Anyone have any idea what information is required for the x ray feature to work? I have it working with some movies but doesnt show up for others?
<ondown condition="!IsEmpty(VideoPlayer.IMDBNumber)">RunScript(script.extendedinfo,info=extendedinfo,imdb_id=$INFO[VideoPlayer.IMDBNumber])</ondown>
As you can see -> IMDBNumber is required for your movie. If it's not correctly scrapped, it won't work.
fach1708
BTW, are the movies that work with xray stored as files locally, and the ones that don't work being streamed using an addon? I have a hunch...
(2016-03-12, 15:53)guido1138 Wrote: [ -> ]@fach1708
Yup got it in one
(2016-03-12, 16:15)fach1708 Wrote: [ -> ] (2016-03-12, 15:53)guido1138 Wrote: [ -> ]@fach1708
Yup got it in one
So is there a way to enable it globally, stream or otherwise?
I guess you know that Kodi is designed to use a local database of you videos. Most streaming addons won't even fill artworks correctly, so don't wonder why they have no IMDB number.
And one last time:
I do not give support to streaming addons and I don't wanna see any discussion right here. You guys don't name them, but everyone is aware of which addons you are talking about.
(2016-03-12, 21:10)sualfred Wrote: [ -> ]I guess you know that Kodi is designed to use a local database of you videos. Most streaming addons won't even fill artworks correctly, so don't wonder why they have no IMDB number.
And one last time:
OK just a question. Didn't mention any addons and only.did when prompted. My question was what controls.xray so I could fix it myself potentially so please, everyone, get off your high horses. FFS.
(2016-03-12, 23:33)fach1708 Wrote: [ -> ] (2016-03-12, 21:10)sualfred Wrote: [ -> ]I guess you know that Kodi is designed to use a local database of you videos. Most streaming addons won't even fill artworks correctly, so don't wonder why they have no IMDB number.
And one last time:
Oh and FYI 95% of my library is locally stored. I use 1 addon to stream movies which I have been unable to find on dvd, usually either foreign movies or niche horror movies which had a limited release like the Poughkeepie Tapes.
(2016-03-12, 09:23)sualfred Wrote: [ -> ] (2016-03-11, 22:09)fach1708 Wrote: [ -> ]That worked perfectly thanks. Is there a corresponding.widget for imdb top 250 tv shows?
If you find a way to scrap that informations to your TV shows just create a smartplaylist for it.
The addon only supports movies.
(2016-03-12, 04:09)soulshadow Wrote: [ -> ]Hi, I would like to know, How did you get the recent App's to work in Kodi FTV Skin. What Widget did you use.?
Any help welcome !!
Easy: Use, or if you don't own one, buy a Fire TV. Don't forget to close Kodi.
That's a screenshot of the Amazon device.
@all others:
You can now directly access the widget editing window by pressing the Info button ("i" on the keyboard).
Thank you for reply. I do own an Amazon Fire TV. I was referring to the other screen shot where. It says Resent Apps at the top of the kodi FTV. I was hoping you could let me know how it was done.
Any help welcome !!
I guess he just named it "Recent".
You can add all your Android apps as source for the widget by choosing it in the widget setup dialog.
soulshadow
Just named it to :"Recent" (meanwhile)
Working on some adjustment after 2.1.17 was released with "Android Apps" support
Strange. Please reset your main menu to defaults and assign the groups again
Sualfred,
I think you fixed the bug that displayed the ftv splash screen every time the widgets were updated (e.g. after stopping a movie). Thank you!
Some performance feedback:
Startup: every time I start Kodi, my TV screen is dark for 18+ seconds, followed by 5 seconds of Kodi splash screen (near instantaneous) and various FTV splash screens. If Confluence is the selected skin, I see a similar 18 seconds of darkness prior to the Confluence skin loading (i.e. 5 seconds shorter). I am still trying to isolate why Kodi itself takes 18 seconds to load.
Updating FTV from your repo: I don't receive notifications about available updates. I need to manually update all addons. When I do that, I still don't receive any notifications about available updates. After several seconds, the screen goes to black without warning for over 45 seconds. Then the new FTV skin loads.
Switching screens: from FTV, if I switch to confluence, even after confirming the switch, it stays on FTV until I do it a second time.
I am running FTV on Jarvis on Nvidia Shield over a gigabit Ethernet connection. Widget preloading is enabled. The only addons are those specified by the FTV skin. PVR is not enabled. I deleted all addon data in the userdata folder. I am only using 5 movie widgets, 3 TV widgets and a weather widget.
