Full Version: SiO2-X: Trakt not scrobbling when items played from shelf
Hi there,
Using Amazon Fire TV with Kodi 15.2 Isengard.
I was after some help, to get Trakt scrobbling working with the SiO2-X skin.
I have Movies and TV Shows in my library, if I enter into the Movies or TV Shows sections and then play the items from there, Trakt syncs perfectly, but if I play any of the shelf items on the Home screen of SiO2-X, then the Trakt scrobbling does not start.
Is this a known bug, or any way of fixing it?
It's as if the Trakt scrabble isn't invoked when using shelf items to view your media.
Also, another quick error is that I cannot see the menu entries for the Trakt side menu. They are all black/blank.
G
will look into it! but i believe it's all happening at core level / addon level...
Thanks very much! Smile
