how can I remove the home screen in this skin loving it but have no need to have that tried to install one of the mods but didn't work as would like to be able to change all the home screen widgets any help?
thanks
can only be done in XML, there is no option in the skin settings to not display HOME
Can you please (choose one option) :
- tell us what needs to ne changed in XML if we want to do it by ourselves
- explain what would needed to be done to add such an option to the skin's settings
- add such an option to the skin's settings
Thanks a lot in advance
This is not an easy task as you need to modify tons of stuff in both the default and classic home.
