Kodi is aware of via a script, and at that point I should have whatever data flexget would profile. The problem I've got is Kodi doesn't retain the play count from the old version to the new version. My procedure currently works as follows:
What I want to do is
I've been looking at the Kodi JSON RPC api and as far as I can see there is no direct way to look up the removed episode, I have to go though multiple commands to look up the show id, the episode id etc, is there a more straight forward way to do this, something were maybe I can look up the playcount of an episode using it's file path?
- Script checks if the same episode already exists (this is done simply by rm *SXXeXX*) before moving the new file to the location.
- Run update and clean library in Kodi.
- Get the play count for the episode removed from Kodi.
- Update the play count.
