2015-12-25, 17:38
2015-12-25, 17:38
2016-01-23, 21:11
I have the same problem, running Kodi with Amber skin on OSMC on a Raspberry Pi 2. I can select one of those empty items, select "(no action)" in the menu that appears and give the entry a new name, and it shows up in the home menu, but I can't figure out how to give that entry an action. A fix for this would be great!
2016-07-17, 23:06
Same problem, new clean default installation ( LE x86 )
EDIT: Until this is sorted and for other people that may be having this problem, a silly solution
1. Kodi settings > Switch to default skin
2. Browse(*) folder userdata > addon_data > skin.amber , there is a file in there with all skin settings (settings.xml)
3. Open in text editor ( i use Notepad++), scroll down, the CUSTOM MENU entries are there
4. Manually type in whatever you need each menu item to do. Optionally a label you like
Example (just an example, your case may be different):
(*) I find it easier to browse userdata folder while Kodi still running, from another PC, via network. But, of course, needs a second PC on the same network...
Quote: <setting id="CustomHome.4.Label" type="string">MY-MENU-ITEM-LABEL-HERE</setting>5. Save file, Go to Kodi settings and switch back to Amber skin. You should be able to see now all new entries in main menu
<setting id="CustomHome.4.Background" type="string"></setting>
<setting id="CustomHome.4.Path" type="string">ActivateWindow(Videos,"plugin://plugin.video.MY-VIDEO-ADDON-NAME-HERE",return)</setting>
2016-07-30, 12:50
Oh. Glad it's not just me. I have the same problem on a Minix box running Android 4.4.
