2015-12-24, 01:00
Hi I wonder if anyone can help me. I really love eminence skin and have used it for sometime. I installed eminence on my Intel NUC5CPYH with openelec and everything was good. Then after the machine finished updating the library and spotlight eventually fired up, the spotlight section of the screen started flickering. The bottom section where all the buttons are remain normal. I switched to the confluence skin and everything was normal. I tried the arctic zepher which I believe is related to eminence skin and the same thing happened...
I have a few options...I can reinstall openelec, reset the skin, reinstall the skin...or find some scan disk for openelec. I'm hoping that there is a switch/setting that can use instead of other drastic options. I hope someone can help. Many thanks
