2015-12-26, 18:10
just to check if its me this cant be run ?
I manage to install prismatik and run it, all works fine it lights up an all but everything while I'm logged in to the desktop.
when i start kodi prismatik didn't run,i cant even connect to the API and when i try to run it manually via terminal it shows this error:
PHP Code:
xbmc-station@xbmc-station:/etc/xdg/autostart$ prismatik
/etc/xdg/autostart/main.conf
Unportable version
Application directory: /home/xbmc-station/.Prismatik
Rename log: "/home/xbmc-station/.Prismatik/Logs/Prismatik.3.log" to "/home/xbmc-station/.Prismatik/Logs/Prismatik.4.log"
Rename log: "/home/xbmc-station/.Prismatik/Logs/Prismatik.2.log" to "/home/xbmc-station/.Prismatik/Logs/Prismatik.3.log"
Rename log: "/home/xbmc-station/.Prismatik/Logs/Prismatik.1.log" to "/home/xbmc-station/.Prismatik/Logs/Prismatik.2.log"
Rename log: "/home/xbmc-station/.Prismatik/Logs/Prismatik.0.log" to "/home/xbmc-station/.Prismatik/Logs/Prismatik.1.log"
Logs file: "/home/xbmc-station/.Prismatik/Logs/Prismatik.0.log"
12:05:43:076 Fatal: QXcbConnection: Could not connect to display
