Full Version: Addons installation failed
Hello,
First, thank you for your job. I recently installed Kodi and I really like it so far.
However, I am experiencing some troubles as almost 90 percent of the addons I try to intall fail to install. For example, I tried to install Twitch.tv, and I had to install manually from a zip.file the dependencies (simplejson + xbmcswift I think). I could solve this one but for the other ones....I don't know how to fix that or why it is happening. A problem with the server?
I am sticking to the official repository and running Isengard on windows 10.
I am used to linux and all the package/repository/dependencies things but on Windows my knowledge is pretty limited...and it is kind of frustrating to see all these awesome addons (like TV5monde) and not to be able to use them....
Thank you in advance.
J.
please create a Debug Log while trying to install one of the addons.
Hello,
I tried to install Kodi log uploader but it failed, as some of the other addons. Anyway, I have found it using windows explorer.
Checking the log, it looks like some mirror issue, isn't it? I followed the link on the log and in the repo, some files are downloadable and others send an error 502 or something like this, like the fox news video plugin : http://mirrors.kodi.tv/addons/gotham/ . Right now I am in South Korea, is it related to my issue?
I cut the log to make it shorter. I hope you don't need more info.
Thank you again.
14:54:31 T:264 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:54:31 T:264 NOTICE: -----------------------------------------------------------------------
14:54:31 T:264 NOTICE: Starting Kodi (15.2 Git:20151019-02e7013). Platform: Windows NT x86 32-bit
14:54:31 T:264 NOTICE: Using Release Kodi x32 build
14:54:31 T:264 NOTICE: Kodi compiled Oct 19 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
14:54:31 T:264 NOTICE: Running on xxxxxxxxxxxxxxxxxxxx with Windows 10, kernel: Windows NT x86 64-bit version 10.0
14:54:31 T:264 NOTICE: Host CPU: Intel® Core™ i5-4210M CPU @ 2.60GHz, 4 cores available
14:54:31 T:264 NOTICE: Desktop Resolution: 1920x1080 32Bit at 59Hz
14:54:31 T:264 NOTICE: Running with restricted rights
14:54:31 T:264 NOTICE: Aero is enabled
14:54:31 T:264 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
14:54:31 T:264 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
14:54:31 T:264 NOTICE: special://masterprofile/ is mapped to: C:\Users\xxxxxxxxxx\AppData\Roaming\Kodi\userdata
14:54:31 T:264 NOTICE: special://home/ is mapped to: C:\Users\xxxxxxxxxx\AppData\Roaming\Kodi\
14:54:31 T:264 NOTICE: special://temp/ is mapped to: C:\Users\xxxxxxxxxx\AppData\Roaming\Kodi\cache
14:54:31 T:264 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
14:54:31 T:264 NOTICE: Local hostname: xxxxxxxxxx
14:54:31 T:264 NOTICE: Log File is located: C:\Users\Owner\AppData\Roaming\Kodi\kodi.log
14:54:31 T:264 NOTICE: load settings...
14:54:31 T:6564 NOTICE: Thread CWin32PowerStateWorker start, auto delete: false
14:54:31 T:264 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
14:54:31 T:264 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
14:54:31 T:264 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
14:54:31 T:264 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
14:54:31 T:264 NOTICE: Default DVD Player: dvdplayer
14:54:31 T:264 NOTICE: Default Video Player: dvdplayer
14:54:31 T:264 NOTICE: Default Audio Player: paplayer
14:54:31 T:264 NOTICE: Disabled debug logging due to GUI setting. Level 0.
14:54:31 T:264 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
14:54:31 T:264 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
14:54:31 T:264 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:54:31 T:264 NOTICE: Loaded playercorefactory configuration
14:54:31 T:264 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:54:31 T:264 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:54:31 T:5864 NOTICE: Thread ActiveAE start, auto delete: false
14:54:31 T:1376 NOTICE: Thread AESink start, auto delete: false
14:54:31 T:5864 NOTICE: Found 2 Lists of Devices
14:54:31 T:5864 NOTICE: Enumerated DIRECTSOUND devices:
14:54:31 T:264 NOTICE: Running database version Addons19
14:54:31 T:264 NOTICE: ADDONS: Using repository repository.xbmc.org
14:54:31 T:2844 NOTICE: Thread RemoteControl start, auto delete: false
14:54:31 T:264 NOTICE: Found screen: Generic PnP Monitor on Intel® xxxxxxxxxx, adapter 0.
14:54:31 T:264 NOTICE: Primary mode: 1920x1080@ 59.94 - Full Screen
14:54:31 T:264 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
14:54:31 T:264 NOTICE: Checking resolution 16
14:54:31 T:264 ERROR: XFILE::CDirectory::Create - Error creating C:\Program Files (x86)\Kodi\sounds
14:54:31 T:264 ERROR: XFILE::CDirectory::Create - Error creating special://xbmc/sounds
14:54:31 T:4044 NOTICE: Thread PeripBusCEC start, auto delete: false
14:54:31 T:3360 NOTICE: Thread PeripBusUSB start, auto delete: false
14:54:31 T:264 NOTICE: Running database version ViewModes6
14:54:31 T:264 NOTICE: Running database version Textures13
14:54:31 T:264 NOTICE: Running database version MyMusic52
14:54:31 T:264 NOTICE: Running database version MyVideos93
14:54:31 T:264 NOTICE: Running database version TV29
14:54:31 T:264 NOTICE: Running database version Epg10
14:54:31 T:264 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
14:54:31 T:264 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
14:54:31 T:264 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
14:54:31 T:264 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
14:54:31 T:6940 NOTICE: Thread LanguageInvoker start, auto delete: false
14:54:31 T:264 NOTICE: initialize done
14:54:31 T:264 NOTICE: Running the application...
14:54:31 T:5112 NOTICE: Thread JobWorker start, auto delete: true
14:54:31 T:264 NOTICE: starting upnp client
14:54:31 T:264 NOTICE: ES: Starting event server
14:54:31 T:6212 NOTICE: Thread EventServer start, auto delete: false
14:54:31 T:6212 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
14:54:31 T:7412 NOTICE: Thread TCPServer start, auto delete: false
14:54:31 T:6212 NOTICE: UDP: Listening on port 9777
14:54:31 T:6868 NOTICE: Thread RSSReader start, auto delete: false
14:54:31 T:5752 NOTICE: Thread JobWorker start, auto delete: true
14:54:31 T:6940 NOTICE: -->Python Interpreter Initialized<--
14:54:32 T:6716 NOTICE: Thread JobWorker start, auto delete: true
14:54:40 T:7268 NOTICE: Thread BackgroundLoader start, auto delete: false
14:54:47 T:7644 NOTICE: Previous line repeats 1 times.
14:54:47 T:7644 NOTICE: Thread JobWorker start, auto delete: true
14:54:58 T:6728 NOTICE: Thread FileCache start, auto delete: false
14:55:01 T:4460 NOTICE: Thread BackgroundLoader start, auto delete: false
14:55:11 T:5748 NOTICE: Thread FileCache start, auto delete: false
14:55:15 T:880 NOTICE: Thread BackgroundLoader start, auto delete: false
14:55:30 T:412 NOTICE: Thread FileCache start, auto delete: false
14:55:33 T:6440 NOTICE: Thread BackgroundLoader start, auto delete: false
14:55:57 T:320 NOTICE: Thread FileCache start, auto delete: false
14:56:02 T:5752 NOTICE: Previous line repeats 1 times.
14:56:02 T:5752 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 502
14:56:02 T:5752 ERROR: CCurlFile::Open failed with code 502 for http://mirrors.kodi.tv/addons/gotham/scr...-1.2.4.zip
14:56:02 T:5752 ERROR: CAddonInstallJob[script.module.beautifulsoup4]: failed to download special://home/addons/packages/script.module.beautifulsoup4-4.3.2.zip
14:56:02 T:5752 ERROR: CAddonInstallJob[plugin.video.espn_3]: failed to install dependency script.module.beautifulsoup4
14:56:02 T:4972 NOTICE: Thread BackgroundLoader start, auto delete: false
14:56:18 T:788 NOTICE: Thread FileCache start, auto delete: false
14:56:19 T:5752 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 502
14:56:19 T:5752 ERROR: CCurlFile::Open failed with code 502 for http://mirrors.kodi.tv/addons/gotham/plu...-4.0.4.zip
14:56:19 T:5752 ERROR: CAddonInstallJob[plugin.video.fox.news]: failed to download special://home/addons/packages/plugin.video.fox.news-4.0.4.zip
14:56:20 T:5952 NOTICE: Thread BackgroundLoader start, auto delete: false
14:56:29 T:7644 WARNING: JpegIO: Error 53: Not a JPEG file: starts with 0x%02x 0x%02x
14:56:42 T:1956 NOTICE: Thread FileCache start, auto delete: false
14:56:43 T:5112 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 502
14:56:43 T:5112 ERROR: CCurlFile::Open failed with code 502 for http://mirrors.kodi.tv/addons/gotham/plu...-0.0.4.zip
14:56:43 T:5112 ERROR: CAddonInstallJob[plugin.video.linuxgamecast]: failed to download special://home/addons/packages/plugin.video.linuxgamecast-0.0.4.zip
14:56:43 T:7672 NOTICE: Thread BackgroundLoader start, auto delete: false
14:57:19 T:5456 NOTICE: Thread FileCache start, auto delete: false
14:57:20 T:5112 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 502
14:57:20 T:5112 ERROR: CCurlFile::Open failed with code 502 for http://mirrors.kodi.tv/addons/gotham/plu...5.0.10.zip
14:57:20 T:5112 ERROR: CAddonInstallJob[plugin.video.popcornflix]: failed to download special://home/addons/packages/plugin.video.popcornflix-5.0.10.zip
14:57:20 T:6600 NOTICE: Thread BackgroundLoader start, auto delete: false
14:57:26 T:7708 NOTICE: Thread FileCache start, auto delete: false
14:57:31 T:8040 NOTICE: Thread BackgroundLoader start, auto delete: false
14:57:54 T:5112 ERROR: dll_fgets emulated function failed
14:58:02 T:7200 NOTICE: Thread FileCache start, auto delete: false
14:58:03 T:6716 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 502
14:58:03 T:6716 ERROR: CCurlFile::Open failed with code 502 for http://mirrors.kodi.tv/addons/gotham/plu...-1.1.1.zip
14:58:03 T:6716 ERROR: CAddonInstallJob[plugin.video.guardian]: failed to download special://home/addons/packages/plugin.video.guardian-1.1.1.zip
14:58:03 T:7188 NOTICE: Thread BackgroundLoader start, auto delete: false
14:58:15 T:6844 NOTICE: Thread FileCache start, auto delete: false
14:58:15 T:6716 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 502
14:58:15 T:6716 ERROR: CCurlFile::Open failed with code 502 for http://mirrors.kodi.tv/addons/gotham/plu...-1.1.2.zip
14:58:15 T:6716 ERROR: CAddonInstallJob[plugin.video.tv5monde]: failed to download special://home/addons/packages/plugin.video.tv5monde-1.1.2.zip
14:58:16 T:3068 NOTICE: Thread BackgroundLoader start, auto delete: false
14:58:36 T:264 NOTICE: Storing total System Uptime
14:58:36 T:264 NOTICE: Saving settings
14:58:36 T:264 NOTICE: stop all
14:58:37 T:264 NOTICE: stop player
14:58:37 T:264 NOTICE: ES: Stopping event server
14:58:37 T:264 NOTICE: stopping upnp
14:58:37 T:6212 NOTICE: ES: UDP Event server stopped
14:58:38 T:264 NOTICE: stop sap announcement listener
14:58:38 T:264 NOTICE: clean cached files!
14:58:38 T:264 NOTICE: unload skin
14:58:38 T:264 NOTICE: stopped
14:58:38 T:264 NOTICE: destroy
14:58:38 T:264 NOTICE: closing down remote control service
14:58:38 T:264 NOTICE: unload sections
14:58:38 T:264 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:58:38 T:264 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
14:58:38 T:264 NOTICE: application stopped...
14:58:38 T:264 ERROR: dllFreeLibrary - Invalid hModule specified
Please use pastebin or XBMClogs for debug logs as per the instructions @ronie linked to above rather than putting cut down versions into the forum directly.
Also this thread may be worth a read as it sounds like the same issue.
Hello,
Sorry for the log, I did not find the way to do it, that is why I submitted it like that.
As for the thread, yes, it sounds the same, and as far as I see, it is not fixed yet. I guess I will wait to go back to Europe, it will be easier that way.
Thank you.
