2016-01-02, 17:55
I have been using Kodi on five PCs in my network for quiet a few years now. While Windows as an OS was always too hard to administrate on so many PCs I was using OpenElec instead. Now the Shield TV box seems to deliver an even more interesting plattform since it offers a lightweight player, low power consumption and Android as OS, which gives the option to use nicely designed apps instead of only plain Kodi addons (Netflix, youtube etc.). But most of all it filled the last blind spot that OpenElec always seemed to have: Gaming. While Windows-PC would require expensive hardware (and cause the aforementioned administrative complexity) Android - and especiall the Shield TV Box with its graphic powers - delivers a siimple and affordable plattform for Kodi AND gaming, the ultimate media box.
So for christmas I got myself my first NVidia Shield TV box and currently I am still planning on buying another three to have the same plattform all over my home network for media playback and gaming. But switching from OpenElec to an Android box I currently have three big issues to solve which I need some advise for:
1. Previously I was able to wake up all my OpenElec PCs from standby remotely via WoL (wake on lan) and administrate them via SSH. Now I managed to get SSH-access to the Shield TV box as well by installing SSH-droid. I was even able to get the Shield TV Utility to work via network as another useful tool for remote administration (having had to connect the box via USB for at least one time to get the confirmation dialogue popping up). But I have not been able to find a way to wake up the Shield TV box from sleep mode via network (WoL) yet. Any idea how I could do that? Currently I would have to run around in my home and wake them up manually.
2. With my OpenElec PC I was able to use a master/slave-socket outlet to have my TV and my receiver starting together with the PC. I only needed to press the start button of the remote control that I used to control Kodi with and everything turned on. And also when I switched off Kodi all peripherals were turned off as well. Now using the Shield TV the power consumption in idle mode seems too low to cause the slaves to turn on. And when I lower the threshold all slaves stay on all the time, even when I put the Shield TV box in sleep mode. I tried using CEC instead, but while my TV (Samsung) is turned on together with the Shield TV Box my receiver (Onkyo) is not. And both are never turned off when I put the Shield TV in sleep mode. So CEC does not seem to be a solution yet. Do you have an idea how to turn the peripherals on and off together with the Shield TV box?
3. Using the Pulse Eight CEC adapter with my OpenElec-PC I had perfect CEC support. Most importantly I was able to adjust the volume of my receiver with the remote control of my Kodi PC. But though the Shield TV box claims to support CEC I never got the Shield remote control to adjust the volume of my receiver. Do you know a solution for that?
Thanks it advance for any help!
FantasticN
FantasticN
