Looks great
can you post a link to the tv logos you are using please?
(2017-01-05, 20:24)sualfred Wrote: [ -> ]They are selfmade and only for the channels I have mapped.
But feel free to use them:
https://github.com/sualfred/TVlogos
sualfred,i give up for change font
,when i relize that roboto font support vietnamese character.
but today when i enbale holiday theme,no thing change.can i enable it for whenever time i want?
(2017-01-06, 02:13)haicaoboi87 Wrote: [ -> ]sualfred,i give up for change font,when i relize that roboto font support vietnamese character.
It's only active during the xmas and holiday time. (1 Dec - 6 Jan)
I can't get the logos to be displayed. I went to settings, have selected the folder logos, then searched for new logos. But no of your logos gets displayed.
Kodi Version: 17 RC2 macos
Skin Version: the current one from your repo
TV-Backend: tvheadend 4.0.8 (on XPEnology)
Because you have to name it correctly or set it manually in your backend. Look at the Kodi wiki or the backend documentation.
(2017-01-06, 14:44)sualfred Wrote: [ -> ]Because you have to name it correctly or set it manually in your backend. Look at the Kodi wiki or the backend documentation.
Thanks I need to check that, maybe I should really define them on the backend
And another suggestion if it is ok for you
In the TV section in the main Menu you should not display the channels, rather display four entry points to the various TV sections like
- Channels
- Guide
- Recordings
- Timer
And within every of those windows then the view is consistent. Currently the channels in the widget and in the channels window have a different look unlike movies and TV shows.
The current channels widget could be another row, called "On Now" and it could also be adopted to show next show airing as a third row called "Up Next".
Just my thoughts about what would make it the perfect skin
Really an amazing skin, love it
Thanks for all your work, support and effort you put into this.
Wish there would be a blueish color option to make it look like a more modern version of the best skin by an awsome skin designer I ever used:
THIS SKIN
Nope, it will stay as it is.
And no to color options, sry. I don't want a customizable monster again.
(2017-01-06, 22:19)sualfred Wrote: [ -> ]Nope, it will stay as it is.
Thanks for the quick reply. Too bad no chance for changing it. Would it be possible to add maybe a second TV widget, with just those 4 shortcuts? Or is there another way I can do it with the menu customizer?
im not 100% sure what you mean but if its what i think, could you not super fave what you want as widget then set the widget to that super fave folder?
(2017-01-07, 11:00)mattcozi Wrote: [ -> ]im not 100% sure what you mean but if its what i think, could you not super fave what you want as widget then set the widget to that super fave folder?
Thanks so much for the hint to super favourites
Thaht is exactly what I need. Is it avail for Kodi v17 too?
