MaDDoGo Wrote:Please post some log so I can know what happen. You have to post it in debug mode.
Thank You...
First of all I want to thank you very very much for your effort doing runnable this scaper.
Here is my log
http://pastebin.com/6ivVr2KE
See you soon
PS : I've tested cinEOL scraper but I got some errors. I'll try it again and post the errors. Thanks for this scraper too
Thanks for posting logs so I can know what happens:
@nabz: Your problem is that google takes a bad search (and I have to say you that I don't know why because I have this movie scraped well). It makes this search and takes The Marine 2 (I also don't know why it doesn't take well :S)
@fidoboy: You have to configure the scrapper. It doesn't take nothing from iMDB. And I think you don't have the new version of the scraper. Please take the latest I uploaded and test it again...
Thanks! It works fine now, i think that something was misconfigured after last XBMC update, i didn't touch anything from scrapper config since the first time... Any case, it's working fine now.
regards,
Thanks MaDDoGo,
i'll try with another movie and report it.
See you!
It works again! I probably did something wrong but it is back online and working. Rgds,
Ignacio
It is working really good.
I would like to have "originaltitle + (title)" would this be possible?
I manage to show only originaltitle, just changing:
output="<entity><title>\1 (\2)</title><
to:
output="<entity><originaltitle>\1 (\2)</originaltitle><
But I would like to show both of them.
I have a problem with Filmaffinity scraper, I can't play trailers. I have tried with this movie "Angeles y demonios" wich worked right before and here is the log:
click
I have the last stable official version 9.11
Thank you for your incredible job
hello,Now I have the same problem with you with the fanart.
Please can any tell me where I can find the lines to modify in the xml? or the new filmaffinity.xml?
Gracias a todos.
@bourbon79: D don't know what happens, the only thing I know is that filmaffinity has this URL to the trailer:
http://www.yobajo.com/watch?v=TP6tFFk83Jw
And you must update your scraper for having the plot back
calibra3 Please, use the option "Usar trazas de depuración" in XBMC options and then please upload %appdata%/XBMC/log.txt to pastebin so I can view what happens to you
@leolo: I will look for it and put here what you have to do for having info this way
For anyone who doesn't know how to change the scraper or doesn't know what is last version I uploaded it again because it became lost on lightning strike
http://pastebin.com/Nzu7acHw
thanks maddogo, I test it your filmaffinity file in you pastebin link with good luck.
I am happy than to you.
@itombs: Please, post a log file with debug enabled and list a movies list so I can try this. Thank You.
With this version I have problems with "argumento" and "poster", thanks maddogo for your work
MaDDoGo Wrote:@itombs: Please, post a log file with debug enabled and list a movies list so I can try this. Thank You.
http://pastebin.com/JVrsSVFA
Another thing I miss in the new version of filmaffinity is the countryu of the film.
In the old version in eslogan apperas "España- Titulo de la pelicula", ahora podria aparecer "España - Eslogan de la pelicula"
Thanks a lot.
