Full Version: Jarvis Beta 4 crash with AMD dual graphics active
Good afternoon,
today I installed the last Jarvis beta and when I start Kodi, the screen is black and windows 10 show a window with the message that Kodi doesn't work. When I deactivate the AMD dual graphics, and work only with the APU Kodi runs perfect.
sorry but i don't know how can I attach the dmp log file. How can I upload it?
18:04:21 T:7028  NOTICE: special://profile/ is mapped to: special://masterprofile/
18:04:21 T:7028  NOTICE: -----------------------------------------------------------------------
18:04:21 T:7028  NOTICE: Starting Kodi (16.0-BETA4 Git:20151213-a724f29). Platform: Windows NT x86 32-bit
18:04:21 T:7028  NOTICE: Using Release Kodi x32 build
18:04:21 T:7028  NOTICE: Kodi compiled Dec 13 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
18:04:21 T:7028  NOTICE: Running on MSI MS-7903 with Windows 10, kernel: Windows NT x86 64-bit version 10.0
18:04:21 T:7028  NOTICE: Host CPU: AMD A10-6700T APU with Radeon(tm) HD Graphics, 4 cores available
18:04:21 T:7028  NOTICE: Desktop Resolution: 1920x1080 32Bit at 50Hz
18:04:21 T:7028  NOTICE: Running with restricted rights
18:04:21 T:7028  NOTICE: Aero is enabled
18:04:21 T:7028  NOTICE: special://xbmc/ is mapped to: C:\Multimedia\Reproductor\Kodi
18:04:21 T:7028  NOTICE: special://xbmcbin/ is mapped to: C:\Multimedia\Reproductor\Kodi
18:04:21 T:7028  NOTICE: special://masterprofile/ is mapped to: C:\Users\kodi\AppData\Roaming\Kodi\userdata
18:04:21 T:7028  NOTICE: special://home/ is mapped to: C:\Users\kodi\AppData\Roaming\Kodi\
18:04:21 T:7028  NOTICE: special://temp/ is mapped to: C:\Users\kodi\AppData\Roaming\Kodi\cache
18:04:21 T:7028  NOTICE: The executable running is: C:\Multimedia\Reproductor\Kodi\Kodi.exe
18:04:21 T:7028  NOTICE: Local hostname: DESKTOP-B6GRNI6
18:04:21 T:7028  NOTICE: Log File is located: C:\Users\kodi\AppData\Roaming\Kodi\kodi.log
18:04:21 T:7028  NOTICE: load settings...
18:04:21 T:7028 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
18:04:21 T:7028 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
18:04:21 T:7028  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:04:21 T:7028   ERROR: Error loading special://profile/advancedsettings.xml, Line 38
                                            Error reading end tag.
18:04:21 T:7028  NOTICE: Default DVD Player: dvdplayer
18:04:21 T:7028  NOTICE: Default Video Player: dvdplayer
18:04:21 T:7028  NOTICE: Default Audio Player: paplayer
18:04:21 T:7028  NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:04:21 T:7028  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:04:21 T:7028  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:04:21 T:7028  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:04:21 T:7028  NOTICE: Loaded playercorefactory configuration
18:04:21 T:7028  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:04:21 T:7028  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:04:21 T:3780  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "1 - Panasonic-TV (AMD High Definition Audio Device)" seems to be not supported.
18:04:21 T:3780  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "1 - Panasonic-TV (AMD High Definition Audio Device)" seems to be not supported.
18:04:21 T:3780  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "1 - Panasonic-TV (AMD High Definition Audio Device)" seems to be not supported.
18:04:21 T:3780  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "1 - Panasonic-TV (AMD High Definition Audio Device)" seems to be not supported.
18:04:21 T:3780  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "1 - Panasonic-TV (AMD High Definition Audio Device)" seems to be not supported.
18:04:21 T:3780  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "1 - Panasonic-TV (AMD High Definition Audio Device)" seems to be not supported.
18:04:21 T:3780  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "1 - Panasonic-TV (AMD High Definition Audio Device)" seems to be not supported.
18:04:21 T:3780  NOTICE: Found 2 Lists of Devices
18:04:21 T:3780  NOTICE: Enumerated DIRECTSOUND devices:
18:04:21 T:3780  NOTICE:     Device 1
18:04:21 T:3780  NOTICE:         m_deviceName      : {DD66608C-4969-45BB-B89B-E2FD0BD49925}
18:04:21 T:3780  NOTICE:         m_displayName     : HDMI - 1 - Panasonic-TV (AMD High Definition Audio Device)
18:04:21 T:3780  NOTICE:         m_displayNameExtra: DIRECTSOUND: 1 - Panasonic-TV (AMD High Definition Audio Device)
18:04:21 T:3780  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
18:04:21 T:3780  NOTICE:         m_channels        : FL,FR
18:04:21 T:3780  NOTICE:         m_sampleRates     : 48000
18:04:21 T:3780  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
18:04:21 T:3780  NOTICE:     Device 2
18:04:21 T:3780  NOTICE:         m_deviceName      : default
18:04:21 T:3780  NOTICE:         m_displayName     : default
18:04:21 T:3780  NOTICE:     Device 3
18:04:21 T:3780  NOTICE:         m_deviceName      : {F2C29267-F34B-44B4-9B98-B7E155DF7486}
18:04:21 T:3780  NOTICE:         m_displayName     : SPDIF - Realtek Digital Output (Realtek High Definition Audio)
18:04:21 T:3780  NOTICE:         m_displayNameExtra: DIRECTSOUND: Realtek Digital Output (Realtek High Definition Audio)
18:04:21 T:3780  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
18:04:21 T:3780  NOTICE: Enumerated WASAPI devices:
18:04:21 T:3780  NOTICE:         m_displayNameExtra: WASAPI: 1 - Panasonic-TV (AMD High Definition Audio Device)
18:04:21 T:3780  NOTICE:         m_sampleRates     : 192000,48000,44100,32000
18:04:21 T:3780  NOTICE:         m_dataFormats     : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
18:04:21 T:3780  NOTICE:         m_displayNameExtra: WASAPI: Realtek Digital Output (Realtek High Definition Audio)
18:04:21 T:3780  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
18:04:21 T:3780  NOTICE:         m_dataFormats     : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:04:21 T:7028  NOTICE: Running database version Addons20
18:04:21 T:7028  NOTICE: ADDONS: Using repository repository.xbmc.org
18:04:21 T:7028  NOTICE: Found screen: Generic PnP Monitor on AMD Radeon HD 8650D + R7 200 Dual Graphics, adapter 0.
18:04:21 T:7028  NOTICE: Primary mode: 1920x1080@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 720x480@ 29.97i - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 720x480@ 30.00i - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 720x576@ 25.00i - Full Screen
18:04:21 T:7028  NOTICE: Previous line repeats 2 times.
18:04:21 T:7028  NOTICE: Additional mode: 800x480@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 800x480@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 800x480@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 800x600@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 800x600@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1024x600@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1024x600@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1024x600@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1024x768@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1024x768@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1024x768@ 24.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1152x648@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1152x648@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1152x648@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x768@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x768@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x768@ 24.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x1024@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x1024@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x1024@ 23.98 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1280x1024@ 24.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1400x1050@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1400x1050@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1400x1050@ 23.98 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1400x1050@ 24.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1600x900@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1600x900@ 24.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1680x1050@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1680x1050@ 23.98 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1680x1050@ 24.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1776x1000@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1776x1000@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1776x1000@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1776x1000@ 29.97i - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1776x1000@ 30.00i - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1776x1000@ 25.00i - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1776x1000@ 24.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
18:04:21 T:7028  NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
18:04:21 T:7028  NOTICE: Checking resolution 16
Thread 7028 (process 4336)
# 0 OpenAdapter10_2
# 1 OpenAdapter10_2
# 2 D3D11CoreCreateLayeredDevice
# 3 D3D11CoreCreateLayeredDevice
# 4 D3D11CreateDeviceAndSwapChain
# 5 D3D11CreateDeviceAndSwapChain
# 6 D3D11CreateDeviceAndSwapChain
# 7 D3D11CreateDeviceAndSwapChain
# 8 ApplyCompatResolutionQuirking
# 9 ApplyCompatResolutionQuirking
#10 ApplyCompatResolutionQuirking
#11 DXGID3D10ETWRundown
#13 ApplyCompatResolutionQuirking
#14 DXGIGetDebugInterface1
#15 DXGIGetDebugInterface1
#16
#17
#18
#19
#20 CommandLineToArgvW
#21
#22
#23 BaseThreadInitThunk
#24 RtlUnicodeStringToInteger
#25 RtlCaptureContext
Thanks for the support.
Please provide a Debug Log.
Good morning,
I attach a link for the Debug log in Pastebin
Dropbox link to the dmp file is Dmp log
Crash occured in atidxx32.dll so seems a driver issue. I don't know more. Try to setup in AMD Control Panel a single card for Kodi only.
Good afternoon,
when I deactivate the AMD dual graphics, and work only with the APU (a single card) Kodi runs perfect.
A single card is more than enough for Kodi.
BR,
Anton
Good afternoon,
ok, but with Kodi Isengand 15.2 works perfect with AMD Dual graphics but in Jarvis or in Isengard DX11 notHuh
I don't understand this, can the problem is the DirectX 11 migration??
