:hi all, am using a 4ife stick. Have been trying to download KODI through plays store. When I initiate the download.it keeps telling me your device is not compatible with this version. Any ideas out there....jhaye2x
Kodi Isengard needs at least Android 4.2 to work. From a quick search on the net I think your stick is only Android 4.1.1 .
So if you want Kodi, you'll either have to find some way to update your Android, use a different device with newer Android on it or side load an older version of Kodi (although support there will be limited and some add-ons may not work).
