2015-12-22, 04:23
Hi everyone, I just recently started getting into using this client. I have a UPnP networked tuner for which I created a playlist of the channel streams, and I loaded that playlist into IPTV Simple Client. If I don't use the client and browse to the channel streams directly through the video file browser, the streams play back correctly at 29.97 frames per second. However, if I view these same channels using IPTV Simple Client, the frame rate for all channels changes to 25 fps (at least as reported by Kodi's codecinfo). Does anyone know what might be causing this?
