Full Version: [RELEASE] Flix2Kodi - Just another Netflix-Addon
(2016-01-03, 15:27)mhoogenbosch Wrote: [ -> ]
(2016-01-03, 14:32)logi85 Wrote: [ -> ]
(2016-01-02, 15:23)mhoogenbosch Wrote: [ -> ]there is a remote plugin which maps kodi commands to key presses, that's how I control the functions in the movie. Works very well,
can you please provide further informations? so i would add it to the faq on the first page.
The plugin is called 'Remote Control Chronium', you can download it form the following location: http://openelec.tv/forum/128-addons/7759...mitstart=0
btw, this is also the thread which led me to your plugin Smile
I am trying to figure out how to use it with my flirc since flirc emulates a keyboard. The flirc "remote" commands are seen as keyboard presses and not captured (best I can tell) by the remote control add-on. I guess I could program I whole new device into my remote to use when I am watching netflix but that is hardly user friendly.
Version 0.4.4 is working on Windows 7 32bit with two small issues
1: Had to edit chrome.cmd in launcher folder to say %ProgramFiles% instead of %ProgramFiles(x86)% as the x86 folder doesn't exist on 32bit windows
2: Pressing stop on mce remote doesn't quit chrome. I'm using a autohotkey script as a workaround for now.
Otherwise, great job on resurrecting Netflix in kodi
(2016-01-04, 01:27)logi85 Wrote: [ -> ]
(2016-01-04, 01:23)bry- Wrote: [ -> ]@logi85 - thanks for this add-on!
I just tested again and it looks good.
two questions: how do I start netflix video in full screen? how can I control netflix via my standard kodi remote?
which OS do you use? which browser? if you use ubuntu with window-manager and chrome or windows 8.1 with chrome it should run out of the box.
windows 10 - does not go full screen via chrome browser.
windows 7 - works full screen with chrome browser - navigating with the controller is an issue.
Doesn't seem to work in Edge for me, Just get message about clicking back
No luck with 0.4.4, Mac OS X 10.11.2, Kodi 15.2
In the module, resources/chrome_cookie.py, I'm getting an error when it can't find the module keyring to load (so says the log file):
if generic_utility.windows():
    import win32crypt
elif generic_utility.darwin():
   import keyring
else:
    from Crypto.Cipher import AES
    from Crypto.Protocol.KDF import PBKDF2
Do I need to update something in python?
(2016-01-04, 07:18)mathgeek97 Wrote: [ -> ]No luck with 0.4.4, Mac OS X 10.11.2, Kodi 15.2
    import win32crypt
   import keyring
else:
I'm running 10.10.5 with a similar error (re: import keyring) which I've logged on github
(2016-01-04, 03:48)tree_and_kite Wrote: [ -> ]Version 0.4.4 is working on Windows 7 32bit with two small issues
Coluld you perhaps share your autohotkey script?
(2016-01-04, 13:06)macardi Wrote: [ -> ]
Not at my PC right now but this code should work: http://pastebin.com/gj6i58ah
I look forward to trying out this add-on. A few questions first:
Could it possibly open up in the windows 10 netflix app instead of a browser? Isn't it correct that the app plays 5.1 surround, while netflix in a browser is only stereo?
Since version 0.4.4 everytime I get back from browser to Kodi I'm getting the error message "Flix2Kodi: cannot update playcount. see logfile".
I'm using Win7 x64 and IE 11
(2016-01-04, 13:48)tree_and_kite Wrote: [ -> ]
(2016-01-04, 13:06)macardi Wrote: [ -> ][quote='tree_and_kite' pid='2203639' dateline='1451872130']
(2016-01-04, 02:48)sagrath Wrote: [ -> ]When i try to add a movie to My List (not my Library, this feature is working well), I receve an error that flix2kodi has crashed, and ask me to refresh my login.
This the log:
22:45:08 T:2772   ERROR: POParser: warning, unhandled escape character. Problematic entry:
                                            msgctxt "#32090"
                                            msgid "Are you sure you want to reset the permanent cache ? \nWarning: This will delete all contents of the folder "
                                            msgstr "Tem certeza de que deseja redefinir o cache permanente? \ nAviso: Isto irá apagar todo o conteúdo da pasta "
22:45:14 T:4072   ERROR: Previous line repeats 1 times.
22:45:14 T:4072  NOTICE: [plugin.video.flix2kodi] parameters: ?mode=add_to_queue&url=70259170
22:45:14 T:4072   ERROR: [plugin.video.flix2kodi] Traceback (most recent call last):
                                              File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\addon.py", line 86, in <module>
                                                handle_request()
                                              File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\addon.py", line 48, in handle_request
                                                queue.add(url)
                                              File "C:\Users\MediaCenter\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\queue.py", line 12, in add
                                                post_data = generic_utility.my_list % generic_utility.get_setting('authorization_url')
                                            AttributeError: 'module' object has no attribute 'my_list'
Using Win10 with Chrome.
Other features is 100% ok
hi, created an issue, will have a look on in a few days
(2016-01-04, 03:22)Shaddow825 Wrote: [ -> ]
(2016-01-03, 14:32)logi85 Wrote: [ -> ]Hi,
are there log-entries about keystrokes in kodi-logfile? ('unknown action'...) if yes, I could add the keys to mapping. if not, I guess the keystrokes are sent to chrome window I cannot capture.
(2016-01-04, 03:55)bry- Wrote: [ -> ]
hi, is there another chrome window opened in background? only if all other chrome windows are closed the kiosk mode works.
and what is your remote? If it's MCE-Remote-Like perhaps the autohotkey-solution would be your friend. perhaps tree_and_kite could help.
Seems to be working quite OKish so far.
Issues encountered:
- "Flix2Kodi: cannot update playcount. see logfile".
- the odd timeout and request to revalidate login
- cannot exit the thing from the remote (I can play/pause using the OK button, but cannot close the main Chrome window); the AHK script above doesn't work either.
My setup: Kodi 15.2, Win10 64 bit, Chrome latest, started as Chrome (not ChromeLauncher or something else)
