2016-01-02, 01:44
I've got KodiBuntu 14.04.3 x64 (Kodi 15.2 Git:02e72013 Compiled Oct 19 2015) running on an Intel small form factor PC. I've upgraded the kernel to 3.19.8-031908-generic. CPU is i5-4570T with 8GB RAM and DisplayPort to HDMI adapter (Intel onboard video) and wired Intel gigabit ethernet.
I'm playing an MKV file that's a direct rip of a DVD. There has been no transcoding done on this file. When I have VAAPI enabled, I have some black frames and slight (non-green) pixelation during MKV with MPEG2 playback. This happens consistently on the MKV files that I've ripped that are MPEG2. When I disable VAAPI, playback is perfectly fine. However, BluRay playback will be stuttery with VAAPI disabled. I've been looking around the forum and have followed this guide to upgrade the kernel and the vaapi-driver from wsnipex. This hasn't fixed the VAAPI MPEG2 issue. Where should I look next? I like the ease of use of KodiBuntu, but I'm open to suggestions. Please let me know if there's any other info I need to add. Thank you!
