Full Version: Pipe function and akamaistream.net radio sources
Has anyone being able to get radio streams which come from "akamaistream.net" working with the pipe function?
Example here for 102.7 KIIS FM - http://kiis-fm.akacast.akamaistream.net/...et/kiis-fm
They play fine with vlc and other radio streams work fine for me with the pipe function but these don't. I know they can probably simply be added as a standalone stream in kodi but would be nice to have them within tvheadend.
With this command for example
ffmpeg -i http://prn-foxsports-ic-pri.akacast.akam...rts_ic_pri -vcodec libx264 -acodec copy -mbd rd -copyinkf -flags +ilme+ildct -fflags +genpts -metadata service_provider=STRING -metadata service_name=STRING -f mpegts pipe:1
I see this
http://pastebin.com/t7XuWfSc
edit: Got it working with this (note i am using openelec so command my be slightly different for other systems)
pipe://ffmpeg -loglevel fatal -i http://prn-foxsports-ic-pri.akacast.akam...rts_ic_pri -vn -acodec aac -flags +global_header -strict -2 -metadata service_provider=RADIOPROVIDER -metadata service_name=RADIONAME -f mpegts -mpegts_service_type digital_radio pipe:1
