Many thanks, cause i'm going crazy trying to understand how the scrapper works. Can u post here the file?
thanks,
It works fine now, but trailers do not play...
They were working in the previous version?
Replace the scrapers and give it a try
I've tested it using the previous scraper version and it doesn't work. So it was not working before your changes...
nose ingles, pero si algun español de los k se pasan por aki me lo traducen, tengo un problema con los scrapers y es k solo me busca solo 1 miniatura.
not English, but if any of the Spanish overlooked k aki me translate it, I have a problem with Scrapers and k is just me looking for only 1 thumb.
Hola filete, lo que pone en los post anteriores al tuyo, es justo eso, la solucion es que descargues el nuevo scrapper aqui:
http://trac.xbmc.org/export/21923/branch...finity.xml o bien que actualices tu XBMC usando la ultima version SVN, con eso esta solucionado.
Salu2,
fidoboy Wrote:Hola filete, lo que pone en los post anteriores al tuyo, es justo eso, la solucion es que descargues el nuevo scrapper aqui: http://trac.xbmc.org/export/21923/branch...finity.xml o bien que actualices tu XBMC usando la ultima version SVN, con eso esta solucionado.
Salu2,
Wenas ya me baje ese scraper y nada no me lo soluciona, y la 2 opcion no se lo k es.
vdrfan Wrote:English please, thanks.
Sorry pero porfavor dar soporte al idioma español
Uhm, you want me to use a online translation tool? Please respect our forum rules!
Salu2,
Hola, yo me he bajado esa version y sigue sin descargarme ams de una caratula.
Hi, i downloaded this version but only appers one thumb (imdb thumb).
Any solution?
And in the new version, problem with actors continues.
