Full Version: [RELEASE] Flix2Kodi - Just another Netflix-Addon
Thank you for the changes to those 4 files from post 880. After editing the files on my LibreElec installation, the errors disappeared, I was able to log in, browse etc.
However, I'm now having a problem when the Chromium browser launches that didn't used to be an issue. I'm getting an error message caused by SSL the site certificate, saying that "Your connection is not private" or "NET::ERR_CERT_AUTHORITY_INVALID" or something like that.
When I type http://www.netflix.com into the address bar in the Chromium browser, I get the same error . Clicking on the https: icon with the error, it tells me that the page is insecure and there is a site certificate error. I can view the certificate. It looks valid, and it's good until November 2nd, 2018. But the error says:
NET::ERR_CERTIFICATE_TRANSPARENCY_REQUIRED
When I try it on my windows machine, using Chrome, it works fine. The certificate looks the same on the Windows version of Chrome as on the Kodi box, same serial number, same effective dates, same version etc.
I cleared cache and cookies on the Kodi box, also made sure date and time were correct. So why is Chromium on the LibreElec box choking on the SSL certificate, and how do I fix it?
(2017-01-09, 03:38)rjames0705 Wrote: [ -> ]Hi,
What am i doing wrong? I keep getting the following error:
Quote:20:27:50 T:140019406722816 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: lolomos not found in: {}
File "/home//.kodi/addons/plugin.video.flix2kodi/addon.py", line 91, in <module>
handle_request()
File "/home//.kodi/addons/plugin.video.flix2kodi/addon.py", line 37, in handle_request
general.main(video_type)
File "/home//.kodi/addons/plugin.video.flix2kodi/resources/general.py", line 50, in main
mylist = lolomos.get_mylist(root_list)
File "/home//.kodi/addons/plugin.video.flix2kodi/resources/path_evaluator/types/lolomos.py", line 54, in get_mylist
llms = child('lolomos', ret)
File "/home//.kodi/addons/plugin.video.flix2kodi/resources/path_evaluator/__init__.py", line 98, in child
raise ValueError(str(chld)+' not found in: '+str(jsn))
ValueError: lolomos not found in: {}
20:27:50 T:140020971747328 ERROR: GetDirectory - Error getting plugin://plugin.video.flix2kodi/?mode=main&thumb&type=show&url
20:27:50 T:140020971747328 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.flix2kodi/?mode=main&thumb&type=show&url) failed
I'm having the exact same problem. The fixed files from post 880 haven't helped me unfortunately Sad
thanks for the TIPS, finally i can return to see netflix comfortable on the couch
(2017-01-19, 20:03)StarLite Wrote: [ -> ]
handle_request()
Exact same error here. I was able to use the corrections from post 880 for awhile until this error. I now get an endless re-login loop.
(2017-01-20, 22:53)ronsonol8 Wrote: [ -> ]
So I've been having this same error and I haven't figured out what is causing the error yet but I was running with chromium when I had this issue and I recently downloaded Chrome instead and that seems to have fixed the issue. I'm not certain if the issue is actually fixed though because now I have a http 404 error that I haven't had time to look into yet.
hi im having troubles setting it up.
Quote:06:30:35.772 T:139634285737728 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: root_list_id not found in cookies!
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/addon.py", line 91, in <module>
handle_request()
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/addon.py", line 37, in handle_request
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/resources/general.py", line 49, in main
root_list = lolomos.get_root_list()
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/resources/path_evaluator/types/lolomos.py", line 40, in get_root_list
return get_root_list_id_from_cookie()
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/resources/path_evaluator/__init__.py", line 68, in get_root_list_id_from_cookie
raise ValueError('root_list_id not found in cookies!')
ValueError: root_list_id not found in cookies!
06:30:35.833 T:139634554173184 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
06:30:35.896 T:139635122133376 ERROR: GetDirectory - Error getting plugin://plugin.video.flix2kodi/?mode=main&thumb&type=movie&url
06:30:35.896 T:139635122133376 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.flix2kodi/?mode=main&thumb&type=movie&url) failed
I'm trying to setup Flix2Kodi but I'm seeing the following error message in the log.
11:28:57 T:4496   ERROR: [plugin.video.flix2kodi] Traceback (most recent call last):
                                              File "C:\Users\fishn\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\addon.py", line 85, in <module>
                                                handle_request()
                                              File "C:\Users\fishn\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\addon.py", line 37, in handle_request
                                              File "C:\Users\fishn\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\general.py", line 46, in main
                                                add_dynamic_lists()
                                              File "C:\Users\fishn\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\general.py", line 60, in add_dynamic_lists
                                                ret, root_list = req_lists()
                                              File "C:\Users\fishn\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\general.py", line 74, in req_lists
                                                ret = req_path(lolomos.my_list(root_list), lolomos.lists(root_list))
                                              File "C:\Users\fishn\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\path_evaluator\__init__.py", line 26, in req_path
                                                content = connect.load_netflix_site(generic_utility.evaluator_url % (generic_utility.api_url, endpoints['/pathEvaluator']), post)
                                              File "C:\Users\fishn\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\connect.py", line 143, in load_netflix_site
                                                raise ValueError('!HTTP-ERROR1!: '+str(status_code)+' loading: "'+url+'", post: "'+ str(post)+'"')
                                            ValueError: !HTTP-ERROR1!: 404 loading: "https://www.netflix.com/api/shakti/pathEvaluator/9ce4104ab5e91cd339a254dc30c81c37bc74dba8?materialize=true&model=harris", post: "{"paths":[["lolomos","9b6bebd3-da20-4a76-a277-172cea124b9f_ROOT","mylist"],["lolomos","9b6bebd3-da20-4a76-a277-172cea124b9f_ROOT",{"from":0,"to":99},"displayName"]],"authURL":"1485088656753.ocinnDnLPxeNFeoHR+46JC9ZyWI="}"
Having the same issues as above. Wiped everything. Tried un5ki11ed version do not even get a login or pick profile. Tried logi85 from repo and login and profiles show but same error as above.
Kodi.log shows:
https://www.netflix.com/api/shakti/pathE...del=harris
When I pull netflix up with development tools open, it looks like this:
https://www.netflix.com/api/shakti/d72b0...del=harris
The text in the middle does not change when I logout and back in. I can add the text before /pathEvaluator but do not understand the code enough to figure out how to get rid of the text before ?materialize. Might this be causing the issue with retrieving the list of movies and TV shows?
also getting the same error as other post?
Anybody got a fix?
Quote:21:56:57.376 T:139827987064576 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: !HTTP-ERROR1!: 404 loading: "https://www.netflix.com/api/shakti/pathEvaluator/9ce4104ab5e91cd339a254dc30c81c37bc74dba8?materialize=true&model=harris", post: "{"paths":[["lolomos","2c307949-d779-4ca2-a7b4-93b4fbb371ea_ROOT","mylist"],["lolomos","2c307949-d779-4ca2-a7b4-93b4fbb371ea_ROOT",{"from":0,"to":99},"displayName"]],"authURL":"1485377810838.4m/SuKbwmAP77BSV2vSAG82N0N0="}"
handle_request()
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/resources/general.py", line 50, in main
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/resources/path_evaluator/types/lolomos.py", line 53, in get_mylist
ret = req_path(my_list(root_list_id), lists(root_list_id))
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/resources/path_evaluator/__init__.py", line 26, in req_path
File "/home/iiidefconiii/.kodi/addons/plugin.video.flix2kodi/resources/connect.py", line 143, in load_netflix_site
ValueError: !HTTP-ERROR1!: 404 loading: "https://www.netflix.com/api/shakti/pathEvaluator/9ce4104ab5e91cd339a254dc30c81c37bc74dba8?materialize=true&model=harris", post: "{"paths":[["lolomos","2c307949-d779-4ca2-a7b4-93b4fbb371ea_ROOT","mylist"],["lolomos","2c307949-d779-4ca2-a7b4-93b4fbb371ea_ROOT",{"from":0,"to":99},"displayName"]],"authURL":"1485377810838.4m/SuKbwmAP77BSV2vSAG82N0N0="}"
Hello folks,
It's been a while since i was looking for a KODI Addon to fully integrate Netflix on my Win10 KODI living room PC.
I've found this addon today, installed it and - guess what - not working.
Although I'm glad that there are still people out there who obviously try to get things working, i think of it as a Sisyphean task, as - obviously - Netflix does not have any intention of making things easy for people who like to use their services not "off the shelf", which renders - imho - any plugin as a doomed waste of time (sorry for my honesty).
However, i've found a quite easy way for me to start Netflix out from KODI by just using a full screen chrome Window (kiosk mode) through an custom Aeon Nox Main menu entry (i guess there are also other skins which support such custom menus).
Just activate one of the "Custom" Menus, and set it up like:
* Select "Default Action" in the Menu
* Select "user defined entry" at the bottom of the menu
* Enter the following line:
System.ExecWait(""C:\Program Files(x86)\Google\Chrome\Application\chrome.exe" -kiosk -newwindow https://www.netflix.com")
(you might need to adopt the path to the chrome binary)
Of course this has some ugly disadvantages: you'll probably need a pointing device to handle the netflix UI and you'll not get AC3 sound, but this solution works for me for quite a while without any "api changing headaches". I agree that this solution will probably miserably fail any WAF tests.
I've also tried running the Windows Netflix App through a System.ExecWait call (over a .vbs batch file), however i've always had problems with window focus (either netflix not getting the focus after start, or Kodi not getting focus after exiting Netflix App), but this is not an issue with Chrome kiosk mode. Additionally, netflix never managed to get the App working so it can be controlled with cursor keys and "enter" (which would be perferct for my MCE remote), so the App didn't have much advantage for me.
hth,
yours,
Juergen
Hi Guys,
I also just trying to get this somehow working in KODI but I have also no success. I get the following Error:
18:52:36 T:140062502418176  NOTICE: [plugin.video.flix2kodi] Loading netflix: https://www.netflix.com/Login Post: None
18:52:37 T:140062502418176  NOTICE: [plugin.video.flix2kodi] Setting authorization url: 1485456756769.RHIM9WC//rYRg7dD+8hzpNm1v2c=
18:52:37 T:140062502418176  NOTICE: [plugin.video.flix2kodi] Loading netflix: https://www.netflix.com/Login?locale=en Post: {u'rememberMe': u'true', u'authURL': '1485456756769.RHIM9WC//rYRg7dD+8hzpNm1v2c=', u'mode': u'loginPassword', u'action': u'loginAction', u'password': 'mypassword', u'flow': u'websiteSignUp', u'email': '[email protected]', u'nextPage': u'', u'withFields': u'email,password,rememberMe,nextPage'}
18:52:39 T:140062502418176  NOTICE: [plugin.video.flix2kodi] Setting authorization url: 1485456758518.vSb90vMQ9KuGvVx0zlF5Qxp2Yt0=
18:52:39 T:140062502418176  NOTICE: [plugin.video.flix2kodi] cookies: <RequestsCookieJar[<Cookie profilesNewSession=0 for />, <Cookie profilesNewUser=0 for />, <Cookie NetflixId=ct%3DBQAOAAEBEJWZFVgt9cayiiHcw0p_IyWB0B2wg-gZOz4lmbSAW_AZ4bBNFV9IvRiud0Ptw-vkJj5vgBQbL77iLuF-Zfl9LwCgRy8MnQ4p7O8A70h4XruCrUqlDji4yq0mbTIudyzhNt1G0ZeBRiRa5fzayCgL1CRIqQIk0f7PuHhH0JqNJ-gn6m1a5UEAPJioQktniFT7wFr7nTB6r1jvHM1Rm64g_4UTG221nMUnP4mslLtsl3LZ_SJz2ZxDg9rOi1GO-WuQR-rVrM0X29D26Pks1v5fhQfbLekXmStL4QIHuhMvRasgQUFVvG-Pw16TQgm3V9ZaeTd6zgv8h7EVNdnlolMLC3McvwO_B3fPKXI5tc2OW4wtVzURJL928rrEY1uv9v9MS92snLih5qwIM8ZyZg_a-5_U9eDG4y4S91VyAb1iBxQ6IXFL6Ts5YWhZm0klHmUx0GucZw4C9aZhyg_3iRrX9QEeS5_WxXH_zMChaitthj7kcUk9NiHBFO8a1uuqiihQa1R2ti4f5a1JPkKoBoX-mFVcZoo-V94urrgCyrS4mxeihozQITxOpu4fqEQom10tQAfpBHnGwMVOTqvIdqK-LTkKlckUMBEX7Ny-XW3jYxILKFU2oAk72fW1gYNC-jOMaxaT%26bt%3Ddbl%26ch%3DAQEAEAABABSE3922NKP3WgsGsOd7geazR9mppf6ZOJ0.%26v%3D2%26mac%3DAQEAEAABABR6ZGuJIPsi84niHc7uL0mzv2WEYBhERPQ. for .netflix.com/>, <Cookie SecureNetflixId=v%3D2%26mac%3DAQEAEQABABRqPUBmOX5GzQxORx59rcqTQuEzLo7ndAs.%26dt%3D1485456757944 for .netflix.com/>, <Cookie dsca=customer for .netflix.com/>, <Cookie lhpuuidh-browse-JCGQELLAZBARLCOP7MUNZJRA7M=PL%3ADE-PL%3A7db30474-3b50-414a-8dd0-88917f785f17_ROOT for .netflix.com/>, <Cookie lhpuuidh-browse-JCGQELLAZBARLCOP7MUNZJRA7M-T=1485456759571 for .netflix.com/>, <Cookie memclid=827576ac-4af1-4205-b077-d47bcc161dd4 for .netflix.com/>, <Cookie nfvdid=BQFmAAEBEGVSWR%2F%2FQGTtTWws7hFexn1glGvRyahaFnkou8toRURc19RmYYzhYMbvocxRyU5qqB6JKFWsVAJ38H4K9gEqu8TwLqWmXAyPKgidCSqBGtV0nTiFQzYADFb9o3owOluUYvWNmMdwxDCv6WF5b6vqFaJx for .netflix.com/>, <Cookie profilesNewSession=0 for .netflix.com/>]>
18:52:44 T:140062502418176   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            [b]Error Contents: !HTTP-ERROR1!: 404 loading: "https://www.netflix.com/api/shakti/pathEvaluator/9ce4104ab5e91cd339a254dc30c81c37bc74dba8?materialize=true&model=harris", post: "{"paths":[["videos",[70293585,70293584,70293583,70293582,70293581,70293580,70293579,70248301,70248300,70248299,70248298,70248297,70248296,70248295,70248294,70248293,70248292,70248291,70248290,70248289,80119350],["availability","bookmarkPosition","details","episodeCount","maturity","queue","releaseYear","requestId","runtime","seasonCount","summary","title","userRating","watched","hd"]],["videos",[70293585,70293584,70293583,70293582,70293581,70293580,70293579,70248301,70248300,70248299,70248298,70248297,70248296,70248295,70248294,70248293,70248292,70248291,70248290,70248289,80119350],"current",["summary","runtime","bookmarkPosition","creditsOffset","title"]],["videos",[70293585,70293584,70293583,70293582,70293581,70293580,70293579,70248301,70248300,70248299,70248298,70248297,70248296,70248295,70248294,70248293,70248292,70248291,70248290,70248289,80119350],"seasonList","current",["showMemberType","summary"]],["videos",[70293585,70293584,70293583,70293582,70293581,70293580,70293579,70248301,70248300,70248299,70248298,70248297,70248296,70248295,70248294,70248293,70248292,70248291,70248290,70248289,80119350],"boxarts",["_665x375","_342x192"],"jpg"]],"authURL":"1485456739527.rsi8h/34ErdhTeaPLpEwE0wpCZo="}"
                                            Traceback (most recent call last):[/b]
                                              File "/home/username/.kodi/addons/plugin.video.flix2kodi/addon.py", line 91, in <module>
                                                handle_request()
                                              File "/home/username/.kodi/addons/plugin.video.flix2kodi/addon.py", line 47, in handle_request
                                                list.viewing_activity(video_type, run_as_widget)
                                              File "/home/username/.kodi/addons/plugin.video.flix2kodi/resources/list.py", line 56, in viewing_activity
                                                metadata = get.viewing_activity_matches(video_type)
                                              File "/home/username/.kodi/addons/plugin.video.flix2kodi/resources/get.py", line 58, in viewing_activity_matches
                                                ret = req_path(path1, path2, path3, path4)
                                              File "/home/username/.kodi/addons/plugin.video.flix2kodi/resources/path_evaluator/__init__.py", line 26, in req_path
                                              File "/home/username/.kodi/addons/plugin.video.flix2kodi/resources/connect.py", line 143, in load_netflix_site
                                            ValueError: !HTTP-ERROR1!: 404 loading: "https://www.netflix.com/api/shakti/pathEvaluator/9ce4104ab5e91cd339a254dc30c81c37bc74dba8?materialize=true&model=harris", post: "{"paths":[["videos",[70293585,70293584,70293583,70293582,70293581,70293580,70293579,70248301,70248300,70248299,70248298,70248297,70248296,70248295,70248294,70248293,70248292,70248291,70248290,70248289,80119350],["availability","bookmarkPosition","details","episodeCount","maturity","queue","releaseYear","requestId","runtime","seasonCount","summary","title","userRating","watched","hd"]],["videos",[70293585,70293584,70293583,70293582,70293581,70293580,70293579,70248301,70248300,70248299,70248298,70248297,70248296,70248295,70248294,70248293,70248292,70248291,70248290,70248289,80119350],"current",["summary","runtime","bookmarkPosition","creditsOffset","title"]],["videos",[70293585,70293584,70293583,70293582,70293581,70293580,70293579,70248301,70248300,70248299,70248298,70248297,70248296,70248295,70248294,70248293,70248292,70248291,70248290,70248289,80119350],"seasonList","current",["showMemberType","summary"]],["videos",[70293585,70293584,70293583,70293582,70293581,70293580,70293579,70248301,70248300,70248299,70248298,70248297,70248296,70248295,70248294,70248293,70248292,70248291,70248290,70248289,80119350],"boxarts",["_665x375","_342x192"],"jpg"]],"authURL":"1485456739527.rsi8h/34ErdhTeaPLpEwE0wpCZo="}"
18:52:44 T:140065629526464   ERROR: GetDirectory - Error getting plugin://plugin.video.flix2kodi/?mode=list_viewing_activity&thumb&type=show&url
18:52:44 T:140065629526464   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.flix2kodi/?mode=list_viewing_activity&thumb&type=show&url) failed
Not sure how I should interpret this error but it looks like the authentication is working but I can not watch anything. In Kodi it always shows Login / complete etc. and this its doing like 5 times and than I should check the error log.
I reset the Plugin, cleared cookies, etc. nothing helped. In Google Chome its working fine (OpenSuse).
Any help would be great !
On windows 10 kodi app:
19:59:49.472 T:9064   ERROR: Control 55 in window 10025 has been asked to focus, but it can't
19:59:50.182 T:5084   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.ImportError'>
                                            Error Contents: DLL load failed: Nie mozna odnalezc okreslonego modulu.
                                              File "C:\Users\Konrad\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\addon.py", line 10, in <module>
                                                from resources import general
                                              File "C:\Users\Konrad\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\general.py", line 7, in <module>
                                                import add
                                              File "C:\Users\Konrad\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\add.py", line 10, in <module>
                                                from resources import library
                                              File "C:\Users\Konrad\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\library.py", line 9, in <module>
                                                import get
                                              File "C:\Users\Konrad\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\get.py", line 18, in <module>
                                                from resources import connect, video_parser
                                              File "C:\Users\Konrad\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\connect.py", line 15, in <module>
                                                from resources import chrome_cookie
                                              File "C:\Users\Konrad\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\chrome_cookie.py", line 16, in <module>
                                                import win32crypt
                                            ImportError: DLL load failed: Nie mozna odnalezc okreslonego modulu.
19:59:50.206 T:9064   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.flix2kodi/
19:59:50.453 T:9064   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.flix2kodi/) failed
19:59:50.862 T:9512  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:00:05.284 T:1552  NOTICE: Previous line repeats 4 times.
20:00:05.284 T:1552  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
Broke for me either.
Very sad...
Running on Kodi; Started poking at / understanding source code a little bit. The 404 error from #909 is the same as what i'm seeing, I believe.
404 indicates the paths are not longer accurate. (https://en.wikipedia.org/wiki/HTTP_404)
Some dynamic path evaluation/building was added in this changelist, but apparently they have changed again in some fashion (most likely not the endpoints, as I can still see the response form Netflix providing the endpoints- more likely some other bit of the path-building engine)
https://github.com/logi85/plugin.video.f...eb61321d63
I think the only way to fix for certain is to sniff some traffic from a netflix appliance and check what paths are being used by the API/App.
I'd expect it is https, so that would require a bunch of screwing around (transparent proxy/etc).. but not sure. May look more into it.
By the way, there is a change.org petition for Netflix to write an official Kodi plugin. not that it will gather any traction, i don't think:
https://www.change.org/p/netflix-write-a...merly-xbmc
Just a short update.
After doing some search, I found a nice add-on that can give another option: Remote Control Browser (http://addons.kodi.tv/show/plugin.progra...l.browser/).
It enables Chrome on full screen with remote control working (arrows in remote control can move the mouse cursor).
It is not ideal, but you can easily enter and browse Netflix website. No need to always update settings according to API.
