2015-12-29, 16:04
Well, the subject states it:
I have a Kodi Database with attached storage (NAS) shares - a long time ago, I had to export/import databases, and had to do that using the "export to multiple files" option, then re-import from there.
The only issue I had with this is, that my media folders were (obviously) spammed with jpgs, nfo files etc. etc. which made the folders almost un-navigatable by normal PC browsing, so I wished to remove
all the files again, as I expected them to be "imported" to Kodi texture cache as they would have been with online artwork... so I removed everything. And now (silly me) almost all my movies are missing
posters, fanart etc... and the only way to get them back is the tried and true "refresh every single movie / series manually" approach, as that replaces the local URLs with online ones, but you can't force that
on the whole library without doing a rescrape, which would kill a lot of my manual edits (wrongly scraped stuff) and lose me the watched status entries... I also thought about just removing the (now empty-pointing) local
URLs from the Database directly using SQL, but that would be no good, as that would just leave it without an online URL and still not pull any fanart in... another Idea I thought would be to export (again) to multiple files,
delete the database, (set the advancedsettings import watched state flag), delete all the locally exported jpgs/pngs, and THEN re-import the database again so that it pulls all the info from online again...
anyone have a better Idea for what I'm planning to do? If it matters, it is a NAS-based setup with three KODI-machines using centralized MySQL storage. And no, keeping ANY files besides the .mkv / .avi / etc. in the folders is not acceptable. For that reason, I can't use Artwork Downloader for example...
