2015-12-30, 03:36
I have a python script that turns my samsung TV on. Some of the fine folks here helped me out and its been working great. I even wrote about it on my blog: http://knightcinema.com/2015/09/08/samsu...onnection/
After re-configuring some wiring my serial controller sometimes stops working. I found a script that restarts it and it works well, but its not in python. Im not totally sure of the language, maybe c++.
I would like to only run it if the serial communication fails. This is the error:
I would be happy if it ran every time, it happens almost instantly.
Thanks in advanced for any help.
This is the python script. I have several but the only difference is the hex code sent.
kodi@server:~/data/scripts$ ./tvon.py
File "./tvon.py", line 4, in <module>
ser = serial.Serial(port='/dev/ttyUSB0', baudrate=9600, timeout=1)
File "/usr/lib/python2.7/dist-packages/serial/serialutil.py", line 261, in __init__
self.open()
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 278, in open
raise SerialException("could not open port %s: %s" % (self._port, msg))
serial.serialutil.SerialException: could not open port /dev/ttyUSB0: [Errno 5] Input/output error: '/dev/ttyUSB0'
#!/usr/bin/env python
import time, serial
resp=""
loop="true"
string="030cf100"
while loop:
if string in resp:
print "found it"
break
ser.close()
else:
ser.write("\x08\x22\x00\x00\x00\x02\xd4")
data = ser.read(24)
resp=data.encode('hex')
print resp
time.sleep(1)
print "finished"
