Full Version: [RELEASE] Flix2Kodi - Just another Netflix-Addon
reinstall kodi, addon and work!!!!! thx great addon Wink
win10 x64 koran pack,
Had lots of problems ever since the last API change, resetting the cache and cookies didn't help. Now i've chosen to reset the addon and it started working again. Maybe someone can use this advise Smile
Also having issues here with the login bug. I'm running Kodi 16.0 on Windows 10 Pro x64, Arctic Zephyr: From Ashes skin.
Hi.
I'm using Kodi on OpenElec 6.0.199 (Intel_EGL) - Chromium was installed correctly and Flix2Kodi too. (Chromium is working well) I've setup Flix2Kodi and I have access to my NetFlix account (I can browse the content) - but when I'm selecting any movie/TV show screen just flashing (sometimes I can see message for half of sec - "If your browser does not lauch ...") but no browser and no playback is starting.
Is there any solution for this issue?
Regards Chris
(2016-03-27, 20:39)filemoon Wrote: [ -> ]Hi.
Regards Chris
with or without the chromium launcher plugin?
either way check in the chromium launcher scripts inside the flix2 or launcher plugin if the path-to-chromium is valid, probably not if you ar using openelec...
Hello,
After osmc, I have installed kodi on my raspbian (for pi2). I tought it would work better since there is an X server with raspbian. However, it seems to fail to launch the chromium.sh script from kodi(I have added some log) while it works if I just run it directly from the terminal in raspbian.
I'm not sure this code is working on pi:
process = subprocess.Popen(callstr, startupinfo=info, shell=True)
If I replace this by
subprocess.check_call(callstr, startupinfo=info, shell=True)
I get a return code 1...
(2016-03-23, 10:35)basco Wrote: [ -> ]
(2016-03-23, 03:10)bjarque Wrote: [ -> ]
(2016-03-03, 10:00)laukarlueng Wrote: [ -> ]Can't find the launchBrowser.sh. Do I need to create it or modify a different file?
Go to /addons/plugin.video.flix2kodi/resources/scripts/launcher/linux/chromelauncher.sh and do the changes. Worked for me.
If you want audio, add "--alsa-output-device=plughw:0,8" just before the "$url" part in the line that launches chrome. 0,8 is your output device from aplay -l, change it to what your audio output device is.
mind you that if you use --alsa.... when returning to kodi, you might not always have sound.
and you should disable 'keep audio alive (or something)' in kodi, because this hijacks the audio device and --alsa will not work (keep it at never or once a minute for roulette style audio :o) )
when you force video with edid this issue should not occur.
Yoǘre right, i do lose sound when returning. What do you mean by forcing video with edid?
(2016-04-01, 00:51)bjarque Wrote: [ -> ]
(2016-03-23, 03:10)bjarque Wrote: [ -> ]Go to /addons/plugin.video.flix2kodi/resources/scripts/launcher/linux/chromelauncher.sh and do the changes. Worked for me.
forcing edid means that your oe or kodi box does not read the edid screen info from the receiver/tv but forces tv standards read from a file in xorg.conf (edid.bin).
you can generate an edid.bin file for your tv/receiver like this:
kodi:
http://kodi.wiki/view/Creating_and_using..._xorg.conf
oe:
http://wiki.openelec.tv/index.php?title=...DID_nvidia
b.t.w. if you are in europe and use live tv, also add the 1080x1920_50 as the first item in the modes section of xorg.conf.
netflix will stutter @ 50 Hz so you should also change the chromium.sh or whatever script you use to launch chromium to switch refresh rate from 50 hz to 24 hz and back when you exit flix:
xrandr --output HDMI-0 --mode 1920x1080 --rate 23.976
and when returning
xrandr --output HDMI-0 --mode 1920x1080 --rate 50
this is however semi optimal, but hte best you can achieve so far.... because netflix has some streams for european market that are 25 hz... this will cause a slight stutter.
OR
you can use 60 Hz fixed for everything (live tv, flix etc), this will cause slight stuttering also...
appletv does this
i've tried to install flix2kodi on my box T95 S905.
The installation was ok but when i try lo watch a video, i obtain the error 'Error Launching browser'
Any suggestion?
PS: excuse me for my poor skill, but how can i access to the box to find the logfile?
regards
killian
Hi all, I installed flix2kodi and it seems to work but I encounter login issue. The addon ask for the login repeatedly. I noticed also that I have some trouble with the double account. It ask repeatedly if I'm user 1 or user 2
Is there any way to solve?
(2016-03-12, 00:39)Stin Wrote: [ -> ]I've followed the instruction and I can log into my netflix account through flix2kodi but when I click on something to watch, it looks like its trying to load the show but it just returns to the list.
If anyone can please help, I would very much appreciate it.
Here is the output to the log when the problem happens:
22:23:53 T:140601973278464  NOTICE:         m_deviceName      : default
22:23:53 T:140601973278464  NOTICE:         m_displayName     : Default (HDA ATI HDMI HDMI 0)
22:23:53 T:140601973278464  NOTICE:         m_displayNameExtra:
22:23:53 T:140601973278464  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
22:23:53 T:140601973278464  NOTICE:         m_channels        : FL,FR,BL,BR,FC,LFE,SL,SR
22:23:53 T:140601973278464  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,176400,192000
22:23:53 T:140601973278464  NOTICE:         m_dataFormats     : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
22:23:53 T:140601973278464  NOTICE:     Device 2
22:23:53 T:140601973278464  NOTICE:         m_deviceName      : hdmi:CARD=HDMI,DEV=0
22:23:53 T:140601973278464  NOTICE:         m_displayName     : HDA ATI
22:23:53 T:140601973278464  NOTICE:         m_displayNameExtra: HDMI
22:23:53 T:140601973278464  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
22:23:53 T:140601973278464  NOTICE:         m_dataFormats     : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
22:23:53 T:140601964885760    INFO: CActiveAESink::OpenSink - initialize sink
22:23:53 T:140601964885760   DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:default
22:23:53 T:140601964885760    INFO: CAESinkALSA::Initialize - Attempting to open device "default"
22:23:53 T:140601964885760    INFO: CAESinkALSA::Initialize - Opened device "default"
22:23:53 T:140601964885760    INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
22:23:53 T:140601964885760    INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
22:23:53 T:140601964885760   DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
22:23:53 T:140601964885760   DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
22:23:53 T:140601964885760   DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
22:23:53 T:140601964885760   DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
22:23:53 T:140601964885760   DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR
22:23:53 T:140601964885760   DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR (ALSA: FL FR)
22:23:53 T:140601964885760   DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
22:23:53 T:140601964885760   DEBUG:   Output Device : Default (HDA ATI HDMI HDMI 0)
22:23:53 T:140601964885760   DEBUG:   Sample Rate   : 44100
22:23:53 T:140601964885760   DEBUG:   Sample Format : AE_FMT_S32NE
22:23:53 T:140601964885760   DEBUG:   Channel Count : 2
22:23:53 T:140601964885760   DEBUG:   Channel Layout: FL,FR
22:23:53 T:140601964885760   DEBUG:   Frames        : 2048
22:23:53 T:140601964885760   DEBUG:   Frame Samples : 4096
22:23:53 T:140601964885760   DEBUG:   Frame Size    : 8
22:23:53 T:140601973278464   DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
22:23:53 T:140601544697600   DEBUG: RunQuery took 0 ms for 0 items query: select * from movieview
22:23:53 T:140601544697600   DEBUG: RunQuery took 1 ms for 0 items query: select * from episodeview
22:23:53 T:140602444220352   DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
22:23:53 T:140602444220352   DEBUG: ------ Window Init () ------
22:23:53 T:140602444220352   DEBUG: Activating window ID: 10025
22:23:53 T:140602444220352   DEBUG: ------ Window Deinit () ------
22:23:53 T:140601433507584    INFO: CPythonInvoker(23, /home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py): script successfully run
22:23:53 T:140601433507584    INFO: CPythonInvoker(23, /home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py): waiting on thread 140601544697600
22:23:53 T:140602444220352   DEBUG: ------ Window Init (MyVideoNav.xml) ------
22:23:53 T:140602444220352   DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.flix2kodi/?mode=list_episodes&series_id=70299043&url=1)
22:23:53 T:140602444220352   DEBUG:   ParentPath = [plugin://plugin.video.flix2kodi/?mode=list_episodes&series_id=70299043&url=1]
22:23:53 T:140602444220352   DEBUG: StartScript - calling plugin Flix2Kodi('plugin://plugin.video.flix2kodi/','17','?mode=list_episodes&series_id=70299043&url=1')
22:23:53 T:140602444220352   DEBUG: WaitOnScriptResult - waiting on the Flix2Kodi (id=24) plugin...
22:23:53 T:140601425114880  NOTICE: Thread LanguageInvoker start, auto delete: false
22:23:53 T:140601425114880    INFO: initializing python engine.
22:23:53 T:140601425114880   DEBUG: CPythonInvoker(24, /home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py): start processing
22:23:53 T:140601425114880  NOTICE: -->Python Interpreter Initialized<--
22:23:53 T:140601425114880   DEBUG: CPythonInvoker(24, /home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py): the source file to load is "/home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py"
22:23:53 T:140601425114880   DEBUG: CPythonInvoker(24, /home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py): setting the Python path to /home/nas/.kodi/addons/plugin.video.flix2kodi:/home/nas/.kodi/addons/script.module.requests/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
22:23:53 T:140601425114880   DEBUG: CPythonInvoker(24, /home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py): entering source directory /home/nas/.kodi/addons/plugin.video.flix2kodi
22:23:53 T:140601425114880   DEBUG: CPythonInvoker(24, /home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py): instantiating addon using automatically obtained id of "plugin.video.flix2kodi" dependent on version 2.1.0 of the xbmc.python api
22:23:53 T:140602444220352   ERROR: Control 503 in window 10025 has been asked to focus, but it can't
22:23:53 T:140601425114880    INFO: CPythonInvoker(24, /home/nas/.kodi/addons/plugin.video.flix2kodi/addon.py): script successfully run
22:23:53 T:140602444220352   DEBUG: WaitOnScriptResult- plugin returned successfully
22:23:53 T:140601416722176  NOTICE: Thread BackgroundLoader start, auto delete: false
22:23:53 T:140601416722176   DEBUG: Thread BackgroundLoader 140601416722176 terminating
22:23:53 T:140601425114880    INFO: Python script stopped
22:23:53 T:140601425114880   DEBUG: Thread LanguageInvoker 140601425114880 terminating
22:23:53 T:140601433507584    INFO: Python script stopped
22:23:53 T:140601433507584   DEBUG: Thread LanguageInvoker 140601433507584 terminating
22:23:54 T:140602444220352   DEBUG: ------ Window Init (Pointer.xml) ------
22:24:03 T:140602444220352    INFO: Python, unloading python shared library because no scripts are running anymore
22:24:03 T:140602444220352   DEBUG: UnloadExtensionLibs, clearing python extension libraries
22:24:04 T:140602444220352   DEBUG: ------ Window Deinit (Pointer.xml) ------
(2016-03-14, 21:51)logi85 Wrote: [ -> ]Hi, just uploaded version 0.5.9, please read changelog @ first page.
@tmdb: marcelveldt uploaded a version which uses skinhelper. will test it and release in a few days(weeks?)
@metate: thx
@vulpecula: removed
@mhoogenbosch: please try again, and supply logfile if not works
@Reaper_1980: it should be backspace, with openelec I cannot help, but search in thread, someone wrote something about at some page ;-)
@mrfreddy: sounds like you're missing a window-manager, please search in this thread. about login, please try again with new version. I guess you use linux, so the settings-folder would be ~/.kodi/userdata/addon_data/plugin.video.flix2kodi , and the logfile ~/.kodi/temp/kodi.log
@dorf: integrated your changes, please checkout in new version. thx for supplying changes
@stin: please try again with new version. please try also to press enter instead of clicking.
@msj33: kids-profiles should work now
@vizoere: should work now
@all others: if you wait for an answer for a question posted before last post by me, please post again. I can only read from last post to current time.
/logi85
Hello Logi85,
I just managed to retry this today, using 0.6.0. I get the same issue. I tried clicking and pressing enter with the same effect each time.
The screen changes as if something is about to load, and then I get brought back to the selection screen.
@Stin
Look at myposts for paths in this thread
(2016-03-15, 21:56)marcelveldt Wrote: [ -> ]
(2016-03-15, 14:31)horstepipe Wrote: [ -> ]is there a way to fix the "Flix2Kodi just crashed" message on every Kodi startup? After refreshing the login it works.
I submitted a patch to logi85 for that. This same patch will also fix the artwork.
Will be included soon
@logi85
Any indication when this will be fixed?
Hello I am brand new to kodi and still a bit "noobish" on linux(kodiubuntu). I have the plugin all installed and configured as best as I can tell. I had previously installed and the uninstalled netflixbmc. all my profiles come up, all the content seems to be there but when you go to launch any video the screen just flashes and then nothing else happens. I have had a few messages pop up while navigating some of the menus telling me to check logs but I am not certain where those are located as well to post here. Any initial thoughts?
Hi kodi I have an account with two profile.
Every time I try to open movie list or other stuff related to a profile the addon crash, ask to login again ethat's it. Nothing happen. I can't see anything.
Is it a problem retaed to the two profile?
Thanks for any replay
