2016-01-02, 20:06
Hey Guys -
I've tried to do my homework before posting and have found related posts, but no solution or explanation so far, so here it goes...
I am having / have had issues in Kodi when fast forwarding. In nearly every video, it seems the faster I try to fast forward; the more often it freezes after a few seconds. It doesn't crash Kodi and if I click "Play", it will resume at the point it froze at where I then try to fast forward again. It's becoming extremely frustrating! This occurs on videos of all varieties. I've tried wiping the OS and performing a complete reinstall, but no to avail. This has always been an issue since I ran XBMC 12.x a while back. I've tried a few things like making adjustments in advancedsettings.xml like increasing the cache, but that doesn't help, either.
Below is the system setup for my main Kodi box, Kodi's basic Configuration, & my current advanced.xml
Kodi System Configuration
- Kodi 15.2
- Windows 7 x64 (Fully Patched)
- Dedicated system connected to TV via HDMI
- Intel I7 CPU
- 8gb RAM
- SSD for OS Disk
- All drivers are installed & 100% up to date
- Currently using integrated video (Intel HD5000) but about to re-install my Nvidia GX660 as sometimes I use PC for Nvidia Gamestream. Issue occurs when I used the 660 previously, too
- Only other thing the system is used for is eventghost to control many things in Kodi, Flirc USB, and Plex Home Theater which I sometimes switch to. Plex HT does not run in background while Kodi is running, though.
Kodi Configuration
- Each library has a single remote source path connected via SMB and located on a different PC which is on the same LAN
- Kodi PC & Server (library sources) are each connected via ethernet (10/100/1000) to router (Have used at least 3 different routers since issue started)
- Basic setup using Artic Zephyr skin (issue occurs no matter skin used)
- A few various Plugins which all come from Kodi's default repo
- Watch status for everything synced with TrakTV
Configuration Files
Link to guisettings.xml
Link to sources.xml
Link to advancedsettings.xml (also shown below)
Media Played
Most of the media played are MKV and MP4 with a few AVIs and other formats floating around. Most of them are also H264 even though I'm starting to use H265 / HEVC more currently. All seemingly have the issue
Kodi Log File
I checked the log file for timestamps for when the freezing occurs. Unfortunately, it doesn't show anything that cooresponds when it happens. In fact, the only error(s) it shows not related to media scanning is below and seem to relate to the add-on PleXMBC which I tried out a while back yet do not currently use. The issue occurred well before trying to plugin anyways...
Any thoughts or suggestions? Happy to post links to other files if needed (except passwords.xml) Thanks!
- Kodi 15.2
- Intel I7 CPU
- 8gb RAM
- SSD for OS Disk
Kodi Configuration
Configuration Files
Link to sources.xml
<advancedsettings>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
<recentlyaddeditems>75</recentlyaddeditems> <!-- How many items to list in "Recent" category -->
<hideemptyseries>true</hideemptyseries> <!-- set to "true" to hide empty series in the video library and prevent empty series from being removed during a library cleanup. -->
<dateadded>1</dateadded>
</videolibrary>
<network>
<buffermode>1</buffermode> <!-- Default is 1 -->
<cachemembuffersize>256000000</cachemembuffersize> <!-- Default is 20971520 bytes or 20 MB -->
<readbufferfactor>25</readbufferfactor> <!-- Default is 1.0 -->
</network>
<video>
<timeseekforward>30</timeseekforward> <!-- Skip back time 15 s -->
<timeseekbackward>-10</timeseekbackward> <!-- Skip forward time 10 s -->
<subsdelayrange>0</subsdelayrange> <!-- Subtitle offset adjustment range -->
<playcountminimumpercent>90</playcountminimumpercent> <!--Minimum percentage that has to be played before it is marked as watched. Set to 101 to never auto-mark items as watched -->
<ignorepercentatend>8</ignorepercentatend> <!-- percentage of video to ignore at the end. If you stop watching the video here no resume point is created. Set to 101 to never save a resume point. The video is already marked as watched at 90%, see above. -->
<excludefromscan>
<regexp>-trailer</regexp>
<regexp>[!-._ \\/]rarbg[-._ \\/]</regexp>
<regexp>[!-._ \\/]sample[-._ \\/]</regexp>
<regexp>.*extra.*</regexp>
<regexp>.*bonus.*</regexp>
</excludefromscan>
<trailermatching> <!-- This regexp will match moviename_Trailer.avi -->
<regexp>(.*?)(-trailer)(\.[^.]+)$</regexp>
</trailermatching>
</video>
<videoscanner>
<ignoreerrors>true</ignoreerrors> <!-- Silently ignore errors while scanning videos. -->
</videoscanner>
</advancedsettings>
Media Played
Kodi Log File
11:59:06 T:3308 ERROR: Traceback (most recent call last):
11:59:06 T:3308 ERROR: File "C:\Users\XBMC\AppData\Roaming\Kodi\addons\script.plexbmc.helper-3.4.1\resources\lib\httppersist.py", line 62, in get
11:59:06 T:3308 ERROR: conn.request("GET", path, headers=header)
11:59:06 T:3308 ERROR: File "C:\Program Files (x86)\Kodi\system\python\Lib\httplib.py", line 995, in request
11:59:06 T:3308 ERROR: self._send_request(method, url, body, headers)
11:59:06 T:3308 ERROR: File "C:\Program Files (x86)\Kodi\system\python\Lib\httplib.py", line 1029, in _send_request
11:59:06 T:3308 ERROR: self.endheaders(body)
11:59:06 T:3308 ERROR: File "C:\Program Files (x86)\Kodi\system\python\Lib\httplib.py", line 991, in endheaders
11:59:06 T:3308 ERROR: self._send_output(message_body)
11:59:06 T:3308 ERROR: File "C:\Program Files (x86)\Kodi\system\python\Lib\httplib.py", line 844, in _send_output
11:59:06 T:3308 ERROR: self.send(msg)
11:59:06 T:3308 ERROR: File "C:\Program Files (x86)\Kodi\system\python\Lib\httplib.py", line 806, in send
11:59:06 T:3308 ERROR: self.connect()
11:59:06 T:3308 ERROR: File "C:\Program Files (x86)\Kodi\system\python\Lib\httplib.py", line 787, in connect
11:59:06 T:3308 ERROR: self.timeout, self.source_address)
11:59:06 T:3308 ERROR: File "C:\Program Files (x86)\Kodi\system\python\Lib\socket.py", line 571, in create_connection
11:59:06 T:3308 ERROR: raise err
11:59:06 T:3308 ERROR: error: [Errno 10049] The requested address is not valid in its context
11:59:06 T:3308 NOTICE: Unable to connect to
Reason: None
