Full Version: Graphics Card Required?
Hi there, i've joined this forum because I'm struggling to find the right information anywhere!
I want to add a HD USB tuner (PCTV systems nanoStick 292e DVB-T2 tripleStick HD TV Tuner) to my microserver N54l to act as a backend and serve my intel NUC KODI frontend.
I don't have a graphics card in the N54L because I run it headless. It has windows 8 installed.
My question is would I need a graphics card for this to work properly or would the USB TV tuner on its own be suffice?
Thanks in advance.
Edit: I should also ask if you all think the processing power of the N54L is good enough?
System requirements for the TV tuner are listed as follows but i'm not too sure how accurate these are:
Microsoft Windows (8.1, 8,7,Vista, XP(32bit) ) with current service pack and 1 GB RAM
PC with 1.5GHz dual core processor for SD TV
PC with 2.6GHz multi core processor für HD TV
Hard disk with min. 1 GB free capacity (20 GB free capacity recommended)
Sound and graphics with support for DirectX® 9 or higher
USB 2.0 port
CD/DVD drive for software installation
Internet connection for software updates, activations and DistanTV
Yes, that should be fine as a headless NextPVR backend for use with Kodi.
thank you
