I notice a long "loading" when I enter My List, or enter in some genre.
It´s Normal? Or I need to delete some folders?
(2016-05-14, 18:59)sagrath Wrote: [ -> ]I notice a long "loading" when I enter My List, or enter in some genre.
Did you enable the "Get covers and fanart images from TMDB" setting ?
That one retrieves all artwork from TMDB and fanart.tv but at first enter it will be slow (as the images are retrieved). Caching is applied so the next time you enter it, it will be faster.
Yes, I enable Get covers and fanart from TMDB.
Good to know.
And by the way, FANTASTIC work Marcelvedt.
Does anyone else experience the color flipping problem? When I launch a video via Flix2Kodi, either the video OR the rest of the evironment (Kodi, other apps, Windows task bar, etc.) has the colors changed around, e.g., red becomes blue, as in the screen shot:
http://picpaste.com/WP_20160517_14_59_20...VgLFcW.jpg
Windows 10
Kodi 16.1
Radeon R9 280 GPU
Chrome 50.0.2661.102 m
Also, is it possible to close the video with the controller? Press Alt+F4 isn't THAT inconvenient in the grand scheme of things, but...
Can anyone help me to configure it in a nvidia shield tv?
LARQ
Whats your difficult?
If you tell us what exactly do you need, it´s become more easier to help you.
dorf helped me.
In one nvidia shield tv I was using the native app of netflix instead of the phone app.
Now its working fine.
no one is experiencing slow behaviour during metadata download with or without "get cover fanart from TMDb"?
with this enabled for me is endless if i try to browse all show (i have default 100 items per pages) if i disable TMDb feature i seems slow then before.
Peppe
I notice a slow using "get covers...." ON, not tested with OFF. And I realized that the more items in the list , the longer to load, but the second time , it no longer takes so . I do not mind if the addon had an option to save the arts and metadata . So we could get the context menu with C , and select "download metadata" , and thus the data for that item would be saved. Just an idea.
(2016-05-20, 09:24)peppe_sr Wrote: [ -> ]no one is experiencing slow behaviour during metadata download with or without "get cover fanart from TMDb"?
Peppe
It will be slow when metadata lookup is enabled, offcourse because the data has to be downloaded from the internet.
Without metadata lookup it will be pretty fast as only the details from netflix are used.
One word: Amazing
Thank you! Really a wonderful experience using Netflix via Kodi in my NVIDIA Shield Portable
Kudos from Portugal!
anthonws.
hi logi, should be possible add "ListItem.TVShowTitle" to use the recap addon from flix2kodi
here the
addon thread and the
hint of robwebset
(2016-05-23, 15:21)peppe_sr Wrote: [ -> ]hi logi, should be possible add "ListItem.TVShowTitle" to use the recap addon from flix2kodi
here the addon thread and the hint of robwebset
That should be set when you use the latest version (with my modifications included)...
