2015-12-28, 18:11
Hi all,
I've some playback issues with vido files generated by a Panasonic HC-X909EG Camcorder.
Seems to be audio issue - because the video works well without the audio stream.
Could it be a problem that the video uses 50p fps and audio only 21.250 fps ?
Or is my FireTV to weak to playback the original 50p Files ?
I uses Kodi 15.1 on my FireTV.
Jens
Mediainfo :
Jens
Mediainfo :
Quote:c:\temp\mediainfocli>MediaInfo.exe z:\video\00006.MTS
General
Complete name : z:\video\00006.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 319 MiB
Duration : 1mn 46s
Overall bit rate mode : Variable
Overall bit rate : 25.1 Mbps
Maximum Overall bit rate : 28.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=24
Codec ID : 27
Duration : 1mn 46s
Bit rate mode : Variable
Bit rate : 23.7 Mbps
Maximum bit rate : 25.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.229
Stream size : 301 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 1mn 46s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Compression mode : Lossy
Delay relative to video : -40ms
Stream size : 4.88 MiB (2%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 1mn 46s
